KT-CP0109
KT-CP0109
    LULZBOT
    LULZBOT MINI SINGLE EXTRUDER TOO
KT-CP0109 数据手册
    Suited for Intermediate Users LulzBot Mini Single Extruder Tool Head v2.1 This replacement standard tool head for the LulzBot Mini 3D printer features improved cooling through the larger heat sink fan and a redesigned extruder idler made to be stronger and more reliable. We use the popular Wade's Accessible Reloaded extruder and feature the LulzBot v2 all-metal hot end (capable of temperatures up to 300°C) mounted on our LulzBot Mini Extruder Mount. This tool head ships assembled, aligned, and with all the connections terminated for ease of installation onto the LulzBot Mini. Works with: LulzBot Mini Features Updates include the Beefy Extruder Idler, designed for strength and reliability, an updated larger heat sync cooling fan, and Moons stepper motors with modular connector plugs, all used on the latest generation of LulzBot Mini 3D printers. Parts & Specifications Parts Included LulzBot v2 All Metal Hot End Wade's Accessible Extruder LulzBot Mini Extruder Mount Tools Required 2.5mm Hex Key 4mm Hex Key Optional Printable Upgrade X-Axis Carriage Cap with Integrated Wire Management Specifications Recommended filament diameter: 3mm Hot end temperature range: 120°C - 300°C Nozzle diameter: 0.5mm Fans: Heat sink and nozzle fans included Weight: 0.73 kg (1.6 lbs)          https://www.lulzbot.com/store/tool‐heads/lulzbot‐mini‐single‐extruder‐tool‐head‐v2_1 4‐11‐18
KT-CP0109 价格&库存
很抱歉,暂时无法提供与“KT-CP0109”相匹配的价格&库存,您可以联系我们找货
