CA13313_LAURA-SS-WAS
    LEDIL(芬兰)
    LENS ASSEMBLY LAURA
CA13313_LAURA-SS-WAS 数据手册
PRODUCT DATASHEET CA13313_LAURA-SS-WAS LAURA-SS-WAS Asymmetric beam for wall-washing optimized for Nichia 19. Assembly with white holder and installation tape. TECHNICAL SPECIFICATIONS: Dimensions 21.6 mm Height 13.1 mm Fastening tape ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material LAURA-SS-WAS Single lens PMMA LAURA-HLD-N19-WHT Holder PC ROSE-TAPE Tape PU tape Colour Finish ORDERING INFORMATION: Component CA13313_LAURA-SS-WAS » Box size: Qty in box Single lens 1440 MOQ MPQ 360 Last update: 07/03/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 0.0 1/4 PRODUCT DATASHEET CA13313_LAURA-SS-WAS Last update: 07/03/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/4 PRODUCT DATASHEET CA13313_LAURA-SS-WAS PHOTOMETRIC DATA (MEASURED): LED NCSxx19A FWHM Asymmetric Efficiency 92 % Peak intensity 10.300 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM Asymmetric Efficiency 90 % Peak intensity 13.100 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM Asymmetric Efficiency 93 % Peak intensity 9.500 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/03/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/4 PRODUCT DATASHEET CA13313_LAURA-SS-WAS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 07/03/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/4
CA13313_LAURA-SS-WAS 价格&库存
很抱歉,暂时无法提供与“CA13313_LAURA-SS-WAS”相匹配的价格&库存,您可以联系我们找货
