Suited for Intermediate Users
PETg by IC3D
3 mm , 1kg reel
This IC3D filament combines high strength with high ductility. Medical braces,
bottles, mechanical parts, and robotics are ideal applications for PETg 3D
printer filament. Because the finished prints bear a bright, eye-catching sheen,
this filament is also perfect for artistic endeavors like jewelry, vases, and
decorative items. The low shrink rate of this PETg 3D printer filament makes it
a perfect choice for large prints.
IC3D is the first and only Open Source Hardware filament manufacturer. By
purchasing IC3D filament, you support User Freedom and the advancement
of desktop 3D printing.
Works with: LulzBot Mini 2, LulzBot Mini 1, LulzBot TAZ 6, LulzBot TAZ/Mini
Aerostruder v2 Micro, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ 6 Hexagon
IC3D PETg combines the dimensional stability of PLA with the strength of
ABS, making it an excellent choice for industrial applications. This material
is ideal for snap-fit prints that require a high degree of precision. Use PETg
filament when your 3D printed objects need to be strong, stiff, and flexible
enough to resist breaking when stressed.
Filament Specifications
Filament Diameter: 3 mm (0.12 inches)
Amount of Filament: 1 kg (2.2 lb), 5 lb (2.27 kg)
Filament color may vary
Printing Specifications
Hot End Temperature Range: 230°C
Print Surface: PEI film recommended.
Print Surface Temperature: 70°C
Packaging Information
IC3D PETg filament ships vacuum sealed and mounted on a reel
Black Blue Red White
https://www.lulzbot.com/store/filament/ic3d‐petg 11‐19‐18
很抱歉,暂时无法提供与“RM-PE0012”相匹配的价格&库存,您可以联系我们找货
