RM-NY0008
RM-NY0008
    LULZBOT
    3D 打印丝 0.118"(3.00mm) 1.000 磅(453.59 g)
RM-NY0008 数据手册
    Suited for Advanced Users Bridge Nylon by Taulman 3D 3 mm , 1lb reel Taulman's "Bridge" high strength Nylon co-polymer bridges the strength of Nylon 645 and the ease of printing of ABS/PLA. Items printed in Bridge Nylon filament are stronger and more resilient than parts printed in more common materials. PRODUCT ALERT (1) Print Surface Recommendation: Bridge is a nylon filament material, therefore applying a glue stick (such as Elmer's® brand) directly to the print surface before starting your LulzBot is strongly recommended Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ 14, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ Dual Extruder, LulzBot TAZ FlexyDually, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5 Hexagon, LulzBot TAZ 1-4 Budaschnozzle, LulzBot Budaschnozzle Features Since Bridge prints cleanly and easily you can print complex models that are ready to be used. The combination of strength, reduced shrinkage, and ease in printing allows you to go from 3D model to 3D printed part ready to be installed. Bridge Nylon filament adheres well to the bed when treated with a PVA glue solution (water & PVA(Polyvinyl Acetate) glue) or a PVA glue stick. Bridge Nylon warps less than Nylon 618, 645 but slightly more than ABS, and prints well at 235°C. Like other Taulman nylons, Bridge can be dyed using Rit® brand dye to achieve custom color profiles. Parts & Specifications Filament Specifications Filament Diameter: 3 mm (0.12 inches) Amount of Filament: 1 lb (0.45 kg) Filament color may vary Printing Specifications Special Tool Head Requirements: LulzBot Hexagon Hot End recommended Hot End Temperature Range: 230°C - 240°C Print Surface: PEI film recommended Print Surface Temperature: 100°C Packaging Information Bridge filament ships vacuum sealed and mounted on a reel. Storage Specifications Store your filament in an air tight container. The use of desiccant is encouraged as nylon filament will absorb moisture from the air.        https://www.lulzbot.com/store/filament/alloy‐910 4‐10‐18
RM-NY0008 价格&库存
很抱歉,暂时无法提供与“RM-NY0008”相匹配的价格&库存,您可以联系我们找货
