9100-0002-94
9100-0002-94
    LEADERTECH
    RF 屏蔽 屏蔽,单体式 4.000"(101.60mm) X 4.000"(101.60mm) 通风孔,按样式排列
9100-0002-94 数据手册
Product Profile 00438 EMI/RFI Board, Enclosure, Cable Shielding & Thermal Solutions Global EMI Shielding Technology Center 12420 Race Track Rd., Tampa, Florida 33626 866.TECH.EMI (866.832.4364) t 813.855.6921 f 813.855.3291 www.LeaderTechInc.com Tech Vent EMI/RFI Vent Panels - For Distribution Only EMI/RFI Board, Enclosure, Cable Shielding & Thermal Solutions Leader Tech’s low cost EMI vent panels are the perfect solution to shield openings for heating and ventilation against electromagnetic interference. The Tech Vent EMI vent panels are constructed with aluminum honeycomb to maximize shielding effectiveness as well as airflow performance. These panels are manufactured with a rigid aluminum frame and pre-drilled to meet your mounting specifications. They utilize EMI gasketing as well as weather sealing material for grounding to an enclosure and providing environmental protection. The panels can also be plated in a variety of finishes to improve shielding, corrosion resistance, and galvanic compatibility. MATERIAL CODE HONEYCOMB FRAME PLATING EMI GASKET -94 ALUMINUM 5052, 1/8 CELL, 4.5 DENSITY (0.001 THICK) PER AMS-C-7438 0.062” ALUMINUM 6063 PER ASTM B221 CHROMATE FINISH PER ASTM B449, CLASS 2, RoHS Cu/Ni RIPSTOP FABRIC OVER PU FOAM CORE -95 ALUMINUM 5052, 1/8 CELL, 4.5 DENSITY (0.001 THICK) PER AMS-C-7438 0.062” ALUMINUM 6063 PER ASTM B221 MATTE TIN PER ASTM B545, CLASS B Cu/Ni RIPSTOP FABRIC OVER PU FOAM CORE -95SN ALUMINUM 5052, 1/8 CELL, 4.5 DENSITY (0.001 THICK) PER AMS-C-7438 0.062” ALUMINUM 6063 PER ASTM B221 BRIGHT TIN PER ASTM B545, CLASS B Cu/Ni RIPSTOP FABRIC OVER PU FOAM CORE -96 ALUMINUM 5052, 1/8 CELL, 4.5 DENSITY (0.001 THICK) PER AMS-C-7438 0.062” ALUMINUM 6063 PER ASTM B221 NICKEL PER ASTM B689, CLASS 5 Cu/Ni RIPSTOP FABRIC OVER PU FOAM CORE Global EMI Shielding Technology Center 12420 Race Track Rd., Tampa, Florida 33626 866.TECH.EMI (866.832.4364) t 813.855.6921 f 813.855.3291 STATEMENT OF LIEU OF WARRANTY: All technical information and data in this document is based on tests and is believed to be accurate and reliable. Nevertheless, since the products described herein are not provided to conform with mutually accepted specifications and the use thereof is unknown, the manufacturer and seller of the products do not guarantee results, freedom from patent infringement, or suitability of the products for any application thereof. The manufacturer and seller of the products described in this document will provide all possible technical assistance and will replace any products proven defective. No statement or recommendations made by the manufacturer or seller not contained herein shall have any force of effect unless in conformity with an agreement signed by an officer of the seller and manufacturer. Product testing by the purchaser is recommended in order to confirm expected results. Product Profile 00438 EMI/RFI Board, Enclosure, Cable Shielding & Thermal Solutions Tech Vent EMI/RFI Vent Panels 9100-XXXX-XX Applications Honeycomb Area No. of Fastening Holes Hole Spacing Black = inches Blue = mm Part Number W L A B C D E F W Side L Side 3.00 76.20 2.00 50.80 2.00 50.80 1.25 31.75 1.25 31.75 - - - - 1 1 9100-0002-XX 4.00 101.60 4.00 101.60 3.00 76.20 3.00 76.20 1.75 44.45 1.75 44.45 - - - - 1 1 9100-0003-XX 4.00 101.60 12.00 304.80 3.00 76.20 11.00 279.40 1.75 44.45 1.25 31.75 - - 3.00 76.20 1 4 65 9100-0004-XX 5.00 127.00 5.00 127.00 4.00 101.60 4.00 101.60 2.25 57.15 0.75 19.05 - - 3.00 76.20 1 2 60 9100-0005-XX 5.00 127.00 7.00 177.80 4.00 101.60 6.00 152.40 2.25 57.15 1.50 38.10 - - 3.50 88.90 1 2 6.00 152.40 5.00 127.00 5.00 127.00 1.00 25.40 1.00 25.40 3.50 88.90 3.50 88.90 2 2 9100-0007-XX 6.00 152.40 18.00 457.20 5.00 127.00 17.00 431.80 1.00 25.40 1.25 31.75 3.50 88.90 3.75 95.25 2 5 9100-0008-XX 7.00 177.80 7.00 177.80 6.00 152.40 6.00 152.40 1.50 38.10 1.50 38.10 3.50 88.90 3.50 88.90 2 2 9100-0009-XX 7.00 177.80 14.00 355.60 6.00 152.40 13.00 330.20 1.50 38.10 1.50 38.10 3.50 88.90 3.50 88.90 2 4 9100-0010-XX 8.00 203.20 8.00 203.20 7.00 177.80 7.00 177.80 2.00 50.80 0.75 19.05 3.50 88.90 3.00 76.20 2 3 9100-0011-XX 8.00 203.20 16.00 406.40 7.00 177.80 15.00 381.00 0.75 19.05 1.25 31.75 3.00 76.20 3.25 82.55 3 5 9100-0012-XX 10.00 254.00 10.00 254.00 9.00 228.60 9.00 228.60 1.25 31.75 1.25 31.75 3.50 88.90 3.50 88.90 3 3 9100-0013-XX 10.00 254.00 18.00 457.20 9.00 228.60 17.00 431.80 1.25 31.75 1.25 31.75 3.50 88.90 3.75 95.25 3 5 9100-0014-XX 12.00 304.80 12.00 304.80 11.00 279.40 11.00 279.40 1.25 31.75 1.25 31.75 3.00 76.20 3.00 76.20 4 4 9100-0015-XX 12.00 304.80 24.00 609.60 11.00 279.40 23.00 584.20 1.25 31.75 1.25 31.75 3.00 76.20 3.50 88.90 4 7 Part Number Example for part : 9100-0001-94 9100 Series (9100) - 0001 Length and Width (3x3) - • MRI Room Shielding 80 76.20 152.40 • Ventilation openings 85 3.00 6.00 • Server Racks 90 9100-0001-XX 9100-0006-XX • Fans Vertical Antenna Polarity • Military applications 75 • Telecommunications Hardware equipment dB 70 Material Characteristics 55 50 45 • Frames are made from aluminum extrusion 40 35 0.1 1 10 1000 100 10000 Frequency (MHz) 9100-0006-94 Chromate with FSG 9100-0006-95 Tin with FSG 9100-0006-96 Nickel with FSG Performance Horizontal Antenna Polarity 94 • See attached test data 90 85 Material Code (Chromate Finish) Availability 80 Custom sizes are available. Contact Leader Tech Engineering to discuss custom sizes. Visit our website to view our distribution partners. 75 dB 65 60 55 .50 50 45 40 .50 35 100 1000 10000 Frequency (MHz) .625 FRAME • Low cost EMI Gaskets made with Fabric Shielding Gasket 70 EMI GASKET .10 • Honeycomb is made from aluminum .50 HONEYCOMB 9100-0006-94 Chromate with FSG 9100-0006-95 Tin with FSG 9100-0006-96 Nickel with FSG EA TVP TECH Vent Panels www.LeaderTechInc.com Copyright© Leader Tech, Inc. 2019
9100-0002-94 价格&库存
很抱歉,暂时无法提供与“9100-0002-94”相匹配的价格&库存,您可以联系我们找货
    库存:171
    9100-0002-94
      库存:10000
