Suited for Advanced Users
PC-ABS Alloy by Proto-pasta
3 mm , 500g reel
Stronger than ABS and more wear resistant, PC-ABS Alloy brings strength
and high temperature resistance to ABS 3D printing filament.
PRODUCT ALERT (2)
Compatibility Alert:
A tool head equipped with an all-metal hot end is required due to the high
ideal printing temperature range.
Print Surface Recommendation:
Applying a glue stick (such as Elmer's® brand) directly to the print surface
before starting your LulzBot 3D printer is strongly recommended for increased
printed object adhesion.
Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ/Mini
Aerostruder, LulzBot TAZ Dual Extruder, LulzBot TAZ FlexyDually, LulzBot
Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5 Hexagon
Colors
Black
Natural
Features
By combining the bonding properties of ABS with the strength and
higher extrusion temperature of polycarbonate, this premium alloy is
perfect for small parts ready for use in the field. Choose PC-ABS Alloy
for custom brackets, connectors, clasps, and housings .
Parts & Specifications
Filament Specifications
Filament Diameter: 2.85 mm (0.11 inches)
Amount of Filament: 500 g (1.1 lbs)
Average Length of Filament: 77 m
Filament color may vary
Printing Specifications
Special Tool Head Requirements: LulzBot Hexagon Hot End
recommended
Hot End Temperature Range: 260°C-280°C
Print Surface: PEI film recommended with a glue stick (such as UHU®
brand) applied to the print surface prior to powering on your LulzBot.
Maintain the print surface by powering off your LulzBot and cleaning the
glue stick residue with a soft cloth and water.
Print Surface Temperature: 110°C
Packaging Information
PC-ABS Alloy filament ships vacuum sealed and mounted on a reel.
Storage Specifications
Store your filament in an air tight container. The use of desiccant is
encouraged as this filament will absorb moisture from the air.
https://www.lulzbot.com/store/filament/pc‐abs‐alloy 4‐11‐18
很抱歉,暂时无法提供与“RM-PY0003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+359.700721+44.99032
