SM0058-016-P
SM0058-016-P
    LICAP
    58F, 16V, PASSIVE
SM0058-016-P 数据手册
16V, 58F Ultracapacitor Module Specifications SM0058-016-P Capacitance Voltage ESR Current Rated1 58F Tolerance -0/+20% Rated 16V DC Surge 17V DC ESR (DC) - maximum initial 22mΩ Maximum leakage3 25mA Maximum peak 200A 2 Maximum continuous 19A RMS Maximum energy 2.1Wh Usable energy 1.5Wh 4 Energy Storage 5 Volumetric energy density6 2.4Wh/L Gravametric energy density 3.2Wh/kg Power density8 2148W/kg 7 Power Temperature Operating temperature range Temperature Characteristics Storage temperature range APPLICATIONS Monitor and Control • Wind Turbine Pitch Control Alarm Monitor • UPS Systems • Industrial Peak Load Shaving • Small Engine Starting • AGV -40℃ to +65℃ -40℃ to +70℃ Over voltage N/A Temperature sensor N/A Short circuit current 640A 500V DC Insulation resistance ≥100MΩ 5600V DC Leakage current ≤10mA Environmental ingress protection IP54 Safety Safety Service Lifetime Endurance FEATURES & ADVANTAGES • One Million Cycle Life • High Power Density Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Product held at rated voltage in 25℃ environment DC Life • Compact Size, Lightweight Life (projected) 10+ years Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Cycling from rated voltage to 50% voltage under constant current in 25℃ environment • Wide Temperature Range: -400C to +650C Product held at rated voltage in 65℃ environment for 1500 hours Cycle Life Storage Life (projected) 1,000,000 cycles Change in capacitance (% drop from rated) ≤20% Change in ESR (% increase from maximum initial) ≤100% Stored uncharged in original packaging in 25℃ environment Life 4 years Physical Characteristics Mechanical Vibration GB/T 11287-2000 Transportation vibration GB/T 4798.2-2008 Shock GB/T 14537-1993 16V, 58F Ultracapacitor Module Outline Drawings: Weight and Size: Weight: ≤.65 kg | Size: (Typical value): 240*47*76 (L*W*H) mm Naming Rules: SM Supercapacitor Module Capacaitance Dash Rated Voltage Dash CMS - Capacitor Management/Monitoring 0058 = 58F - 016 = 16V - P = Passive balancing Notes: 2. Maximum voltage is non-repeatable and duration cannot exceed 1s 3. Corresponding current value after 72 hours of rated voltage at 25℃ 4. 0.5C(Vnom2)/3600 CAP/ESR Measurement Waveform V1 +1 V3 ( 6. Max energy (Wh)/ L x W x H (mm) 1 x 106 ) 7. Max energy (Wh)/Weight (kg) 8. Per IEC62391-2, Pd = 0.12V2 ESRDC x Weight(kg) LICAP Technologies, Inc. V4 0 0 5. 0.5C(Vnom2 - 0.5Vnom2)/3600 V2 Capacitor Voltage 1. Measure capacitance and DC internal resistance at 25℃ under specified test current per Figure 1 Time t1 V1 = Vrated t2 - t1 = 15 seconds V3 = 0.5 x Vrated t4 - t3 = 5 seconds t2 t3 t4 Capacitor Current Type Voltage Current -1 Capacitance = I x (t3-t2)/(V2-V3) ESR = (V4 - V3)/I Figure 1 Precautions: • This product may vent or rupture if overcharged, reverse charged,incinerated or heated above 100℃ • Do not crush, mutilate, or disassemble • Do not dispose of unit in trash Specifications are subject to change without notice. 9795 Business Park Drive - Sacramento, CA 95827 USA https://licaptech.com/ • info@licaptech.com
SM0058-016-P 价格&库存
很抱歉,暂时无法提供与“SM0058-016-P”相匹配的价格&库存,您可以联系我们找货
