M5329BFE
M5329BFE
    BEACONEMBEDDEDWORKS
    Module
    ZOOM MCF5329 EVAL BRD
M5329BFE 数据手册
PRODUCT BRIEF: Logic :: Freescale MCF5329 FIRE ENGINE System on Module The MCF5329 Fire Engine is a compact, product-ready hardware and software solution that fast forwards your embedded product design. MCF5329 FIRE ENGINE :: HIGHLIGHTS: The MCF5329 Fire Engine is a complete System on Module (SOM) that offers essential features for handheld and embedded networking applications. Use of custom baseboards makes the Fire Engine the ideal foundation for OEMs developing handheld and compact products. The Fire Engine provides a common reference pin-out on its expansion connectors, which enables easy scalability to next generation microprocessor Fire Engines when new functionality or performance is required. + SOM Application development is performed right on the product-ready MCF5329 Fire Engine and software Board Support Packages (BSPs), which enables you to seamlessly transfer your application code and hardware into production. + MCF5329 The MCF5329 Fire Engine is ideal for applications in the medical, point-of-sale, industrial, and security markets. From patient + Product-ready System on Module with the MCF5329 ColdFire processor running at 240 MHz Card Engine form factor 60.2 mm x 67.8 mm x 4.4 mm + Long product lifecycle + Multiple + 0 third-party software options ˚C to 70 ˚C (commercial temp) + RoHS compliant ZOOM ™ COLDFIRE M5329EVB :: FEATURES: + Application FREESCALE MCF5329 FIRE ENGINE monitoring and medical imaging, to card payment terminals and bar code readers, to CCTV cameras and intruder alarms, the MCF5329 Fire Engine allows for powerful versatility and long-life products. baseboard Fire Engine (M5329BFE) + Necessary accessories to immediately get up and running + Kit available from Freescale (M5329EVBE) + See Zoom™ ColdFire SDK product brief for more information Product Features MCF5329 Fire Engine Block Diagram EXP CONNECTOR #1 Processor + Freescale MCF5329 32-bit ColdFire RISC microprocessor running at 240 MHz EXP CONNECTOR #2 MAC POWER IN Flash Memory + 2–4 MB scalable NOR flash (2 MB standard) + Scalable NAND flash (16 MB standard) CONFIG COLDFIRE PROCESSOR U R AT CONTROLLER SDRAM Memory + 32 MB DDR SDRAM standard AUDIO CODEC MCF5329 J TA G TOUCHSCREEN DMA INT PERIPHERALS PHY 10/100 BASE-T FLEXBUS DDR LEVEL SHIFT DDR RAM NOR FLASH NAND FLASH Display + Programmable color LCD controller + Built-in driver supports up to 800x600 with 16-bit LCD interface Touch Screen + Integrated 4-wire touch screen controller Network Support + 10/100 Base-T Ethernet controller for application/debug (National Semiconductor DP83848 PHY) SODIMM CONNECTOR MCF5329 Fire Engine Ordering Information Freescale P/N Speed (MHz) SDRAM (MB) NAND Flash (MB) NOR Flash (MB) Touch Audio Ethernet M5329AFE 240 32 0 2 Y Y Y M5329BFE 240 32 16 2 Y Y Y ZOOM™ ColdFire M5329EVB Ordering Information Freescale P/N SOM Configuration Recommended Resale M5329EVBE M5329BFE $699 Serial Ports + Three 16C550 compatible UARTs + Queued SPI interface w/selectable bit patterns Discussion Group : http://www.logicpd.com/support/tdg/ + Frequently + For CAN + CAN 2.0B interface muxed with I2C interface Technical Support : http://www.logicpd.com/support/ + Technical PC Card Expansion + CompactFlash Type I card (memory-mapped mode only) USB + USB 2.0 full-speed host and device interface LOGIC WEBSITE :: DESIGN RESOURCES: + Logic Audio + I2S compliant audio codec (Texas Instruments TLV320AIC23) GPIO + Programmable I/O depending on peripheral requirements Asked Questions (FAQ) : http://www.logicpd.com/support/faq/ more information contact Logic Sales : product.sales@logicpd.com Software + LogicLoader™ (bootloader/monitor) + Freescale dBUG ROM monitor + Multiple third-party software options Mechanical + 60.2 mm wide x 67.8 mm long x 4.4 mm high embedded product solutions 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com RoHS Compliant © 2007 Logic Product Development. All rights reserved. PN: 1004114 Rev G
M5329BFE 价格&库存
很抱歉,暂时无法提供与“M5329BFE”相匹配的价格&库存,您可以联系我们找货
