LCD196-156NTL0NCNTTR1.0
    LINCOLN
    非触控式 智能,智慧,发光二极管,图形 OLED eDP 15.6"(396.24mm) 3840 x 2160
LCD196-156NTL0NCNTTR1.0 数据手册
Page |1 15.6” AMOLED 3840*2160 LCD196-156NTL0NCNTTR0.1 lincolntechsolutions.com ● 111 Corning Rd. STE 116 ● Cary, NC 27518 www.lincolntechsolutions.com ©2021 All rights reserved. Page |2 Contents Revision History ...................................................................................................................................................................................... 3 1. Scope ................................................................................................................................................................................................... 3 2. Features .............................................................................................................................................................................................. 3 3. General Information ...................................................................................................................................................................... 4 4. Maximum Rating ............................................................................................................................................................................... 4 5. Mechanical Specifications .............................................................................................................................................................. 5 6. Electrical Specifications ................................................................................................................................................................... 5 7. Electro-Optical Specification......................................................................................................................................................... 6 8. I/O connection & Block Diagram ...........................................................................................................................................11 9. Recommended Operating Sequence ..................................................................................................................................12 10. Interface ...........................................................................................................................................................................................13 11. Reliability .........................................................................................................................................................................................13 12. Handling Precautions .................................................................................................................................................................13 14. Packing Specification ..................................................................................................................................................................14 15. The Control of Hazardous substances ................................................................................................................................14 www.lincolntechsolutions.com ©2021 All rights reserved. Page |3 Revision History Version History Version. Date Contents Remark No 1 12/13/2021 2 5/20/2022 Preliminary Specification Corrected part Revision in the preliminary specification to 0.1 1. Scope This Specification defines AMOLED manufactured Lincoln Technology Solutions, from here on referred to as LTS. In the case of any unspecified item, it may require both LTS and the party designs this module into its product to work out a solution. 2. Features 2.1 Product Applications Laptop/Notebook 2.2 Product Features 1) Display color:RGB 10bit 2) Display format:15.6” (3840RGBx2160) 3) Pixel arrangement: Real RGB arrangement 4) Interface:eDP 1.4b 5) T-con: MTK 6) Source IC: RM98110 7) Power IC: RM/Chipone www.lincolntechsolutions.com ©2021 All rights reserved. Page |4 2.3 Model Name: Code Definition Description E Suppler Name LTS 156 Display Size 15.60 inch U Resolution B Technology A Touch technology NA 6 Delivery type FOG A serial number A 3840RGB×2160 LTPS/Real RGB/0.3mm glass 3. General Information Item Specification Unit Active area 344.2176 (H) x 193.6224 (V) mm Diagonal size 15.6 inch Driver Element LTPS TFT active matrix Display mode OLED Display Colors RGB 10 bit Number of pixel 3840*2160(UHD) Pixel Arrangement RGB Delta Type Pixel pitch 89.64x89.6 Surface treatment Glare 4 Note Pixel 16:9 μm 4. Maximum Rating Item Symbol Min. Max. Unit Note Storage temperature TSTG -40 85 ℃ - Operating temperature TOPR -20 70 ℃ - Supply System VDD_3.3V -0.3 +4.6 V - Voltage EL Power VBAT -0.3 +27 V - www.lincolntechsolutions.com ©2021 All rights reserved. Page |5 5. Mechanical Specifications Item Module Size Min. Typ. Max. Unit Horizontal (H) 348.02 348.22 348.42 mm Vertical (V) 215.172 215.672 216.172 mm Thickness (Panel) - 1.102 1.215 inch 2.804 mm 200 g Thickness w/ PCB Weight Note w/ PCB 6. Electrical Specifications Item System Symbol Condition Min. Typ. Max. Unit VDD_3.3V - 3.0 3.3 3.6 V Analog Vol. VBAT - 8.0 12.0 21.0 V Logic VDD_3.3V - 420 640 - 1100 1370 - 1.4 2.1 Analog/ Note Logic Vol. Panel Current Consumption Panel IVBAT Logic VDD_3.3V Full white VDD_3.3V =3.3V VBAT=12V Panel Frame Frequency PVBAT fps - - 13.2 16.4 - 60 - mA (1) W (1) Hz Note (1): VDD_3.3V=3.3 (V) VBAT=12.0 (V), Full White pattern, Temperature = 22±3℃ Room Temperature www.lincolntechsolutions.com ©2021 All rights reserved. Page |6 7. Electro-Optical Specification Test condition:25℃±3℃,65±20%RH,Dark room. Item Symbol Brightness Peak Luminance (10% Box) Condition Min. Typ. Max. Unit Normal (White mode) 352 400 448 cd/m Note 2 2 (1) VESA VESA HDR 500 - - cd/m Full white 75 - - % 500TB (2) 100,000 - - - (3) x 0.293 0.313 0.333 - y 0.309 0.329 0.349 - 0.658 0.688 0.718 - 0.282 0.312 0.342 - 0.18 0.22 0.26 - y 0.696 0.736 0.776 - x 0.105 0.145 0.185 - y 0.021 0.041 0.081 - 98 - - % 98 - 6000 6500 7000 K 2.0 2.2 2.4 - (5) - 1 2 ms (6) 85 - - ° (7) - - 0.025 - (8) - - 3.5 % (9) - - -30 dB Brightness Uniformity Normal Contrast Ratio HDR Θ=Φ=0° White Color of CIE Red Coordinate Green Blue x y x Normal Θ=Φ=0° Adobe RGB Color Gamut DCI-P3 Normal White Temperature°K Θ=Φ=0° Normal Gamma % (4) Θ=Φ=0° Response time On/Off Top/Bottom/Right/ Left Viewing Angle CR>10 Color Shift ∆uv Image Sticking ∆E Θ=Φ=45° Macbeth pattern Max Lum, 3000h Flicker www.lincolntechsolutions.com ©2021 All rights reserved. Normal Θ=Φ=0° Page |7 Crosstalk Normal Θ=Φ=0° TUV blue ray certification 415-455nm/400-500nm OLED Lifetime T50 @ 25℃ - 15,000 - - 1.5 % (10) 50 % (11) - Hrs (12) Note 1: Brightness follows MicroSoft brightness3 (Based on OPR 50%). The Brightness of full white pattern (OPR100%) is the same as that of OPR 50%. Note 2: Brightness uniformity For brightness uniformity measure, LTS’ request as below: 1. The test condition is at 25℃ and measured on the surface of Display panel module. 2. Measurement equipment: CA310 or similar equipment. 3. The brightness uniformity is calculated by using following formula: Brightness Uniformity = Bp (Min.) / Bp (Max.)×100 (%) Bp (Max.) = Maximum brightness in 13 measured spots Bp (Min.) = Minimum brightness in 13 measured spots. www.lincolntechsolutions.com ©2021 All rights reserved. Page |8 Note 3: Contrast Ratio Dark Room C.R=LW/LB LW: full white brightness of display center P0; LB: full black brightness of display center P0. Note 4: Color Gamut For brightness uniformity measure, LTS’ request as below: 1. Measurement equipment: CS2000A or similar equipment. 2. DCI-P3 & Adobe color data: CIE1976 R G B DCI-P3 (0.496,0.526) (0.099,0.578) (0.175,0.158) Adobe (0.451,0.523) (0.076,0.576) (0.175,0.158) 3. The color gamut is calculated by using following formula: Color Gamut % = S coverage / S original color gamut S coverage: The area covered by panel color gamut S original color gamut: The triangle area of Adobe or DCI-P3 color gamut For example: Color Gamut %= SDEB/SABC % www.lincolntechsolutions.com ©2021 All rights reserved. Page |9 Note 5: Gamma For gamma curve control, LTS’ request as below: 1. Calibration the test instrument. Set the screen size parameters and measure the center point. 2. LTS will test the gray scale below, if possible, also can use the patterns of gray 0 to 255 to test: for example: 0, 8, 16, 25, 33, 41, 49, 58, 66, 74, 82, 90, 99, 107, 115, 123, 132, 140, 148, 156, 165, 173, 181, 189, 197,206, 214, 222, 230, 239, 247, 255 Or 0, 1, 2, 3, ..., 252, 253, 254,255. Total 256pcs patterns. 3. Output the measure data. Data number normalization and draw the chart. 4. The whole screen should be complied with the gamma curve of gamma 2.0 or 2.4, it means +/-0.2 error is allowed. But if there are special requirements for the special project, its required specifications can be used as a standard value, please refer the project spec. Note 6: Response Time Response time=Pixel turn on and turn off time (WhiteBlack). It is measuring transition time from 10% to 90% of luminance. Note 7: The definition of Viewing Angle Refer to the graph below marked by θ and Ф www.lincolntechsolutions.com ©2021 All rights reserved. P a g e | 10 Note 8: Color Shift For color shift measure: Fix on white pattern, On the condition θ=0 F=0°, we can get the color coordinate (u1', v1') and on θ=45° F=45° we can get another color coordinate (u2', v2') Delta = Square Root((u2'-u1')^2 + (v2'-v1')^2 ) JNCD stands for "Just Noticeable Color Difference" For the (u', v') color space 1 JNCD=0.0040 4.5 JNCD means Delta u’v’
LCD196-156NTL0NCNTTR1.0 价格&库存
很抱歉,暂时无法提供与“LCD196-156NTL0NCNTTR1.0”相匹配的价格&库存,您可以联系我们找货
