FFS.F7.125.LCL23
FFS.F7.125.LCL23
    LEMO(雷莫)
    连接器 触点 用于
FFS.F7.125.LCL23 数据手册
® ® Electronic & Fibre Optic Connectors MINIATURE F7 CONTACT FOR MULTI & HYBRID FIBRE OPTIC CONNECTORS ® ® MINIATURE FIBRE-OPTIC F7 CONTACT FOR MULTIFIBRE OR MIXED OPTICAL/ELECTRICAL OF THE 1K-5K AND 1B-5B SERIES In addition to the existing F2 fibre optic contact shown in our catalogue of Fibre-Optic connectors No 5, the B and K series can now also be fitted with the new miniature F7 contact. The main benefits of using this contact are: – Reduced size allowing increased contact density. As an example, a 4-channel fibre optic connector is now possible in series 3K/3B. – Use of industry standard 1.25 mm diameter ferrule and polishing processes. Contact design is based on the well-proven F2. Contacts fit onto buffered fibres or semitight jacket cables up to 2 mm in diameter. u a l i ty S dQ ie Cer ti tem ys f This brochure shows only a sample of the available models of connectors. Refer to our catalogue No 5 for more detailed information of the full range of LEMO fibre optic connectors. Refer also to catalogue No 5 for accessories or tools specific to the electrical contacts used in hybrid connectors. IS O 9001 Reg. No. 10472 - 03 5 Fibre Optic Connectors No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserve the right at all times to modify and improve specifications without any notification. 2 Printed in Switzerland, November 2003 Pdf updated March 2011 www.lemo.com ® ® F7 Fibre Optic Contact Introduction The F7 type contact is designed to fit multi fibre connectors or mixed fibre optical/electrical connectors from 1B to 5B, 1K to 5K series. The design is based on the well proven F2 contact. Its main features are as follows: – Ceramic ferrules diameter 1.25 mm – Simple and fast polishing ensuring the physical contact of the fibre end face – After mounting on the cable, the contact is very easily installed in the main connector insulator, the particular shape of the contact body retains it in the insulator – Single type of cable assembly, regardless of connector shell used – The alignment tube can be easily removed in order to clean the fibre end face. This contact makes it possible to use single fibre cables with single-mode or multi-mode fibres of the following sizes; 9/125, 50/125 and 62.5/125. Part Section Showing Internal Components Female contact 4 1 3 5 2 2 3 1 4 Male contact 1 body with holder 1 body with holder 2 ferrule with holder 3 spring 2 ferrule with holder 4 crimp ferrule 3 spring 5 alignment tube 4 crimp ferrule with support Technical Characteristics Material and Treatment Component Body Ferrule Holder Crimp holder Spring Crimp ferrule Support Alignment tube Optical Material PEEK Ceramic Alloy CuNiZn Brass Stainless steel Cu 99 Alloy CuNiZn Ceramic Surface treatment (µm) Cu Ni without treatment without treatment without treatment 0.5 3 without treatment 0.5 3 without treatment without treatment Characteristic Value Standard Method Average insertion loss fibre 9/125 µm 0.18 dB IEC 61300-03-34 Method 2 Average insertion loss fibre 50/125 µm 0.25 dB IEC 61300-03-34 Method 2 Return loss fibre 9/125 µm (UPC) ≥45 dB IEC 61300-03-06 Coupler Method Return loss fibre 9/125 µm (Hand polish) >25 dB IEC 61300-03-06 Coupler Method Mechanical and Environmental Characteristic Value Standard Mating durability Damp heat steady state High temperature Low temperature Cable retention Vibration (3 axes) Change of temperature Temperature/humidity > 1000 cycles up to 93 % RH at 40°C +85°C -40°C 100 N 100 to 2000 Hz, 2 hrs -40 to +75°C -10 to +65°C at 93 % RH IEC 61300-02-02 IEC 61300-02-19 IEC 61300-02-18 IEC 61300-02-17 IEC 61300-02-04 – IEC 61300-02-22 IEC 61300-02-21 www.lemo.com 3 ® ® Part Number Example F7 contacts are designed in 2 different lengths: – the short version for 1B/K, 2B/K and 3B/K series, code E. – the long version for 4B/K and 5B/K series, code L. FFS F7 125 L C E 23 = Male contact Model: FFS PSS = Female contact FO Contact type: F7 Cable ø: 23 = 0.25 to 2.0 mm Fibre type: (page 3) Contact Length: Body: L = PEEK Ferrule material: C = Zirconia ceramic E = for 1B/K, 2B/K, 3B/K L = for 4B/K, 5B/K FFS.F7.125.LCE23 = Male F7 type fibre optic contact, ferrule bore diameter of 125 µm, PEEK body, Zirconia ceramic ferrule, contact length for 1B/K, 2B/K or 3B/K series, for cable with diameter max = 2.0 mm. Model - FO Contact Type ø 1.25 FFS.F7 Male F7 Fibre Optic Contact Reference ø 3.3 ~L Dimensions (mm) Model Series L FFS.F7 FFS.F7 1B, 1K, 2B, 2K, 3B, 3K 4B, 4K, 5B, 5K 25.8 32.8 ø 3.3 ~L 4 ø 1.25 PSS.F7 Female F7 Fibre Optic Contact Reference 8.2 Dimensions (mm) Model Series L PSS.F7 PSS.F7 1B, 1K, 2B, 2K, 3B, 3K 4B, 4K, 5B, 5K 25.8 32.8 www.lemo.com ® ® Fibre Type The choice of the ferrule hole diameter is dependent upon the fibre cladding size. LEMO offers a range of ferrule hole diameters to suit the users’ specific requirements. ø Core/Cladding (µm) Reference Ferrule hole diameter (µm) Note 1) 125 ● 126 ● 128 ● 125 9/125 50/125 62.5/125 126 128 ● First choice alternative ● Special order alternative Accessories PSS Alignment device for F7 fibre optic contact 8.2 ø 3.2 Part number PSS.F7.290.NZZ Note: Alignment device should be ordered as replacement item. FGG-EGG Insulators male FO Contact Type F7 female Insulator part number Male contact Female contact 1B/1K 92A FGG.1B.302.FL EGG.1B.402.FL 2B/2K 03A 93B FGG.2B.302.FL FGG.2B.324.FL EGG.2B.402.FL EGG.2B.424.FL 3B/3K 03C 95B FGG.3B.304.FL FGG.3B.344.FL EGG.3B.404.FL EGG.3B.444.FL 4B/4K 03G 03H 97B FGG.4B.308.FL FGG.4B.309.FL FGG.4B.362.FL EGG.4B.408.FL EGG.4B.409.FL EGG.4B.462.FL 5B/5K 03Q 03V FGG.5B.316.FL FGG.5B.321.FL EGG.5B.416.FL EGG.5B.421.FL www.lemo.com Insulators for 1B-5B and 1K-5K series vary according to the fibre optic contact type. For the new F7 contact insulators are: 5 ® ® 1K-5K Series The new F7 fibre optic contact has been designed to work in the 1K-5K series. The main features of these series are as follows: – Security of the LEMO Push-Pull self-latching system – Specially designed for outdoors applications. All these models are waterproof when mated and reach a protection index of IP 66-IP 68, according to the IEC 60529 standard – Protection against accidental contamination or damage to the fibre end face because the ferrules are recessed within the connector shell – The alignment key (G, A…F, L and R) ensures excellent repeatability of performance during frequent matings – A choice of configurations of multi fibre or mixed optical/electrical contacts – The new miniature F7 contact allows hybrid configuration in the 1K series and multi fibre up to 21 channels in the 5K series. The 1K-5K series consists of ten models which will accept outer cable diameters ranging from 2.6 mm to 23.5 mm. Interconnections Straight plug FGG Fixed plugs Free socket PHG Fixed sockets EGG Fixed sockets EEG* FXG* PKG* EBG* FMG* PEG* EDG* Model Description EBG Fixed socket with square flange, key (G) or keys (A…F, L and R), four holes fixing EDG Fixed socket with square flange, key (G) or keys (A…F, L and R), protruding shell and earthing tag, screw fixing EEG Fixed socket, nut fixing, key (G) or keys (A…F, L and R) (back panel mounting) EGG Fixed socket, nut fixing, key (G) or keys (A…F, L and R) FGG Straight plug, key (G) or keys PHG Free socket, key (G) or keys (A…F, L and R), cable adapter (A…F, L and R), cable adapter and nut for fitting a bend relief and nut for fitting a bend relief FMG Fixed plug with round flange, four holes PKG Fixed socket, nut fixing, fixing, key (G) or keys (A…F, L and R), key (G) or keys (A…F, L and R), cable adapter and nut for fitting a bend relief cable adapter and nut for fitting a bend relief FXG Fixed plug with round flange, four holes fixing, key (G) or keys (A…F, L and R) PEG Fixed socket, nut fixing, key (G) or keys (A…F, L and R), cable adapter and nut for fitting a bend relief * Not show in this catalogue. (back panel mounting) Refer to our catalogue No 5. Certain models and certain key-ways may not be available in all series. Please consult us. 6 www.lemo.com ® ® Part Number Example FGG 3K 03C C L A Variant: see note 1) T 76 Z Model: (see examples below) Cable ø: (page 9) Series: (see examples below) Cable fixing type: T = cable adapter Type: (page 8) LV Contact Type: (page 9) Housing: (C = chrome plated brass) Insulator: L = PEEK FGG.3K.03C.CLAT76Z = Straight plug with key (G), 3K series, multi-fibre type to accept 4 F7 type fibre optic contacts, chrome-plated brass housing, PEEK insulator, cable fixing type T for 7.5 mm diameter cable, and nut for fitting a bend relief. Connectors are delivered without fibre optic contacts. F7 fibre optic contacts must be ordered separately according to size and type of fibre (see pages 1 to 3). Note: 1) The «Variant» position in the reference is used to indicate the presence of a collet nut for fitting the bend relief. The bend relief must be ordered separately. Sample Models FGG Straight plug, key (G) or keys (A…F, L and R), cable adapter and nut for fitting a bend relief Reference L max ¿A M max S2 Dimensions (mm) Model Series A FGG FGG FGG FGG FGG 1K 2K 3K 4K 5K 13 16 19 25 38 L M S2 92 78.0 9 101 85.0 12 109 89.0 15 131 110.5 19 160 135.0 30 Note: The overall length dimension is with Desmopan bend relief PHG Free socket, key (G) or keys (A…F, L and R), cable adapter and nut for fitting a bend relief Reference ¿A L max S2 Dimensions (mm) Model Series A L S2 PHG PHG PHG PHG PHG 1K 2K 3K 4K 5K 15 19 23 29 42 95.0 103.0 113.0 135.5 164.0 9 12 15 19 30 Note: The overall length dimension is with Desmopan bend relief EGG Fixed socket, nut fixing, key (G) or keys (A…F, L and R) L max M ¿A e ¿B S3 E max S1 Reference Dimensions (mm) Model Series A B e E EGG EGG EGG EGG EGG 1K 2K 3K 4K 5K 20 25 31 37 55 21.5 27.0 34.0 40.5 54.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 9 9 11 9 10 L max 1) F1 F2 31.0 31.0 35.5 37.0 40.5 41.0 41.0 42.5 41.0 42.0 M 4.5 5.0 6.0 6.5 9.0 S1 S3 14.5 18.5 22.5 28.5 42.5 19 24 30 36 – Note: 1) The overall length (L) may vary depending upon the type of electrical LV or fibre optic contact fitted. www.lemo.com 7 ® ® 1B-5B Series The new F7 fibre optic contact has been designed to work in the 1B-5B series. The main features of these series are as follows: – Security of the LEMO Push-Pull self-latching system – Protection against accidental contamination or damage to the fibre end face because the ferrules are recessed within the connector shell – The alignment key (G, A…L, Y and R) ensures excellent repeatability of performance during frequent matings – A choice of configurations of multi fibre or mixed optical/electrical contacts – The new miniature F7 contact allows hybrid configuration in the 1B series and multi fibre up to 21 channels in the 5B series. The 1B-5B series consist of fifteen models. The possible outer cable diameters range from 2.1 to 25 mm. Interconnections Straight plugs Free sockets Fixed sockets FGG Fixed sockets EGG PHG PKG* FGG* ECG* PHG* PFG* FNG* EHG* Plastic housing models Straight plugs Fixed sockets FGG* ENG* FGY* ENY* FGY* Model Description ECG Fixed socket, with two nuts, key (G) or keys (A…L and R), (back panel mounting) EGG Fixed socket, nut fixing, key (G) or keys (A…L and R) EHG Fixed socket, nut fixing, key (G) or keys (A…L and R) with visible shell ENG Fixed socket with grounding tab, nut fixing, key (G or J), PEEK outer shell ENY Fixed socket with grounding tab, nut fixing, keys (Y), PSU or PPSU outer shell FGG Straight plug, key (G) or keys (A…L and R) and cable collet FGG Straight plug, key (G) or keys (A…L) cable collet and nut for fitting a bend relief FGG Straight plug, key (G or J), cable collet, PEEK outer shell FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell and nut for fitting a bend relief FNG Straight plug, key (G) or keys (A…L and R) and cable collet with lanyard release PFG Fixed socket, with two nuts, key (G) or keys (A…L and R) and cable collet (back panel mounting) PHG Free socket, key (G) or keys (A…L and R) and cable collet PHG Free socket, key (G) or keys (A…L) and cable collet and nut for fitting a bend relief PKG Fixed socket, nut fixing, key (G) or keys (A…L and R) and cable collet * Not show in this catalogue. Refer to our catalogue No 5. Certain models and certain key-ways may not be available in all series. Please consult us. 8 www.lemo.com ® ® Part Number Example FGG 93B 2B C L Variant: see note 1) A D 72 Z Model: (see examples below) Cable ø: (page 9) Series: (see examples below) Collet type: (page 9) Type: (page 8) LV contact type: (page 9) Housing: (C = chrome plated brass) Insulator: L = PEEK FGG.2B.93B.CLAD72Z = Straight plug with key (G), 2B series, mixed type to accept 2 F7 fibre optic contact and 4 low voltage electrical contacts, chrome-plated brass housing, PEEK insulator, 4 male solder electrical contacts, type D collet system to suit a 7.0 to 6.1 mm diameter cable, and a nut for fitting a bend relief. Connectors are delivered without fibre optic contacts. F7 fibre optic contacts must be ordered separately according to size and type of fibre (see pages 1 to 3). Note: 1) The «Variant» position in the reference is used to indicate the presence of a collet nut for fitting the bend relief. The bend relief must be ordered separately. Sample Models FGG Straight plug, key (G) or keys (A…L and R) and cable collet Reference ~L ¿A ~M S2 Model Series FGG1) FGG FGG FGG FGG 1B 2B 3B 4B 5B Dimensions (mm) A L M 12 722) 612) 15 50 38 18 58 43 25 75 57 35 103 78 S1 S2 10 13 15 21 31 9 12 14 20 30 Note: 1) Models can be delivered only with «T» type of cable adapter and nut for fitting a bend relief. 2) Lengths include the bend relief. S1 PHG Free socket, key (G) or keys (A…L and R) and cable collet Reference øA ~L S2 Dimensions (mm) Model Series A L S1 S2 PHG1) PHG PHG PHG PHG 1B 2B 3B 4B 5B 12.5 16.5 19.0 24.4 34.2 69.52) 47.0 56.0 73.0 99.0 10 13 15 21 31 9 12 14 20 30 Note: 1) Models can be delivered only with «T» type of cable adapter and nut for fitting a bend relief. 2) Lengths include the bend relief. S1 EGG Fixed socket, nut fixing, key (G) or keys (A…L and R) L max Reference M øA e øB S3 E max S1 Dimensions (mm) Model Series A B e E EGG EGG EGG EGG EGG 1B 2B 3B 4B 5B 14 18 22 28 40 16 19.2 25.0 34.0 40.0 M12x1 M15x1 M18x1 M25x1 M35x1 7.5 8.5 11.5 12.0 11.0 L max 1) F1 F2 27.0 27.0 30.0 34.5 36.5 37.0 37.0 37.0 38.5 38.0 M S1 S3 1.5 1.8 2.0 2.5 3.0 10.5 13.5 16.5 23.5 33.5 14 17 22 30 – Note: 1) The overall length (L) may vary depending upon the type of electrical LV or fibre optic contact fitted. www.lemo.com 9 ® ® Types Multi fibre and Mixed fibre optic (F7 contact) + LV 2 0.9 ● ● 0.90 1.50 2B 2K 03A 2 – – – – 93B 2 4 0.7 ● ● 03C 4 – – – – 95B 4 4 0.9 ● ● 03G 8 – – – – – – – – – 03H 9 – – – – – – – – – 97B 6 2 1.6 ● ● 1.20 1.05 13 03Q 16 – – – – – – – – – 03V 21 – – – – – – – – – øA F7 Female crimp contacts 1 4 4 1 2 3 3 2 3B 3K – – 0.85 1.20 – – Rated current (A) Test voltage (kV rms)1) Contact-contact 1 Male crimp contacts Test voltage (kV rms)1) Contact-shell Crimp 92A Female solder contacts Test voltage (kV rms)1) Contact-contact Solder 1B 1K Male solder contacts Test voltage (kV rms)1) Contact-shell ø A (mm) Crimp contact Contact No Reference FO Contact Type Solder contact Fibre optic No øA Low Voltage contact Contact type 1.20 1.80 7.0 – – 0.85 1.25 – – – 6.0 – 1 1 2 4 2 4 3 3 4B 4K 5B 5K 1.20 1.05 1.00 0.80 1.30 1.30 8.0 Note: 1) Test voltage Test voltage (Ue): (measured according to the IEC 60512-2 test 4a standard). It corresponds to 75% of the mean breakdown voltage. Test voltage is applied at 500 V/s and the test duration is one minute. Operating voltage (Us): It is proposed according to the following ratio: Us = Ue 3 Caution: For a number of applications, safety requirements for electrical appliances are more severe with regard to operating voltage. This test has been carried out with a mated plug and receptacle, with power supply only on the plug end. 10 www.lemo.com ® ® Electrical Contact Contact for plug, socket, and fixed socket Contact type Ref. male solder male crimp female solder female crimp no contact A C L M Z Collets (K and B series) T type cable adapter Reference 1B 1K 2K 3K 4K 5K D and M type collets Cable ø Reference Bend relief to be used 1) Type ø max. min. T T 36 46 3.5 4.5 2.6 3.6 GMA.1B.030.D● GMA.1B.040.D● T T T 46 56 66 4.5 5.5 6.5 3.6 4.6 5.6 GMA.2B.040.D● GMA.2B.050.D● GMA.2B.060.D● T T T T T T 46 56 66 76 86 91 4.5 5.5 6.5 7.5 8.5 9.0 3.6 4.6 5.6 6.6 7.6 8.1 GMA.2B.040.D● GMA.2B.050.D● GMA.2B.060.D● GMA.3B.070.D● GMA.3B.080.D● GMA.3B.080.D● T T T T T T T T 46 56 66 76 86 96 11 13 4.5 5.5 6.5 7.5 8.5 9.5 11.5 13.5 3.6 4.6 5.6 6.6 7.6 8.6 10.6 12.6 GMA.2B.040.D● GMA.2B.050.D● GMA.2B.060.D● GMA.3B.070.D● GMA.3B.080.D● GMA.4B.010.D● 2) GMA.4B.011.D● GMA.4B.013.D● T T T T T T T T T T T T T T T T T T T 61 71 81 91 96 10 11 12 13 14 15 16 17 18 19 20 21 22 23 6.0 7.0 8.0 9.0 9.5 10.5 11.5 12.5 13.5 14.5 15.5 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 5.1 6.1 7.1 8.1 8.6 9.6 10.6 11.6 12.6 13.6 14.6 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 GMA.2B.057.R● GMA.3B.060.D● GMA.3B.070.D● GMA.3B.080.D● GMA.4B.010.D● 2) GMA.4B.010.D● GMA.4B.011.D● GMA.4B.012.D● GMA.4B.013.D● GMA.4B.013.D● heat-shrink tube 3) heat-shrink tube heat-shrink tube heat-shrink tube heat-shrink tube heat-shrink tube heat-shrink tube heat-shrink tube heat-shrink tube www.lemo.com 2B 3B 4B 5B Cable ø Type ø max. M D D D D D D 31 42 52 62 72 82 92 3.2 4.2 5.2 6.2 7.2 8.2 9.2 > 2.2 > 3.2 > 4.2 > 5.2 > 6.2 > 7.2 > 8.2 M D D D D D 52 62 72 92 10 12 5.2 6.2 7.7 9.2 10.7 11.9 > 4.2 4.9 > 6.2 > 7.7 > 9.2 > 10.7 M M M M D D D D 62 72 82 92 10 12 13 15 6.0 7.0 8.0 9.0 10.5 12.0 13.5 15.0 5.1 6.1 7.1 8.1 9.1 10.6 12.1 13.6 D D D D D D D D 11 13 15 17 19 21 23 25 11.5 13.5 15.5 17.5 19.5 21.5 23.5 25.0 9.6 11.6 13.6 15.6 17.6 19.6 21.6 23.6 min. Note: 1) The bend relief is to be ordered separately. 2) Add a short piece of heat-shrink tubing under the bend relief. 3) The heat-shrink tube is supplied. All dimensions are in millimeters. 11 ® ® Fibre Optic Tooling We offer a complete range of tools for fibre optic connector cable assembly. Some tools are specific to each fibre optic contact type. When selecting necessary tooling, make sure you identify correctly the contact type used in the selected product. DRV Complete workstation for fibre optic contact Description Comprehensive range of tools for terminating both singlemode and multi-mode fibres. Includes specific tools for F7 fibre optic contacts. Detachable termination case lid for use as polishing platform during field termination. Rugged but aesthetically pleasing termination case which is ideal for field use or in-house terminations. Curing oven and inspection microscope should be ordered separately. Part number DRV.91.CF7.PN Part Number Description Quantity Number Workstation Contents WST.BT.175.55PT WST.BR.150.8AC WST.CH.252.5SR WST.CS.125.CE WST.CO.020.52 WST.DS.290.PT DCC.91.307.5LA DCS.F7.035.PN DCS.91.G90.6E125 WST.ME.354.8R DOC.FO.CF7.0000 WST.OU.135.10SZ DCS.91.D01.LC WST.OU.452.5MN WST.PA.105.5525 WST.PA.012.AOJ WST.PA.005.AOM WST.PA.001.DIL WST.PN.210.AS WST.PN.145.AR WST.PN.103.0PG WST.PN.203.CR WST.PN.102.3CR DPE.99.003.1K WST.PL.322.5PT WST.RE.353.EPO WST.SE.305.8PH WST.TU.193.LN WST.RG.150.AZ WST.SY.135.PA WST.CS.155.AZ Plastic box Tweezers Lint-free Cloth Kevlar cutters Cotton bud (sachet of 20 pcs) Alcohol dispenser (supplied empty) Extraction tool for F7 contact Alignment device tool Microscope adapter for F7 contacts Epoxy mixer and pad Terminating instructions for F7 contacts Fibre scribe Polishing tool for F7 contacts Large cable stripper Cleaning tissues Lapping film 12µm (yellow) Lapping film 5µm (brown) Lapping film 1µm (lavander) diamond Armoured cable cutter Cable cutter Outer jacket stripper Buffer coating stripping tool Primary coat stripper Crimp tool Polishing platform Epoxy resin + safety instructions Syringe with needle # 19 & # 20 Fibre shield for F7 contacts Steel rule 6’’ (152 mm) Fibre length marking pen Scissors 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 20 20 5 1 1 1 1 1 1 1 10 10 4 1 1 1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 18 25 17 16 26 11 3 30 29 31 7 26 27 5 1 15 28 13 6 4 8 19 23 24 22 10 20 9 21 14 2 12 Note: The interior of the case is fitted with pre-formed plastic foam to provide secure storage of the tools. 12 www.lemo.com ® ® DPE Crimping tool for F7 fibre optic contact Description Crimping tool for capturing KEVLAR® strand on contact body. 3.1 2.7 Part number DPE.99.003.1K 1) Note: 1) Included in the LEMO F7 workstation. WST Epoxy curing oven Description Oven for assisting in curing epoxy. Part number WST.FR.220.VA WST.FR.110.VA Voltage 220 volts 110 volts DCS Polishing tool for fibre optic contacts Description Precision tool for polishing terminated fibre optic contacts with 1.25 mm ferrule. Part number DCS.91.D01.LC 1) Note: 1) Included in the LEMO F7 workstation. WST Fibre Inspection Microscope Description Microscope to assist in viewing termination operations and verifying fibre end finish. Zoom with 200 ➞ 400 x magnification. See adaptor below. Part number WST.FB.G00.301 DCS Microscope adaptor for fibre optic contacts Description Adaptor for final inspection of fibre optic contacts with 1.25 mm ferrule. To be used with microscope WST.FB.G00.301. Part number DCS.91.G90.6E125 1) Note: 1) Included in the LEMO F7 workstation. www.lemo.com 13 ® ® DCC Extractor for F7 fibre optic contact Description Manual tool for the extraction of the F7 contact. Part number DCC.91.307.5LA 1) Note: 1) Included in the LEMO F7 workstation. DCS F7 contact alignment device tool Description Simple tool with two threaded end for installation/extraction of the F7 contact alignment device. Part number DCS.F7.035.PN 1) Note: 1) Included in the LEMO F7 workstation. WST Fibre shield for F7 fibre optic contact Description To protect ferrule when curing epoxy. Part number WST.TU.193.LN 1) Note: 1) Included in the LEMO F7 workstation. Cable Termination Detailed instructions for terminating single fibre cables with LEMO F7 fibre optic contacts are given in the reference manual DOC.FO.CF7.0000 supplied with the complete termination workstation (see page 10). After termination contacts shall be introduced in the main insulator as shown below. For purpose of cleaning they can also be removed. Installation of F7 contact and alignment device Insertion The male fibre optic contact terminated on the cable must be inserted into the connector insulator from the back end until it comes to a stop. Make sure that the contact is correctly positioned into the inner antirotation key. Key is in line with the red dot on the rear of the contact (step 1). Check that the contact is correctly retained by gently pulling on it (step 2). 1) For female contacts, the alignment device shall be clipped onto the fibre optic contacts which is already fitted into female insulator. This procedure is performed using the tool, reference DCS.F7.035.PN. The alignment device shall be first installed onto threaded end of the tool (step 3). Then clip the adapter (step 4), unscrew and remove the tool (step 5). Extraction of alignment device Screw the threaded end of the tool reference DCS.F7.035.PN (step 1) onto the alignment device. Pull out strongly (step 2). 2) 1) 3) 2) 4) 5) Extraction of F7 contact Possible only for fixed socket, using the manual tool DCC.91.307.5LA. Shall be made with great care. Note: The life time installation of the alignment device is minimum 300 cycles. 14 www.lemo.com ® www.lemo.com ® 15 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 2108 1967 DC Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Trading (Shanghai) Co., Ltd LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 redelemo@lemo.hu ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com JAPAN LEMO Japan Ltd 4-10-3, Takaido Higashi, Suginami-ku, Tokyo, 168-0072 Tel: (+81 3) 53 44 39 33 Fax: (+81 3) 53 44 39 35 lemoinfo@lemo.co.jp LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO S.A. Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.F7.LEN.P1103 LEMO
FFS.F7.125.LCL23 价格&库存
很抱歉,暂时无法提供与“FFS.F7.125.LCL23”相匹配的价格&库存,您可以联系我们找货
