RM-PE0014
RM-PE0014
    LULZBOT
    3D 打印丝 红色 PETG(改性聚对苯二甲酸乙二醇酯) 0.118"(3.00mm) 2.205 磅(1.00 kg)
RM-PE0014 数据手册
      Suited for Intermediate Users PETg by IC3D 3 mm , 1kg reel This IC3D filament combines high strength with high ductility. Medical braces, bottles, mechanical parts, and robotics are ideal applications for PETg 3D printer filament. Because the finished prints bear a bright, eye-catching sheen, this filament is also perfect for artistic endeavors like jewelry, vases, and decorative items. The low shrink rate of this PETg 3D printer filament makes it a perfect choice for large prints.     IC3D is the first and only Open Source Hardware filament manufacturer. By purchasing IC3D filament, you support User Freedom and the advancement of desktop 3D printing. Works with: LulzBot Mini 2, LulzBot Mini 1, LulzBot TAZ 6, LulzBot TAZ/Mini Aerostruder v2 Micro, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ 6 Hexagon IC3D PETg combines the dimensional stability of PLA with the strength of ABS, making it an excellent choice for industrial applications. This material is ideal for snap-fit prints that require a high degree of precision. Use PETg filament when your 3D printed objects need to be strong, stiff, and flexible enough to resist breaking when stressed. Filament Specifications Filament Diameter: 3 mm (0.12 inches) Amount of Filament: 1 kg (2.2 lb), 5 lb (2.27 kg) Filament color may vary Printing Specifications Hot End Temperature Range: 230°C Print Surface: PEI film recommended. Print Surface Temperature: 70°C Packaging Information IC3D PETg filament ships vacuum sealed and mounted on a reel                    Black                                       Blue                                       Red                                      White        https://www.lulzbot.com/store/filament/ic3d‐petg 11‐19‐18
RM-PE0014 价格&库存
很抱歉,暂时无法提供与“RM-PE0014”相匹配的价格&库存,您可以联系我们找货
