Guaranteed efficiency, reliability, AND customizable to YOUR specs.
NEW 1-1/2 x 2-1/2 Tubular Solenoid
• Longer Stroke
• Higher Cycles
• Better Mounting
• Push/Pull Functionality
Applications for use include sorting machines
and laboratory equipment.
NEW
Brass
STA Model Sleeve Model
Stroke to 1.5 inches
Up to 25 Million Cycles
Built in Air Gap Spacer
RoHS Compliant
UL Listed Coil Components
Ease of Mounting
Push & Pull Models
DIMENSIONS
Size 150 STA® Pull Tubular Solenoids
1-1/2” Dia. x 2-1/2”
Inches (mm)
All solenoids are illustrated in
energized state
All specifications subject to
change without notice.
Size 150 STA® Push Tubular Solenoids
innovating motion
https://us.JohnsonElectric.com/solenoids/STA
Size 150 1-1/2” Dia. x 2-1/2”
STA® Pull and Push Tubular Solenoids
SPECIFICATIONS
1000 VRMS
Recommended
Minimum Heat Sink
Maximum watts dissipated by
solenoid are based on an
unrestricted flow of air at 20°C,
with solenoid mounted on the
equivalent of an aluminum plate
measuring 6” square by 1/8” thick
Coil Resistance
±5% tolerance
Holding Force
Push:
Pull:
TYPICAL FORCE @ 20°C
Force values for reference only
25.0
(111.2)
100% Duty Cycle 17W
17.7 lbs (78.9 N) at 20°C
14.5 lbs (64.50 N) at 20°C
Weight
Push: 17.1 oz (484.4g)
Pull:
17 oz (481.8g)
Plunger Weight
Push:
Pull:
Dimensions
Ø1.50” x 2.50” L
50% Duty Cycle 34W
20.0
(89.0)
Force - lbs (N)
Dielectric Strength
25% Duty Cycle 68W
10% Duty Cycle 170W
15.0
(66.7)
10.0
(44.5)
5.0
(22.2)
3.4 oz (95.5 g)
4.04 oz (114.5 g)
0.0
(5.08)
0.40
(10.16)
0.60
(15.24)
0.80
(20.32)
1.00
(25.40)
1.20
(30.48)
1.40
(35.56)
1.60
(39.37)
Stroke - in (mm)
HOW TO ORDER
PART NUMBER
TYPICAL FORCE (LBS)
Pull Model
Push Model
Duty Cycle
Voltage
Coil Resistance
(Ω) ± 5%
Power (W)
154660-221
154661-221
Intermittent
12 VDC
2.34
61.5
10.25
6.00
2.63
154660-224
154661-224
Continuous
12 VDC
9.30
15.5
3.75
1.75
0.50
154660-224
154661-224
Intermittent
24 VDC
9.30
61.9
10.25
6.00
2.63
154660-227
154661-227
Continuous
24 VDC
36.90
15.6
3.75
1.75
0.50
0.25” Stroke .50” Stroke 1.00” Stroke
Continuous Duty = 100% “On” Time
Intermittent Duty = 25% “On Time / 75% “Off” time
When ordering please refer to Part Number as listed above.
innovating motion
很抱歉,暂时无法提供与“154661-227”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+793.365321+102.63392
- 10+706.5254110+91.39985
- 25+674.6137725+87.27159
- 50+651.4181950+84.27089
- 100+629.00160100+81.37096
