EVM-915-250-BZR
EVM-915-250-BZR
    LINXTECHNOLOGIES(灵思)
    EVAL MODULE 915-920MHZ
EVM-915-250-BZR 数据手册
EVM-915-250 Data Guide (Preliminary) Table of Contents 1 2 2 4 5 6 7 8 Description Ordering Information Electrical Specifications Pin Assignments Pin Descriptions PCB Footprint Schematic Diagram Usage Guidelines for FCC Compliance 8 Antenna Selection 8 Module Modification 8 End Product Labeling Requirements Additional FCC Testing Requirements 10 FCC Statements of Modular Compliance 11 Customer FCC Warning Requirements 9 EVM-915-250 Data Guide (Preliminary) Description The EVM-915-250 evaluation module supports developments with the TRM915-R250 embedded radio module. The EVM-915-250 module combines a state-of-the art low power wireless transceiver with a powerful multipointFigure 1: EVM-915-250-FCx to-multipoint protocol controller to form a complete wireless communication solution. With a simple UART interface, a 130dB link budget and very low power operation modes. The module is excellent for Automatic Meter Reading (AMR), fleet management, RFID, gas and oil sensing, Home Automation, and many other cable replacement applications requiring long range and long battery life. The module can operate as a transparent wire replacement solution. It can also operate in a peer-to-peer networked mode that supports node addressing and assured delivery. The module is designed to be totally transparent. Data is validated using an internally generated CRC-16 and encoded using a proprietary Frequency Hopping Spread Spectrum algorithm. Multiple modules can operate on the same channel because of the built-in carrier-sense-multiple-access (CSMA) protocol. –1 – Preliminary Draft Revised 5/30/12 Ordering Information Electrical Specifications Continuation Parameter Ordering Information Product Part No. Description Radiotronix Part No. EVM-915-250-FCR TRM-915-R250 Evaluation Module, Right Angle RP-SMA Connector, FCC Approved Wi.232FHSS-250-FCC-RA-R EVM-915-250-FCS TRM-915-R250 Evaluation Module, Straight RP-SMA Connector, FCC Approved Wi.232FHSS-250-FCC-ST-R EVM-915-250-BZR TRM-915-R250 Evaluation Module, Right Angle RP-SMA Connector, Brazil Anatel Approved Wi.232FHSS-250B-RA-R EVM-915-250-BZS TRM-915-R250 Evaluation Module, Straight RP-SMA Connector, Brazil Anatel Approved Wi.232FHSS-250B-ST-R EVM-915-250-CFR TRM-915-R250 Evaluation Module, Right Angle SP-SMA Connector, Mexico CoFeTel Approved Wi.232FHSS-250-FCC-CFTC-RA-R EVM-915-250-CFS TRM-915-R250 Evaluation Module, Straight RP-SMA Connector, Mexico CoFeTel Approved Wi.232FHSS-250-FCC-CFTC-ST-R Electrical Specifications Min. Operating Voltage VCC 4 Supply Current Max. Units ICC Typ. 12 VDC 25 mA Transmit, Po = 8dBm 60 mA Transmit, Po = 23.5dBm 200 mA Power Supply Receive Digital Interface Output Logic Low VOL 0 0.4 VDC Logic High VOH 2.5 VCC VDC Preliminary Draft –2 – Typ. Max. Units Notes Logic Low VIL 0 0.3*VCC VDC Logic High VIH 0.7*VCC VCC VDC –40 85 °C Operating Temperature Range Figure 3: Electrical Specifications Electrical Specifications Designation Min. Environmental Figure 2: Ordering Information Parameter Designation Input Notes ! Warning: Linx radio frequency (“RF”) products may be used to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns. No Linx Technologies product is intended for use in any application without redundancies where the safety of life or property is at risk. The customers and users of devices and machinery controlled with RF products must understand and must use all appropriate safety procedures in connection with the devices, including without limitation, using appropriate safety procedures to prevent inadvertent triggering by the user of the device and using appropriate security codes to prevent triggering of the remote controlled machine or device by users of other remote controllers. All RF products are susceptible to RF interface that can prevent communication. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. –3 – Preliminary Draft Pin Assignments Pin Descriptions Pin Descriptions Pin No. Figure 3: Pin Assignments Name Description 1 Vcc 4V to 12V Supply Voltage 2 RXD0 Serial Port Receive Data 3 TXD0 Serial Port Transmit Data 4 CTS0 Serial Port Clear To Send 5 COMMAND Command 6 N/C No Electrical Connection 7 N/C No Electrical Connection 8 N/C No Electrical Connection 9 N/C No Electrical Connection 10 N/C No Electrical Connection 11 GND Analog Ground 12 GND Analog Ground 13 GND Analog Ground 14 GND Analog Ground 15 N/C No Electrical Connection 16 N/C No Electrical Connection 17 N/C No Electrical Connection 18 N/C No Electrical Connection 19 PD5-EX Exception 20 RSSI Received Signal Strength Indicator 21 AD0-CMD_RSP Command Response 22 AD1-BE Buffer Empty 23 GND Analog Ground 24 GND Analog Ground Figure 4: Pin Descriptions Preliminary Draft –4 – –5 – Preliminary Draft PCB Footprint Schematic Diagram Figure 5: PCB Footprint Figure 6: Schematic Preliminary Draft –6 – – 7– Preliminary Draft Usage Guidelines for FCC Compliance Additional FCC Testing Requirements The EVM-915-250-FCx modules have been awarded a FCC and IC modular approval. The EVM-915-250-BZx have passed Anatel compliance testing. That means that this module, when integrated into your end product, requires no FCC part 15 or IC RSS-210 testing as long as the following guidelines are met. Failure to meet any of the following guidelines will prevent the inheritance of the FCC and IC modular certifications. While the module’s FCC certification can be inherited if the guidelines are met, additional testing will be required to achieve full FCC compliance for the end-product. The integrator is required to perform unintentional radiator testing on the final product per FCC sections 15.107 and 15.109. Additional product-specific testing might be required. Please contact the FCC regarding regulatory requirements for your application. Ultimately is it the integrator’s responsibility to show that their product complies with the regulations applicable to their product. Antenna Selection In order to maintain compliance with FCC, Industry Canada and Anatel regulations, an antenna with no more than 3dBi gain must be used. This module has been tested with the following antennas: Antenna Selection Link Part No. Antenna Type Antenna gain ANT-916-CW-HW RP ½ Wave Dipole 2.5dBi Figure 7: Antenna Selection An approved antenna must be directly attached to the module’s reverse-polarity SMA connector or through an approved shielded coaxial extension cable in the final application to inherit the FCC and IC modular certifications. Module Modification The module must not be physically altered in any way. If any connections are made to the modules that bypass the module pins, socket or antenna connector, the certifications cannot be inherited. End Product labeling Requirements Pursuant to FCC public notice DA 00-1407, the end product must be labeled on its exterior with the following: “Contains FCC ID: Q7V-3F090009X” Preliminary Draft –8 – – 9– Preliminary Draft FCC Statements of Modular Compliance FCC / IC NOTICE (FCC ID: Q7V-3F090009X / IC: 5589A-3F090009) Customer FCC Warning Requirements The end-product user’s manual must contain the following or equivalent statements. This device complies with the rules set forth in Part 15 by the Federal FCC / IC NOTICE Communications Commission and RSS-210/RSS-Gen by Industry Canada. Operation (Containing FCC ID: Q7V-3F090009X / IC: 5589A-3F090009) is subject to the following two conditions: The RF module (FCC ID: Q7V-3F090009X / IC: 5589A-3F090009) contained within 1. This device may not cause harmful interference this device complies with the rules set forth in Part 15 by the Federal Communications 2. This device must accept any interference received, including interference that may Commission and RSS-210/Gen by Industry Canada. Operation is subject to the following conditions: cause undesired operation. Any changes or modifications not expressly approved by Linx Technologies could void 1. This device may not cause harmful interference the user’s authority to operate the equipment. 2. This device must accept any interference received, including interference that The EVM-915-250-FCx module is provided with an inheritable FCC Modular 3. An approved antenna must be directly coupled to the module’s RP-SMA connec- may cause undesired operation. Certification. This certification may be inherited in an end-user product, negating the need for FCC part 15 and IC RSS-210 intentional radiator testing on this module, provided that the following guidelines are met: tor or through an approved coaxial extension cable. 4. The module must not be modified in any way. Coupling of external circuitry must not bypass the provided connectors. 5. The antenna used for this transceiver must not be co-located or operating in 1. An approved antenna must be directly coupled to the module’s RP-SMA connector conjunction with any other antenna or transmitter. or through an approved coaxial extension cable. 2. The module must not be modified in any way. Coupling of external circuitry must not Any changes or modifications could void the user’s authority to operate the equipment. bypass the provided connectors. 3. End product must be externally labeled with “Contains FCC ID: Q7V-3F090009X / FCC/IC Pre-certified EVM-915-250 FCC ID: Q7V-3F090009X IC: 5589A-3F090009” 4. The end product’s user’s manual must contain an FCC statement equivalent to that IC: 5589A-3F090009 listed on page 8 of this manual. 5. The antenna used for this transceiver must not be co-located or operating in conjunction with any other antenna or transmitter. 6. The integrator must not provide any information to the end-user on how to install or remove the module from the end-product. The integrator is required to perform unintentional radiator testing on the final product per FCC sections 15.107 and 15.109. FCC/IC Pre-certified EVM-915-250 FCC ID: Q7V-3F090009X IC: 5589A-3F090009 Preliminary Draft –10 – – 11 – Preliminary Draft Linx Technologies 159 Ort Lane Merlin, OR, US 97532 3090 Sterling Circle, Suite 200 Boulder, CO 80301 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com Disclaimer Linx Technologies is continually striving to improve the quality and function of its products. For this reason, we reserve the right to make changes to our products without notice. The information contained in this Data Guide is believed to be accurate as of the time of publication. Specifications are based on representative lot samples. Values may vary from lot-to-lot and are not guaranteed. “Typical” parameters can and do vary over lots and application. Linx Technologies makes no guarantee, warranty, or representation regarding the suitability of any product for use in any specific application. It is Customer’s responsibility to verify the suitability of the part for the intended application. At Customer’s request, Linx Technologies may provide advice and assistance in designing systems and remote control devices that employ Linx Technologies RF products, but responsibility for the ultimate design and use of any such systems and devices remains entirely with Customer and/or user of the RF products. LINX TECHNOLOGIES DISCLAIMS ANY AND ALL WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL LINX TECHNOLOGIES BE LIABLE FOR ANY CUSTOMER’S OR USER’S INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF OR RELATED TO THE DESIGN OR USE OF A REMOTE CONTROL SYSTEM OR DEVICE EMPLOYING LINX TECHNOLOGIES RF PRODUCTS OR FOR ANY OTHER BREACH OF CONTRACT BY LINX TECHNOLOGIES. CUSTOMER AND/OR USER ASSUME ALL RISKS OF DEATH, BODILY INJURIES, OR PROPERTY DAMAGE ARISING OUT OF OR RELATED TO THE USE OF LINX TECHNOLOGIES RF PRODUCTS, INCLUDING WITH RESPECT TO ANY SERVICES PROVIDED BY LINX RELATED TO THE USE OF LINX TECHNOLOGIES RF PRODUCTS. LINX TECHNOLOGIES SHALL NOT BE LIABLE UNDER ANY CIRCUMSTANCES FOR A CUSTOMER’S, USER’S, OR OTHER PERSON’S DEATH, BODILY INJURY, OR PROPERTY DAMAGE ARISING OUT OF OR RELATED TO THE DESIGN OR USE OF A REMOTE CONTROL SYSTEM OR DEVICE EMPLOYING LINX TECHNOLOGIES RF PRODUCTS. The limitations on Linx Technologies’ liability are applicable to any and all claims or theories of recovery asserted by Customer, including, without limitation, breach of contract, breach of warranty, strict liability, or negligence. Customer assumes all liability (including, without limitation, liability for injury to person or property, economic loss, or business interruption) for all claims, including claims from third parties, arising from the use of the Products. Under no conditions will Linx Technologies be responsible for losses arising from the use or failure of the device in any application, other than the repair, replacement, or refund limited to the original product purchase price. Devices described in this publication may contain proprietary, patented, or copyrighted techniques, components, or materials. All rights reserved. ©2012 Linx Technologies The stylized Linx logo, Wireless Made Simple, CipherLinx, WiSE and the stylized CL logo are trademarks of Linx Technologies.
EVM-915-250-BZR 价格&库存
很抱歉,暂时无法提供与“EVM-915-250-BZR”相匹配的价格&库存,您可以联系我们找货
