7125-06250875-71
7125-06250875-71
    LEADERTECH
    .125" T X .65" ID X .875" OD KNI
7125-06250875-71 数据手册
Product Profile 00435 EMI/RFI Board, Enclosure, Cable Shielding & Thermal Solutions Applications • Antenna seals • Connector seals • Gland rings • Grounding washers Does not provide weather or environment sealing Mesh Gaskets Benefits Mesh gaskets are constructed of knitted mesh wire. The metal mesh material can be SnCuFe (tin-plated copper-clad steel), Monel (nickel-copper alloy) or aluminum. The most common wire materials are Monel, which combines excellent EMI/RFI protection, high resistance to oxidation, high tensile strength and resiliency, and SnCuFe, which offers best shielding performance at lower frequencies, especially with respect to magnetic fields. Aluminum mesh is occasionally used when the mating surfaces are aluminum. Gaskets can be ordered to specific ID, OD and thickness as needed. 7XXX Thickness Where: .125 = 7125 - XXXX Inner Diameter Where: .500 = 0500 XXXX Outer Diameter Where: 1.250 = 1250 XX - Material Code Material Code Material Description 71 0.0045” diameter tin plated copper clad steel wire per ASTM B520 72 0.0045” diameter monel wire per QQ-N-281 73 0.0050” diameter 5056 aluminum wire per AMS-4182 Example: • Excellent EMI shielding and grounding properties • Extreme temperature environments Materials • SnCuFe (Tin plated, copper-clad, steel wire) • Monel Wire (Copper-nickel alloy) • Aluminum Wire Standard Thicknesses • • • • • • .032” .062” .093” .125” .156” .187” • .250” 1) 0.125” thick x 0.250” ID x 1.000 OD made from monel wire: 7125-02501000-72 2) 0.063” thick x 0.500” ID x 1.750” OD made tin plated steel wire: 7063-05001750-71 EA MG M e sh Gasket s Global EMI Shielding Technology Center 12420 Race Track Rd., Tampa, Florida 33626 866.TECH.EMI (866.832.4364) t 813.855.6921 f 813.855.3291 STATEMENT OF LIEU OF WARRANTY: All technical information and data in this document is based on tests and is believed to be accurate and reliable. Nevertheless, since the products described herein are not provided to conform with mutually accepted specifications and the use thereof is unknown, the manufacturer and seller of the products do not guarantee results, freedom from patent infringement, or suitability of the products for any application thereof. The manufacturer and seller of the products described in this document will provide all possible technical assistance and will replace any products proven defective. No statement or recommendations made by the manufacturer or seller not contained herein shall have any force of effect unless in conformity with an agreement signed by an officer of the seller and manufacturer. Product testing by the purchaser is recommended in order to confirm expected results. www.LeaderTechInc.com Copyright© Leader Tech, Inc. 2018
7125-06250875-71 价格&库存
很抱歉,暂时无法提供与“7125-06250875-71”相匹配的价格&库存,您可以联系我们找货
