195205-227
195205-227
    JOHNSON
    间断 占空比螺线管 封闭框架(推),管状 型 0.625"(15.88mm) 行程 12VDC 面板安装
195205-227 数据手册
STA® Push DC Tubular Solenoid Model 75 Size: ¾” OD X 1 ½” L ALL PRODUCTS ARE RoHS COMPLIANT Solenoid shown energized with plunger fully seated Supplied with hex nut shipped loose Spring kits available (consult factory) Part No. 195205-227 195205-230 195205-230 195205-233 Duty Cycle Intermittent Continuous Intermittent Continuous Voltage 12 VDC 12 VDC 24 VDC 24 VDC Resistance (Ω) ± 5% 5.27 20.70 20.70 83.50 Max On Time 25 Sec ∞ 25 Sec ∞ Power (W) 28 7.0 28 7.0 Current (A) 2.28 0.58 1.16 0.29 Continuous Duty = 100% “On” Time Intermittent Duty = 25% “On” Time When ordering please refer to Part No. as listed above Please consult factory for custom configurations and other pole face angles Stroke (in.) Continuous Duty Intermittent Duty 0.060 22.0 50.0 Typical Push Force (oz.) 0.125 0.250 0.375 0.500 11.2 5.0 3.2 1.6 36.8 22.0 14.0 9.6 Additional Specifications: Dielectric Strength: Recommended Heat Sink: Total Unit Weight: Plunger Weight: Ledex® Holding Force (oz.) 0.625 N/A 7.2 0.750 N/A N/A 1.000 N/A N/A 45.6 N/A 1000 VRMS Maximum watts dissipated by solenoid are based on an unrestricted flow of air at 20°C, with solenoid mounted to the equivalent of an aluminum plate measuring 3” square by 1/8” thick. 3.08 oz. / 87.3 g 0.53 oz. / 15.0 g sales@johnsonelectric.com
195205-227 价格&库存
很抱歉,暂时无法提供与“195205-227”相匹配的价格&库存,您可以联系我们找货
  • 4+205.515654+26.58659
库存:157
