KDS U-M124WM124A-T2104-006
    LEUZE(劳易测)
    INTERCONNECTION CABLE
KDS U-M124WM124A-T2104-006 数据手册
Part no.: 50140495 – KDS U-M124W-M124A-T2104-006 – Interconnection cable Technical data Connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Design Angled Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Cable properties Number of conductors 4 Piece(s) Wire cross section 0.82 mm² AWG 18 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Interconnection cable Cable length 600 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Mechanical data Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Environmental data Ambient temperature, operation, flexible use -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Certifications Degree of protection IP 67 IP 65 NEMA 6P Classification eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 ETIM 5.0 EC001855 Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 2/3 Part no.: 50140495 – KDS U-M124W-M124A-T2104-006 – Interconnection cable Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Design Angled Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 3/3
1. 物料型号:50140495 – KDS U-M124W-M124A-T2104-006 2. 器件简介:文档描述了一种连接电缆,适用于拖链使用,具有弯曲周期1,000,000次。 3. 引脚分配:连接1和连接2均为4针编码A型,连接1为M12螺纹,女性类型,角度设计;连接2为M12螺纹,男性类型,轴向设计。 4. 参数特性:电缆具有4根导体,导体截面积为0.82 mm²(AWG 18),外护套颜色为黄色,无屏蔽,无硅,长度为600 mm,外护套材料为TPE,导线绝缘材料为PVC。 5. 功能详解:电缆设计用于连接,具有自锁的锁紧螺钉,推荐扭矩为0.5 Nm。 6. 应用信息:适用于拖链,可在-15至90°C的环境下灵活使用,-35至105°C的环境下固定使用。 7. 封装信息:保护等级为IP 67/IP 65 NEMA 6P,eCl@ss 8.0 27279218,eCl@ss 9.0 27060311,ETIM 5.0 EC001855。 8. 制造商信息:Leuze electronic GmbH + Co. KG,位于德国Owen。
KDS U-M124WM124A-T2104-006 价格&库存
很抱歉,暂时无法提供与“KDS U-M124WM124A-T2104-006”相匹配的价格&库存,您可以联系我们找货
