Ledex® Box Frame Size B12P
Part Number: B12P – XXX – B – 3
All Products are RoHS Compliant
Select from Performance Chart Below
Specifications
Operation
Dielectric Strength
Continuous Duty Cycle
Intermittent Duty Cycle
Holding Force
Spring Force
Coil Insulation
Coil Termination
Plunger Weight
Total Weight
Push
500 VRMS for one second
100% at 20°C ambient temperature
See Below
7.7 oz. (2.1N) at 20°C
.575 oz (.160N) Energized
Class “A”: 105°C max
10” PVC lead wires
0.05 oz
0.30 oz
Performance
Maximum Duty Cycle
Maximum ON Time (sec)
when pulsed continuously
for single pulse
Watts (@ 20°C)
Ampere Turns (@ 20°C)
100%
50%
25%
10%
84
11
2
120
34
8
1.3
2.6
5.2
13
178
251
355
561
Coil Data
Part Number
Resistance
(@20°C)
Ref. #
Turns
VDC
(Nom)
VDC
VDC VDC
(Nom) (Nom) (Nom)
B12P-258 -B-3
6.92
417
3
4.24
6.0
9.5
B12P-255 -B-3
27.7
824
6
8.5
12
B12P-256 -B-3
62.3
1184
9
13
18
19
28.5
B12P-254 -B-3
110.8
1632
12
17
24
38
B12P-253 -B-3
443.1
3336
24
34
48
76
NOTES:
1.
2.
3.
All data is typical.
Force testing is done with the solenoid in the
horizontal position.
All data reflects operation with no heatsink.
All specification subject to change without notice.
Ledex® Solenoids
www.johnsonelectric.com
How to Order:
Select the part number from the table provided. (For
example, to order a 25% duty unit rated at 48 VDC,
specify B12P-253-B-3
Please see www.johnsonelectric.com for a list of our
products available through distribution.
Force values for reference only.
1.937.454.2345
Fax: 1.937-898-8624
Dimensions
Ledex® Solenoids
Inches (mm)
All solenoids are shown in energized state
1.937.454.2345
Fax: 1.937-898-8624
很抱歉,暂时无法提供与“B12P-253-B-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+362.10032500+46.82942
