EL-WIFI-DULT+
EL-WIFI-DULT+
    LASCAR
    Temperature Datalogger WIFI
EL-WIFI-DULT+ 数据手册
EL-WiFi-DULT+ High Accuracy, Dual Channel Ultra Low Temperature Cryogenic Vaccine WiFi Data Logger Your data, anytime, anywhere • Measurement range -100 to +100°C (-148 to +212°F) • High accuracy T-type probe on 2m cable • Dual channel recording through two external thermocouple probes • Wirelessly stream and view data on the EasyLog Cloud, App or on a PC • View and analyse multiple sensors, including graphing of historic data • Configurable high and low alarms with indicator • Easy sensor set-up using free PC software or App The EL-WiFi-DULT+ is designed to monitor vaccines in cryogenic dry ice storage. Data is streamed wirelessly over any compatible WiFi network and can be viewed on a PC using free software or on the EasyLog Cloud or App. To configure the sensor for use on a given wireless network, either connect it via USB to a PC running EasyLog WiFi software on the network, or configure wirelessly using the EasyLog Cloud app on a mobile phone with access to the network. The sensor can then be placed anywhere within range of the network. If the sensor temporarily loses connectivity with the network, it will log readings until it is able to communicate again with the PC application or EasyLog Cloud (max 30 days at 10 second sample interval). The sensor is IEEE 802.11bgn* (2.4GHz) compliant, supports WEP, WPA/WPA2 encryption and enterprise networks (PEAP, TTLS, FAST). EL-WiFi-DULT+ has a protection rating of IP40. The unit is freestanding, but can be attached to a wall or surface using the bracket provided. The unit can be clipped in and out of the bracket as required. ACCESSORIES SPECIFICATIONS Minimum Typical Battery life Temperature measurement range USB supply voltage (@500mA) Maximum >6 Months -100 (-148) 4.5 5.0 +100 (+212) °C (°F) 5.5 Vdc +60 (+140) °C (°F) Operating temperature range (logger) -20 (-4) Logging period (user configurable) 10 sec 10 min 12 hrs Transmission period (user configurable) 1 min 1 hr 24 hrs Temperature measurement resolution 0.1 (0.2) Temperature display resolution Dimensions ±1.8 (±3.2) IP40 °C (°F) (Bung fully inserted, not permanently powered, thermocouple connector fitted and fully inserted, device mounted vertically.) 82 x 70 x 36mm (3.22 x 2.75 x 1.41”)** Probe dimensions 300 x Φ 1.5mm, 2m cable (11.8 x Φ 0.05, 39.3” cable) * MAC Address starting 98:8B:AD:2....... only **Excluding probe and mounting bracket PSU-5VDC-USB-USA USB Mains Power Adapter for USA PSU USB-UK USB Mains Power Adapter for UK PSU USB-EU USB Mains Power Adapter for EU EL-P-TC-T-ULT+ Replacement T-type Thermocouple probe °C (°F) 0.1 Accuracy IP Rating Unit INCLUDED IN THE BOX EL-WIFI WALL BRACKET Wall mounting bracket for EL-WiFi sensors EL-P-TC-T-ULT+ Thermocouple probe CABLE USB A-MICRO B USB Type A to Micro B CALIBRATION CERTIFICATES NOW AVAILABLE Lascar now offers a Traceable Calibration Certificate Service on Temperature Data Loggers. Using reference equipment which has been calibrated by a UKAS/NIST accredited laboratory and using apparatus traceable to national or www.lascarelectronics.com/data-loggers international standards. For more information please see www.lascarelectronics.com. Issue 1 12/2020 Page 1 of 2 EL-WiFi-DULT+ High Accuracy, Dual Channel Ultra Low Temperature Cryogenic Vaccine WiFi Data Logger Your data, anytime, anywhere Easylog Software Lascar’s WiFi software is available as a free download from: www.lascarelectronics.com/software/easylog-wifi. Easy to install and use, EL-WiFi-WIN allows easy connection of sensors to a WiFi network. The user can select where data is stored - the PC or the Cloud. When setting up your logger, make sure you select the T-Type probe. Battery Life and Power Supply The battery can be recharged (unit must be between 0 - 40 °C) via a PC, a USB +5V wall adapter, or a portable USB battery pack using the USB lead provided. It can also be permanently powered by a USB wall adapter or USB battery pack. Readings may be affected while the internal battery is being charged. However, once charged, continued connection of the charger will have no effect. Battery life is dependent on: transmission period, WiFi encryption method, WiFi encryption key rotation frequency (determined by the router/access point), signal strength between router/access point and WiFi device, presence volume and type of WiFi traffic from other devices, sample rate and operating temperature. Specifications liable to change without prior warning www.lascarelectronics.com/data-loggers Issue 1 12/2020 Page 2 of 2
EL-WIFI-DULT+ 价格&库存
很抱歉,暂时无法提供与“EL-WIFI-DULT+”相匹配的价格&库存,您可以联系我们找货
