Suited for Advanced Users
Alloy 910 by Taulman 3D
3 mm , 1lb reel
Specially developed to exhibit the ideal characteristics of several different classes of 3D printing
filaments, Alloy 910 offers the strength and durability of nylon with the same minimal shrink
nature of PLA and t-glase.
PRODUCT ALERT (3)
Compatibility Alert:
A tool head equipped with an all-metal hot end is required due to the high ideal printing
temperature range.
Print Surface Recommendation:
Alloy 910 is a nylon filament material, therefore applying a glue stick (such as Elmer's® brand)
directly to the print surface before starting your LulzBot 3D printer is strongly recommended for
increased printed object adhesion.
Packaging Note:
Reel diameter and packaging style may vary based on color selection. Filament weight remains
the same.
Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ Dual
Extruder, LulzBot TAZ FlexyDually, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5 Hexagon
Support: Alloy 910, 3mm Filament, 1lb Reel (Taulman)
Colors
Black
Natural
Features
Alloy 910 is among the strongest materials you can currently 3D print. When
3D printed, it has a tensile strength of 8,500 PSI, making Alloy 910 almost as
strong as Polycarbonate but easier to 3D print since it warps five times
less. Perfect for applications where high strength and stiffness is key. Use
Alloy 910 for frames or enclosures subject to stress and high impact, and
items subject to repeated flexing such as buckles and clasps. Like other
nylons, Alloy 910 has a large chemical resistance range and can even be
dyed to achieve custom color profiles using Rit® brand dye.
Parts & Specifications
Filament Specifications
Filament Diameter: 3 mm (0.12 inches)
Amount of Filament: 1 lb (0.45 kg)
Filament color may vary
Printing Specifications
Special Tool Head Requirements: LulzBot Hexagon Hot End
recommended
Hot End Temperature Range: 245°C-250°C
Print Surface: PEI film recommended with a glue stick (such as
Elmer's® brand) applied to the print surface prior to powering on your
LulzBot 3D printer. Maintain the print surface by powering off your
LulzBot and cleaning the glue stick residue with a soft cloth and water.
Print Surface Temperature: 110°C
Packaging Information
Filament weight remains the same.
Alloy 910 filament ships vacuum sealed and mounted on a reel.
Storage Specifications
Store your filament in an air tight container. The use of desiccant is
encouraged as nylon filament will absorb moisture from the air.
https://www.lulzbot.com/store/filament/alloy‐910 4‐10‐18
很抱歉,暂时无法提供与“RM-NY0011”相匹配的价格&库存,您可以联系我们找货
