TC-01-MINI
TC-01-MINI
    LEADERTECH
    MINI TECH CLIP
TC-01-MINI 数据手册
Product Profile 00433 The Leading Edge in EMI Shielding Technology Applications & Benefits PCB Tech Clip Mini – P/N TC-01 Mini The Tech Clip is an EMI board shield clip which provides a cost effective alternative to using a 2-piece shielding solution and allows for EMI shield placement on a PCB without post soldering. The Tech Clip eliminates the need for hand soldering, as the parts are delivered in tape & reel packaging and are compatible with high speed automated placement equipment. The Tech Clip allows for easy shield removal and replacement for PCB rework or maintenance, and saves money on PCB costs by eliminating the need for through holes. .072in 1.83mm .264in The Leading Edge in EMI Shielding Technology 6.71mm .000 .004in+.003 0 0.10mm-0.08 .072in 1.83mm 2X .310 5X R.025in 0.64mm .035in 0.90mm .051in 1.29mm • Available Immediately through Distribution • 2-4 Weeks Lead Time for Large Orders (No Stock) • Ships Next Day if Parts are In-Stock • FREE samples available upon request. Additional Products = + 000 .006 - .005 2X .137 2X .088 2X .090 =.089 .105 Material Availability .035in 0.90mm RECOMMENDED SOLDER PAD SIZE (.264[6.70] X .035 [0.90]) Allows for 1-Piece EMI/RFI Shielding on PCBs with easy shield removal/ replacement Universal clip with spring contact retention fingers compatible with .006” - .008” thick shielding materials Suitable for Automated Placement with Circular Pick Spot Tape & Reel Packaging Saves $$$ on PCB costs .006” Thick Pre-Tin Plated Phos. Bronze .204in 5.18mm .264in 6.70mm • • • • • .105 Also Available in larger PCB Tech Clip (.310 in length) Quick turn, low cost, standard and custom covers available. Contact our sales team for available options. PTCM EA P C B T e c h c li p Mi ni LT LOGO & P/N (ETCHED/STAMPED) CENTERD FAR SIDE Global EMI Shielding Technology Center 5.000 12420 Race Track Rd., Tampa, Florida 33626 866.TECH.EMI (866.832.4364) t 813.855.6921 f 813.855.3291 ETCH LINES (TYP) NEAR SIDE STATEMENT OF LIEU OF WARRANTY: All technical information and data in this document is based on tests and is believed to be accurate and reliable. Nevertheless, since the products described herein are not provided to conform with mutually accepted specifications and the use thereof is unknown, the manufacturer and seller of the products do not guarantee results, freedom from patent infringement, or suitability of the products for any application thereof. The manufacturer and seller of the products described in this document will provide all possible technical assistance and will replace any products proven defective. No statement or recommendations made by the manufacturer 5.000 or seller not contained herein shall have any force of effect unless in conformity with an agreement signed by an officer of the seller and manufacturer. Product testing by the purchaser is recommended in order to confirm expected results. www.LeaderTechInc.com Copyright© Leader Tech, Inc. 2015
TC-01-MINI 价格&库存
很抱歉,暂时无法提供与“TC-01-MINI”相匹配的价格&库存,您可以联系我们找货
TC-01-MINI
  • 1+3.693671+0.47532
  • 10+2.5706710+0.33081
  • 25+2.2924225+0.29500
  • 100+1.98245100+0.25512
  • 250+1.83458250+0.23609
  • 500+1.74582500+0.22466
  • 1000+1.672501000+0.21523
库存:24251
TC-01-MINI
  • 2500+1.595222500+0.20529
  • 5000+1.548625000+0.19929
  • 7500+1.525287500+0.19628
  • 12500+1.4994312500+0.19296
  • 17500+1.4843217500+0.19101
  • 25000+1.4697925000+0.18914
库存:24251
TC-01-MINI
  • 1+4.002371+0.51505
  • 10+2.7825010+0.35807
  • 25+2.4814725+0.31933
  • 100+2.14617100+0.27618
  • 250+1.98603250+0.25558
  • 500+1.88997500+0.24321
  • 1000+1.810591000+0.23300
库存:24251
TC-01-MINI
    • 38+2.2240438+0.28620
    • 186+1.48269186+0.19080
    库存:2000
