7006800
7006800
    LASER
    TRUSENSE S300 CASED
7006800 数据手册
LTI Products Laser Sensors Laser Sensors TruSense S200 Part No: E1 Desc: 7005785 TRUSENSE S200 Same small design offering great range and high accuracy in an economical package. Ideal for applications requiring RS232 and a Trigger Output. Key Features:   • Offers a variety of user-configurable target modes: first, last and strongest, and well as advanced modes for multiple-targets.   • Makes non-contact and non-intrusive measurements without the need for frequent calibration.   • Recognizes small targets at long distances, within narrow openings and from sharp angles.   • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for cameras or other equipment. TruSense S200 w/o Housing (OEM) Part No: E1 Desc: 7005910 TRUSENSE S200 OEM Same capabilities as the standard S-200, except it does not come with an external case. Ideal for system integration. Key Features:   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for cameras or other equipment. • Makes non-contact and non-intrusive measurements without the need for frequent calibration.   • Recognizes small targets at long distances, within narrow openings and from sharp angles.   • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for cameras or other equipment. 8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 1 of 7 Laser Sensors Laser Sensors TruSense S210 (RS232 w/Pointer) Part No: E1 Desc: 7006740 TRUSENSE S210 ,RS232 W/POINTER This model utilizes a visible alignment laser and offers serial RS232 and a Trigger Output. Ideal for applications requiring an alignment laser and RS232. Key Features:   • Offers a variety of user-configurable target modes: first, last and strongest, and well as advanced modes for multiple-targets.   • Makes non-contact and non-intrusive measurements without the need for frequent calibration.   • Recognizes small targets at long distances, within narrow openings and from sharp angles.   • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for cameras or other equipment. TruSense S210 W/O Housing (OEM) Part No: E1 Desc: 7006741 Same capabilities as the standard S-200 OEM, except it comes with a visible alignment laser. Ideal for system integration. Key Features:   • Offers a variety of user-configurable target modes: first, last and strongest, and well as advanced modes for multiple-targets.   • Makes non-contact and non-intrusive measurements without the need for frequent calibration.   • Recognizes small targets at long distances, within narrow openings and from sharp angles.   • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for cameras or other equipment. 8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 2 of 7 Laser Sensors Laser Sensors TruSense S230 (4 To 20 w/Pointer) Part No: E1 Desc: 7006750 TRUSENSE S230,4-20MA,W/HART This model utilizes a visible alignment laser and offers serial RS232 and 4-20 outputs and is HART capable. Ideal for applications requiring 4-20. Key Features:   • Offers a variety of user-configurable target modes: first, last and strongest, and well as advanced modes for multiple-targets. • Makes non-contact and non-intrusive measurements without the need for frequent calibration. • Recognizes small targets at long distances, within narrow openings and from sharp angles. • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   • includes HART capability allowing the user freedom to communicate with the laser through 4-20 as well as through RS232 serial communication.   TruSense S230 W/O Housing (OEM) Part No: E1 Desc: 7006751 Same capabilities as the standard S-200 OEM, except it comes with a visible alignment laser and 4-20mA (no RS-232 or trigger out). Ideal for system integration. Key Features:   • Offers 4-20mA analog output.   • Offers a variety of user-configurable target modes: first, last and strongest, and well as advanced modes for multiple-targets.   • Makes non-contact and non-intrusive measurements without the need for frequent calibration. • Recognizes small targets at long distances, within narrow openings and from sharp angles.   • Performs under temperature variations, background noise and low dielectric or acoustically absorbing materials.   8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 3 of 7 Laser Sensors Laser Sensors TruSense S300 Part No: E1 Desc: 7006800 TruSense S300 Non-contact fluid level measurement sensor capable of generating accurate measurements on highly reflective surfaces. Ideal for applications requiring RS232 and a Trigger Output. Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near flat walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for alarms or other equipment. TruSense S300 w/o Housing (OEM) Part No: E1 Desc: 7006801 TruSense S300 w/o Housing (OEM) Same capabilities as the standard S-300, except it does not come with an external case. Ideal for system integration. Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near flat walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for alarms or other equipment. 8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 4 of 7 Laser Sensors Laser Sensors TruSense S310 (RS232 w/ Pointer) Part No: E1 Desc: 7006805 TruSense S310 (RS232 w/ Pointer) Non-contact fluid level measurement sensor capable of generating accurate measurements on highly reflective surfaces. This model utilizes a visible alignment laser and offers serial RS232 and a Trigger Output. Ideal for applications requiring an alignment laser and RS232. Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near flat walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for alarms or other equipment. TruSense S310 (RS232 w/ Pointer) OEM Part No: E1 Desc: 7006806 TruSense S310 (RS232 w/ Pointer) OEM Same capabilities as the standard S-300 OEM, except it comes with a visible alignment laser and offers serial RS232 and a Trigger Output. Ideal for system integration. Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near flat walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest.   • Offers a selection of trigger outputs allowing the sensor to be used directly as an event trigger for alarms or other equipment. TruSense S330 (4 to 20 w/ Pointer) Part No: E1 Desc: 7006815 TruSense S330 (4 to 20 w/ Pointer) Non-contact fluid level measurement sensor capable of generating accurate measurements on highly reflective surfaces. This model utilizes a visible alignment laser and offers serial RS232 and 4-20mA outputs.  Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest, well as advanced modes for multiple-targets. 8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 5 of 7 Laser Sensors Laser Sensors TruSense S330 (4 to 20 w/ Pointer) OEM Part No: E1 Desc: 7006816 TruSense S330 (4 to 20 w/ Pointer) OEM Same capabilities as the standard S-300 OEM. This model utilizes a visible alignment laser and offers serial RS232 and 4-20mA outputs. Ideal for system integration.  Key Features:   • Provides instantaneous measurements that are accurate and highly repeatable, even over long ranges. • Takes non-contact fluid level measurements with little to no required calibrations.   • Provides a sensor that can be shot through protective screens and near flat walls.   • Generates reliable results by stabilizing the reflections picked up by the receiver • Offers a variety of user-configurable target modes: first, last and strongest, and   well as advanced modes for multiple-targets. Universal Laser Sensor Part No: E1 Desc: 7005400 Universal Laser Sensor W/APD-G Four measurement modes along with extensive measurement selections including output power and update rate make this our most versatile Industrial Sensor. Long range capability and high accuracy make this sensor a world class leader. Includes Interface Package including User's Manual, Configuration cable, and Interface Software   Key Features:   • User configurable pulse and update rates up to 4500 Hz.   • Networking ability of up to 64 addressable units.   • Ideal for rugged and adverse ambient conditions.   Universal Laser Sensor w/o Housing (OEM) Part No: E1 Desc: 7005395 Universal Laser Sensor OEM-CG Same unit as the Standard ULS but intended for System Integrators interested in space and weight savings. Ships without extrusion and rear plate resulting in significant space, weight, and cost savings.   Key Features:   • Same performance as Standard unit   • Designed for System Integration   • Weight and cost savings over Standard unit   8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 6 of 7 Laser Sensors Traffic Sensors TruSense T100 Part No: E1 Desc: 7005880 TRUSENSE T100 This single sensor can be used for a wide variety of traffic management applications. Ideal for event triggering and general data capture. Key Features:   • Easily identifies difficult targets such as liquids, non-reflective material and fast moving objects. • Makes non-contact and non-intrusive measurements without the need for frequent calibration. • Recognizes small targets at long distances, within narrow openings and from sharp angles. • Performs under temperature variations, background noise, vapor pressure and low dielectric or acoustically absorbing materials.   Speed System=T100,T200,Optics,Spacer Bar Part No: E1 Desc: 7035125 KIT,T100/T200 SET W/BRACKET Combining these two sensors changes everything, profile and classify vehicles, calculate the speed as well as time and distance between vehicles. Ideal for measuring the height, length and speed of vehicles. Key Features: • • • • Count, profile and classify vehicles Ultimate detection technology Red-light system and license plate integration Mount both the TruSense T-100 & T-200 for speed detection as well as time and distance between vehicles 8/13/2019 Measurably Superior® | ISO 9001:2008 Certified | Awarded 66 Patents Worldwide   6912 South Quentin St | Centennial, Colorado 80112 USA | 1.303.649.1000 [PHONE] | 1.303.649.9710 [FAX] www.lasertech.com 7 of 7
7006800 价格&库存
很抱歉,暂时无法提供与“7006800”相匹配的价格&库存,您可以联系我们找货
