MIMX31CSOMXR
MIMX31CSOMXR
    BEACONEMBEDDEDWORKS
    ZOOM I.MX31 EVAL BRD
MIMX31CSOMXR 数据手册
PRODUCT BRIEF: Logic :: Freescale i.MX31 SOM-LV System on Module The i.MX31 System on Module (SOM) is a compact, productready hardware and software solution that fast forwards your embedded product design. i.MX31 SOM-LV :: HIGHLIGHTS: + Product-ready System on Module with the Freescale i.MX31 processor running up to 532 MHz + Compact form factor—SOM-LV Type I 59.1 x 76.2 x 7.9 mm Designed in the SOM-LV form factor, the i.MX31 module offers essential features for handheld and embedded networking applications. Use of custom baseboards makes the SOM-LV the ideal foundation for OEMs developing handheld and compact products. The SOM-LV provides a common reference pin-out on its expansion connectors, which enables easy scalability when new functionality or performance is required. Application development is performed right on the product-ready i.MX31 SOM-LV and software Board Support Packages (BSPs), which enables you to seamlessly transfer your application code and hardware into production. The i.MX31 SOM-LV is ideal for applications in the medical, pointof-sale, industrial, and security markets. From patient monitoring + Long product lifecycle + Microsoft Windows Embedded CE Board Support Packages (BSPs) + 0 ˚C to 70 ˚C (commercial temp) or -30 ˚C to 85 ˚C (extended temp) + RoHS compliant ZOOM ™ i.MX LITEKIT :: FEATURES: i.MX31 SOM-LV SYSTEM ON MODULE and medical imaging, to card payment terminals and bar code readers, to CCTV cameras and intruder alarms, the i.MX31 SOM-LV allows for powerful versatility and long-life products. + Application + i.MX31 baseboard SOM-LV (MIMX31CSOMCR) + Necessary accessories to immediately get up and running + Kit available from Freescale (MCIMX31LITEKITC) + See i.MX LITEKIT product brief for more information Product Features i.MX31 SOM-LV Block Diagram USB HS OTG PHY USB HS Host PHY ULPI ULPI i.MX31 Processor Processor + Freescale ARM 1136JF-S i.MX31 processor running up to 532 MHz MC13783 13-bit CODEC Touch Controller A/D Power Controller I2S SPI SDRAM Memory + Low power DDR, 64 or 128 MB (128 MB standard) Flash Memory + 2–4 MB scalable NOR flash (2 MB standard) + Scalable NAND flash (64 MB standard) Low Power DDR SDRAM Level Shifting Buffers 1.8V → 3.3V Display + Programmable color LCD controller + Built-in driver supports up to 800 x 600 with 18-bit LCD interface 10/100 Ethernet* NAND Flash *on select configurations Touch Screen + Integrated 4-wire touch screen controller (Freescale MC13783) i.MX31 SOM-LV Ordering Information Model Number Speed (MHz) SDRAM (MB) NAND Flash (MB) NOR Flash (MB) Touch Audio Ethernet Temp MIMX31ASOMCR up to 532 64 64 2 Y Y -- 0 ˚C to 70 ˚C MIMX31BSOMCR up to 532 64 64 2 Y Y Y 0 ˚C to 70 ˚C MIMX31CSOMCR up to 532 128 64 2 Y Y Y 0 ˚C to 70 ˚C MIMX31CSOMXR up to 532 128 64 2 Y Y Y -30 ˚C to 85 ˚C Audio + I2S compliant audio codec (Freescale MC13783—16-bit stereo DAC, 13-bit ADC) PC Card Expansion + CompactFlash Type I card + MMC/SD card support ATA Support ZOOM™ i.MX LITEKIT Ordering Information Model Number SOM-LV Configuration Recommended Resale MCIMX31LITEKITC MIMX31CSOMCR $675 USB + One USB 2.0 high-speed host interface + One USB high-speed On-the-Go device interface (Philips ISP1504CBS) Serial Ports + Three 16C550 compatible UARTs LOGIC WEBSITE :: DESIGN RESOURCES: + Logic Products : www.logicpd.com/products + Logic Technical Support : www.logicpd.com/product-support + For Network Support + 10/100 Base-T Ethernet controller for application/debug (SMSC LAN9117) GPIO + Programmable I/O depending on peripheral requirements more information contact Logic Sales : product.sales@logicpd.com Software + LogicLoader™ (bootloader/monitor) + Windows Embedded CE 5.0 and 6.0 BSPs Mechanical + SOM-LV Type I form factor + 59.1 mm wide x 76.2 mm long x 7.9 mm high 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com © 2009 Logic Product Development Company. All rights reserved. PN: 1005859 Rev J RoHS Compliant
MIMX31CSOMXR 价格&库存
很抱歉,暂时无法提供与“MIMX31CSOMXR”相匹配的价格&库存,您可以联系我们找货
