KT-HB0011
KT-HB0011
    LULZBOT
    LULZBOT MINI MODULAR PRINT BED H
KT-HB0011 数据手册
      Suited for Intermediate Users LulzBot Mini Modular Print Bed Heater The LulzBot Mini Modular Print Bed System ensures your LulzBot Mini is going strong for years to come with improved ease-of-maintenance, increased versatility, and better heat uniformity across the bed surface. The system is an easy and smart upgrade to any existing LulzBot Mini 3D Printer. The LulzBot Mini Modular Print Bed Heater is the lower half of the Mini Modular Print Bed System and features a silicone heat pad laminated to a stainless steel heat spreader. The heat spreader ensures uniform heat distribution across the surface of the bed.   PRODUCT ALERT (1)  Upgrading your LulzBot Mini? Get the other half of the LulzBot Mini Modular Print Bed System here. Works with: LulzBot Mini Features Stainless steel heat spreader for maximizing uniform heat distribution across the print surface. Compatible with all generations of LulzBot Mini. Parts & Specifications Parts Included (1) LulzBot Mini Modular Print Bed Heater (1) Mini Modular Bed Corners Kit o o o o o (4) Flexy Bed Corners, 8 mm x 10 mm (Compatible with LulzBot Mini's with serial number equal to or higher than KT-PR0035NA-07500 - KT-PR0035EU-7659) (4) Metric 18-8 Stainless Steel Unthreaded Spacer, 8mm OD, 10mm length (Compatible with LulzBot Mini's with serial number equal to or higher than KT-PR0035NA-07500 - KT-PR0035EU-7659) (4) M3 x 16mm Flat Head Socket Cap Screw (4) Flexy Bed Corners, 4.5 mm x 8 mm (Compatible LulzBot Mini's with serial number equal to or below KTPR0035NA-07126 - KT-PR0035EU-6703) (4) Aluminum Unthreaded Spacer, 4.5mm OD, 10mm length (Compatible LulzBot Mini's with serial number equal to or below KT-PR0035NA-07126 - KT-PR0035EU-6703)                  https://www.lulzbot.com/store/parts/lulzbot‐mini‐modular‐print‐bed‐heater 4‐11‐18
KT-HB0011 价格&库存
很抱歉,暂时无法提供与“KT-HB0011”相匹配的价格&库存,您可以联系我们找货
KT-HB0011
  • 1+763.204401+98.32686
