154660-224
154660-224
    JOHNSON
    连续 占空比螺线管 封闭框架(拉),管状 型 行程 12.4VDC 面板安装
154660-224 数据手册
Guaranteed efficiency, reliability, AND customizable to YOUR specs. NEW 1-1/2 x 2-1/2 Tubular Solenoid • Longer Stroke • Higher Cycles • Better Mounting • Push/Pull Functionality Applications for use include sorting machines and laboratory equipment. NEW Brass STA Model Sleeve Model Stroke to 1.5 inches Up to 25 Million Cycles Built in Air Gap Spacer RoHS Compliant UL Listed Coil Components Ease of Mounting Push & Pull Models DIMENSIONS     Size 150 STA® Pull Tubular Solenoids 1-1/2” Dia. x 2-1/2”            Inches (mm) All solenoids are illustrated in energized state All specifications subject to change without notice.                                                                     Size 150 STA® Push Tubular Solenoids 1-1/2” Dia. x 2-1/2”                                             innovating motion https://us.JohnsonElectric.com/solenoids/STA    Size 150 1-1/2” Dia. x 2-1/2” STA® Pull and Push Tubular Solenoids SPECIFICATIONS 1000 VRMS Recommended Minimum Heat Sink Maximum watts dissipated by solenoid are based on an unrestricted flow of air at 20°C, with solenoid mounted on the equivalent of an aluminum plate measuring 6” square by 1/8” thick Coil Resistance ±5% tolerance Holding Force Push: Pull: TYPICAL FORCE @ 20°C Force values for reference only 25.0 (111.2) 100% Duty Cycle 17W 17.7 lbs (78.9 N) at 20°C 14.5 lbs (64.50 N) at 20°C Weight Push: 17.1 oz (484.4g) Pull: 17 oz (481.8g) Plunger Weight Push: Pull: Dimensions Ø1.50” x 2.50” L 50% Duty Cycle 34W 20.0 (89.0) Force - lbs (N) Dielectric Strength 25% Duty Cycle 68W 10% Duty Cycle 170W 15.0 (66.7) 10.0 (44.5) 5.0 (22.2) 3.4 oz (95.5 g) 4.04 oz (114.5 g) 0.0 0 0.20 (5.08) 0.40 (10.16) 0.60 (15.24) 0.80 (20.32) 1.00 (25.40) 1.20 (30.48) 1.40 (35.56) 1.60 (39.37) Stroke - in (mm) HOW TO ORDER PART NUMBER TYPICAL FORCE (LBS) Pull Model Push Model Duty Cycle Voltage Coil Resistance (Ω) ± 5% Power (W) 154660-221 154661-221 Intermittent 12 VDC 2.34 61.5 10.25 6.00 2.63 154660-224 154661-224 Continuous 12 VDC 9.30 15.5 3.75 1.75 0.50 154660-224 154661-224 Intermittent 24 VDC 9.30 61.9 10.25 6.00 2.63 154660-227 154661-227 Continuous 24 VDC 36.90 15.6 3.75 1.75 0.50 0.25” Stroke .50” Stroke 1.00” Stroke Continuous Duty = 100% “On” Time Intermittent Duty = 25% “On Time / 75% “Off” time When ordering please refer to Part Number as listed above. https://us.JohnsonElectric.com/solenoids/STA innovating motion
154660-224 价格&库存
很抱歉,暂时无法提供与“154660-224”相匹配的价格&库存,您可以联系我们找货
  • 1+854.793161+110.19933
  • 10+761.1971410+98.13300
  • 25+726.8085125+93.69964
  • 50+701.8127250+90.47720
  • 100+677.66677100+87.36432
