RM-AB0110
RM-AB0110
    LULZBOT
    3D 打印丝 绿色(LulzBot 绿) ABS(丙烯腈丁二烯苯乙烯) 0.112"(2.85mm) 2.205 磅(1.00 kg)
RM-AB0110 数据手册
  Suited for Intermediate Users ABS by IC3D 3 mm , 1kg reel IC3D ABS is the first and only Certified Open Source Hardware 3D printer filament. IC3D has published their filament production process which includes documentation on equipment used, settings and parameters, material grade, and sources. This transparency not only shows the drive for consistency, precision, and quality, but also a committment to furthering desktop 3D printing material technology. By choosing IC3D ABS you too can help support User Freedom in the 3D printing industry. ABS is the leading thermoplastic used in consumer electronics. 3D printed ABS objects balance strength, resilience, and heat resistance. PRODUCT ALERT (2) Additional Accessory Recommendation: 3D printing in a cool or drafty environment? The LulzBot TAZ 6 Enclosure and the LulzBot Mini Enclosure by Printed Solid will help minimize warping and splitting. Inventory Note: IC3D ABS will only be restocked in Australia, Canada, and the United States. Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ 14, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ Dual Extruder, LulzBot TAZ FlexyDually, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5 Hexagon, LulzBot TAZ 1-4 Budaschnozzle, LulzBot Budaschnozzle     Colors Black Blue Green LulzBot Green Grey Natural Orange Red White Yellow  Features IC3D ABS features a precise filament diameter and roundness for consistently smooth top surface finishes and fine layer stacking. Use ABS filament when your 3D printed objects need to be strong, stiff, and flexible enough to resist breaking when stressed. ABS can also be postprocessed easily, either by sealing and painting or through solventbased methods.  Parts & Specifications Filament Specifications Filament Diameter: 3 mm (0.12 inches) Amount of Filament: 1 kg (2.2 lb), 5 lb (2.27 kg) Filament color may vary Printing Specifications Special Tool Head Requirements: LulzBot v2 All-Metal Hot End recommended Hot End Temperature Range: 235-245°C Print Surface: PEI film recommended. Print Surface Temperature: 95°C Packaging Information IC3D ABS filament ships vacuum sealed and mounted on a reel.                                                   https://www.lulzbot.com/store/filament/IC3D‐ABS 4‐5‐18
RM-AB0110 价格&库存
很抱歉,暂时无法提供与“RM-AB0110”相匹配的价格&库存,您可以联系我们找货
