Suited for Intermediate Users
ABS by IC3D
3 mm , 1kg reel
IC3D ABS is the first and only Certified Open Source Hardware 3D printer
filament. IC3D has published their filament production process which includes
documentation on equipment used, settings and parameters, material grade,
and sources.
This transparency not only shows the drive for consistency, precision, and
quality, but also a committment to furthering desktop 3D printing material
technology. By choosing IC3D ABS you too can help support User Freedom in
the 3D printing industry.
ABS is the leading thermoplastic used in consumer electronics. 3D printed
ABS objects balance strength, resilience, and heat resistance.
PRODUCT ALERT (2)
Additional Accessory Recommendation:
3D printing in a cool or drafty environment? The LulzBot TAZ 6 Enclosure and
the LulzBot Mini Enclosure by Printed Solid will help minimize warping and
splitting.
Inventory Note:
IC3D ABS will only be restocked in Australia, Canada, and the United States.
Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ 14, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ Dual Extruder, LulzBot TAZ
FlexyDually, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5
Hexagon, LulzBot TAZ 1-4 Budaschnozzle, LulzBot Budaschnozzle
Colors
Black
Blue
Green
LulzBot Green
Grey
Natural
Orange
Red
White
Yellow
Features
IC3D ABS features a precise filament diameter and roundness for
consistently smooth top surface finishes and fine layer stacking. Use
ABS filament when your 3D printed objects need to be strong, stiff, and
flexible enough to resist breaking when stressed. ABS can also be postprocessed easily, either by sealing and painting or through solventbased methods.
Parts & Specifications
Filament Specifications
Filament Diameter: 3 mm (0.12 inches)
Amount of Filament: 1 kg (2.2 lb), 5 lb (2.27 kg)
Filament color may vary
Printing Specifications
Special Tool Head Requirements: LulzBot v2 All-Metal Hot End
recommended
Hot End Temperature Range: 235-245°C
Print Surface: PEI film recommended.
Print Surface Temperature: 95°C
Packaging Information
IC3D ABS filament ships vacuum sealed and mounted on a reel.
https://www.lulzbot.com/store/filament/IC3D‐ABS 4‐5‐18
很抱歉,暂时无法提供与“RM-AB0129”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+410.968481+53.11032
