MLC500T30-1500
MLC500T30-1500
    LEUZE(劳易测)
    LIGHT CURTAIN HAND 30MM
MLC500T30-1500 数据手册
Technical data sheet Safety light curtain transmitter Part no.: 68000315 MLC500T30-1500 Contents - Technical data Dimensioned drawings Electrical connection Circuit diagrams Operation and display Suitable receivers Part number code Notes Accessories Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 1/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Technical data Basic data Cable properties Series MLC 500 Device type Transmitter Contains 2x BT-NC sliding block Application Hand protection Functions Permissible conductor cross section, typ. 0.25 mm² Length of connection cable, max. 100 m Permissible cable resistance to load, max. 200 Ω Mechanical data Functions Range reduction Dimension (W x H x L) 29 mm x 1,566 mm x 35.4 mm Transmission channel changeover Housing material Metal Metal housing Aluminum Lens cover material Plastic / PMMA Characteristic parameters Type 4, IEC/EN 61496 Material of end caps Diecast zinc SIL 3, IEC 61508 Net weight 1,650 g SILCL 3, IEC/EN 62061 Housing color Yellow, RAL 1021 Mission time TM 20 years, EN ISO 13849-1 Type of fastening Groove mounting Mounting bracket Protective field data Mounting on Device Column Resolution 30 mm Protective field height 1,500 mm Operating range 0 ... 10 m Swivel mount Operation and display Optical data Type of display LED Number of LEDs 2 Piece(s) Synchronization Optical between transmitter and receiver Light source LED, Infrared Wavelength 940 nm Ambient temperature, operation -30 ... 55 °C Transmitted-signal shape Pulsed Ambient temperature, storage -30 ... 70 °C LED risk group Exempt group (in acc. with EN 62471:2008) Relative humidity (non-condensing) 0 ... 95 % Environmental data Certifications Electrical data Protective circuit Degree of protection IP 65 Overvoltage protection Protection class III Short circuit protected Certifications c CSA US c TÜV NRTL US Performance data S Mark Supply voltage UB 24 V, DC, -20 ... 20 % Current consumption, max. 50 mA Fuse 2 A semi time-lag Inputs Number of digital switching inputs 1 Piece(s) TÜV Süd Vibration resistance 50 m/s² Shock resistance 100 m/s² US patents US 6,418,546 B Classification Customs tariff number 85365019 Type Digital switching input ECLASS 5.1.4 27272704 Switching voltage high, min. 18 V ECLASS 8.0 27272704 Switching voltage low, max. 2.5 V ECLASS 9.0 27272704 Switching voltage, typ. 22.5 V ECLASS 10.0 27272704 Voltage type DC ECLASS 11.0 27272704 ECLASS 12.0 27272704 ETIM 5.0 EC002549 ETIM 6.0 EC002549 ETIM 7.0 EC002549 Switching inputs Connection Number of connections 1 Piece(s) Connection 1 Function Machine interface Type of connection Connector Thread size M12 Material Metal No. of pins 5 -pin Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 2/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Dimensioned drawings All dimensions in millimeters Calculation of the effective protective field height HPFE = HPFN + B + C 35,4 M12 C H PFN 29 B R R A HPFE Effective protective field height = 1528 mm C 9 mm HPFN Nominal protective field height = 1500 mm R Effective protective field height HPFE goes beyond the dimensions of the optics area to the outer borders of the circles labeled with R. A Total height = 1566 mm B 19 mm Electrical connection Connection 1 Function Machine interface Type of connection Connector Thread size M12 Type Male Material Metal No. of pins 5 -pin Encoding A-coded Connector housing FE/SHIELD Pin Pin assignment Conductor color 1 VIN1 Brown 2 n.c. White 3 VIN2 Blue 4 RNG Black 5 FE/SHIELD Gray 2 1 3 5 FE 4 Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 3/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Circuit diagrams Transmission channel C1, reduced range + 24V BK BN + 24V -A1 VIN1 = +24 V 3 VIN2 = 0 V 4 RNG = 0 V or open 1 VIN1 = +24 V 3 VIN2 = 0 V 4 RNG = +24 V 4 RNG VIN1 1 1 2 WH 5 BU GY 3 n.c. FE VIN2 MLCx00T 0V FE 0V FE Transmission channel C1, standard range + 24V -A1 BK BN + 24V 4 RNG VIN1 1 2 WH 5 GY BU 3 n.c. FE VIN2 MLCx00T 0V FE 0V FE Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 4/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Circuit diagrams Transmission channel C2, reduced range + 24V -A1 BK BU + 24V VIN1 = 0 V 3 VIN2 = +24 V 4 RNG = 0 V or open 1 VIN1 = 0 V 3 VIN2 = +24 V 4 RNG = +24 V 4 RNG VIN2 3 1 BN 2 WH 5 GY 1 n.c. FE VIN1 MLCx00T 0V FE 0V FE Transmission channel C2, standard range + 24V -A1 BK BU + 24V 4 RNG VIN2 3 2 WH 5 GY BN 1 n.c. FE VIN1 MLCx00T 0V FE 0V FE Operation and display LED Display Meaning 1 Off Device switched off Red, continuous light Device error 2 Green, continuous light Normal operation Green, flashing, 10 s long after switching on Reduced range selected by the wiring of pin 4 Off Transmission channel C1 Green, continuous light Transmission channel C2 Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 5/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Suitable receivers Part no. Designation Article Description 68001315 MLC510R30-1500 Safety light curtain receiver Function package: Basic Resolution: 30 mm Protective field height: 1,500 mm Response time: 14 ms Connection: Connector, M12, Metal, 5 -pin 68002315 MLC520R30-1500 Safety light curtain receiver Function package: Standard Resolution: 30 mm Protective field height: 1,500 mm Response time: 14 ms Connection: Connector, M12, Metal, 8 -pin 68003315 MLC530R30-1500 Safety light curtain receiver Function package: Extended Resolution: 30 mm Protective field height: 1,500 mm Response time: 14 ms Connection: Connector, M12, Metal, 8 -pin 68009315 MLC530R30-1500SPG Safety light curtain receiver Function package: Smart Process Gating Resolution: 30 mm Protective field height: 1,500 mm Response time: 100 ms Connection: Connector, M12, Metal, 8 -pin Part number code Part designation: MLCxyy-za-hhhhei-ooo MLC Safety light curtain x Series 3: MLC 300 5: MLC 500 yy Function classes 00: transmitter 01: transmitter (AIDA) 02: transmitter with test input 10: basic receiver - automatic restart 11: basic receiver - automatic restart (AIDA) 20: standard receiver - EDM/RES selectable 30: extended receiver - blanking/muting z Device type T: transmitter R: receiver a Resolution 14: 14 mm 20: 20 mm 30: 30 mm 40: 40 mm 90: 90 mm hhhh Protective field height 150 … 3000: from 150 mm to 3000 mm e Host/Guest (optional) H: Host MG: Middle Guest G: Guest Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 6/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Part number code MLC Safety light curtain i Interface (optional) /A: AS-i ooo Option /V: high Vibration-proof EX2: explosion protection (zones 2 + 22) SPG: Smart Process Gating Note ª A list with all available device types can be found on the Leuze website at www.leuze.com. Notes Observe intended use! ª The product may only be put into operation by competent persons. ª Only use the product in accordance with its intended use. Accessories Connection technology - Connection cables Part no. Designation Article Description 50133860 KD S-M12-5A-P1-050 Connection cable Connection 1: Connector, M12, Axial, Female, A-coded, 5 -pin Connection 2: Open end Shielded: Yes Cable length: 5,000 mm Sheathing material: PUR Mounting technology - Swivel mounts Part no. Designation Article Description 429393 BT-2HF Mounting bracket set Fastening, at system: Through-hole mounting Mounting bracket, at device: Clampable Type of mounting device: Turning, 360° Material: Metal, Plastic Part no. Designation Article Description 520101 AC-ALM-M Alignment aid Housing material: Plastic Alignment aids Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 7/8 Safety light curtain transmitter • Part no.: 68000315 • MLC500T30-1500 Accessories Services Part no. Designation Article Description S981050 CS40-I-140 Safety inspection Details: Checking of a safety light barrier application in accordance with current standards and guidelines. Inclusion of the device and machine data in a database, production of a test log per application. Conditions: It must be possible to stop the machine, support provided by customer's employees and access to the machine for Leuze employees must be ensured. Restrictions: Travel costs and accommodation expenses charged separately and according to expenditure. S981046 CS40-S-140 Start-up support Details: For safety devices including stopping time measurement and initial inspection. Conditions: Devices and connection cables are already mounted, price not including travel costs and, if applicable, accommodation expenses. Restrictions: Max. 2 h., no mechanical (mounting) and electrical (wiring) work performed, no changes (attachments, wiring, programming) to third-party components in the nearby environment. Note ª A list with all available accessories can be found on the Leuze website in the Download tab of the article detailed page. Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2022-01-26 8/8
MLC500T30-1500 价格&库存
很抱歉,暂时无法提供与“MLC500T30-1500”相匹配的价格&库存,您可以联系我们找货
