RM-PY0011
RM-PY0011
    LULZBOT
    3D 打印丝 黑色 PC-PBT(聚碳酸酯-PBT 合金) 0.112"(2.85mm) 1.653 磅(750.0 g)
RM-PY0011 数据手册
    PC+PBT by Push Plastic 3 mm , 750g reel PC+PBT is a polycarbonate filament alloy from Push Plastic that excels in balancing print stiffness, structural integrity, and impact strength with superb filament ductility. PC+PBT filament produces sturdy, quality prints with excellent fatigue performance and a high chemical resistance to motor oil and grease. Print Surface Recommendation: PC+PBT filament is a polycarbonate-based material, therefore applying a glue stick (such as Elmer's® brand) directly to the print surface before starting your LulzBot 3D printer is strongly recommended for increased printed object adhesion.     Works with: LulzBot Mini 2, LulzBot Mini 1, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ/Mini Aerostruder, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5 Hexagon This polycarbonate alloy material produces smooth prints with excellent structural integrity and a high chemical resistance to motor oil and grease, making it ideal for industrial applications in need of long-term fatigue performance (i.e. 3D printed PC+PBT dirt bike parts from MotoMinded LLC). Filament Specifications Filament Diameter: 2.85mm (0.11 inches) Amount of Filament: 750g (1.65 lbs) Filament Colors: Black and White Printing Specifications Hot End Temperature Range: 235°C-255°C Print Surface: 110°C-120°C; PC+PBT filament is a polycarbonate-based material, therefore applying a glue stick (such as Elmer's® brand) directly to the print surface before starting your LulzBot 3D printer is strongly recommended for increased printed object adhesion. Packaging Information PC+PBT filament ships vaccum sealed and mounted on a reel. Storage Information Store your filament in an air tight container. The use of desiccant is especially encouraged in humid environments as PC+PBT filament will absorb moisture from the air. Print Profiles Get the most up-to-date print profiles, including hot end and print bed temperatures, by updating to the latest version of Cura LulzBot Edition software:         Black        White        https://www.lulzbot.com/store/filament/pcpbt 11‐19‐18
RM-PY0011 价格&库存
很抱歉,暂时无法提供与“RM-PY0011”相匹配的价格&库存,您可以联系我们找货
RM-PY0011
  • 1+493.659011+63.77690
库存:5
