KT-CP0108
KT-CP0108
    LULZBOT
    LULZBOT TAZ MOARSTRUDER TOOL HEA
KT-CP0108 数据手册
  Suited for Advanced Users LulzBot TAZ MOARstruder Tool Head Bigger. Faster. Stronger. MOAR: The LulzBot TAZ MOARstruder Tool Head is a high output tool head with an extra-long heater block, dual print cooling fans, and a 1.2 mm diameter nozzle. These features enable high-speed printing and tough 3D printed objects. PRODUCT ALERT (1)  Compatibility Alert! TAZ 5 users with a tool head wiring harness with four (4) connectors will need an additional accessory: LulzBot TAZ 5 v2c Tool Head Harness Works with: LulzBot TAZ 6, LulzBot TAZ 5 Features This high-output tool head uses an extra-long heater block and a 1.2 nozzle diameter to increase the 3D printing rate to over 100 grams an hour-- that's a kilogram (2.2 pounds) in 10 hours, and over 2.27 kilograms (5 pounds) of filament in a 24 hour period. Further improvements include a stronger extruder idler latch and a stiffer tool head mount. The LulzBot TAZ MOARstruder Tool Head is perfect for large objects that utilize the full build area of the LulzBot TAZ, due to the large nozzle diameter. This allows for layer heights of 0.3 mm to 1.2 mm and for thicker extrusion widths, leading to stronger internal structures and single-walled printed objects, like vases, pipes, and containers. 3D print with smaller layers for strong walls and infill. Larger layer heights will be translucent, shiny, and MOAR eye-catching when used with translucent filament such as t-glase, nGen, and INOVA-1800. Parts & Specifications Parts Included LulzBot TAZ MOARstruder Tool Head v2 (Fully Assembled) Wade's Accessible Extruder LulzBot TAZ Extruder Mount t-glase sample material for first print M3 mounting screw, 20 mm (0.79 in) long, with washer Specifications Required filament diameter: 3 mm Hot end temperature range: 120°C - 300°C Recommended Layer Heights: 0.3 mm (0.01 in) - 1.2 mm (0.05 in) Nozzle diameter: 1.2 mm Required power system: 24 V Fans: Heat sink and dual print-cooling fans included Recommended Filament for Large Scale Objects The following filament options work well at large, full build volume-scales. o o o o o INOVA-1800 nGen PLA PolyLite PLA t-glase Discouraged Filament for Large Scale Objects Avoid using the following filament when printing at larger scales, due to shrinking or warping when printed. o o o o ABS colorFabb_HT HIPS Nylon Alloy 910 o o o Polycarbonate PC-Max (Larger prints may crack) PCTPE (Avoid older, moisture-laden filament)                    https://www.lulzbot.com/store/tool‐heads/lulzbot‐taz‐moarstruder‐tool‐head 4‐11‐18
KT-CP0108
物料型号为LulzBot TAZ MOARstruder Tool Head v2。
该工具头是为高级用户设计的,具有高输出性能,配备了超长加热块、双打印冷却风扇和1.2毫米直径的喷嘴。
这使得3D打印速度更快,能够打印出更坚固的物体。
器件简介如下: - LulzBot TAZ MOARstruder Tool Head v2配备了一个额外长的加热块和1.2毫米直径的喷嘴,可以提高3D打印速度至每小时超过100克,相当于10小时内1公斤(2.2磅),24小时内超过2.27公斤(5磅)的丝材。
- 该工具头还具有更强大的挤出机怠速锁和更坚固的工具头安装座。
引脚分配参数特性: - 需要的丝材直径:3毫米 - 热端温度范围:120°C - 300°C - 推荐层高:0.3毫米(0.01英寸)- 1.2毫米(0.05英寸) - 喷嘴直径:1.2毫米 - 所需电源系统:24 V - 风扇:包括散热器和双打印冷却风扇
功能详解: - 该工具头适合打印大型物体,可以利用LulzBot TAZ的整个构建区域。
大喷嘴直径允许层高在0.3毫米到1.2毫米之间,并且可以挤出更宽的丝材,从而实现更强的内部结构和单壁打印物体,如花瓶、管道和容器。
- 使用较小层高进行3D打印,可以获得强壁和填充。
应用信息: - 推荐用于大型物体的丝材包括INOVA-1800、nGen、PLA、PolyLite PLA和t-glase。
- 避免用于大型物体的丝材包括ABS、colorFabb_HT、HIPS、Nylon Alloy 910、Polycarbonate、PC-Max(较大的打印物可能会破裂)和PCTPE(避免使用较旧、含水的丝材)。
封装信息: - 包装内包括LulzBot TAZ MOARstruder Tool Head v2(完全组装)、Wade的可访问挤出机、LulzBot TAZ挤出机安装座、首次打印用t-glase样品材料、M3安装螺钉(20毫米(0.79英寸)长,带垫圈)。
更多详细信息和购买链接可以访问LulzBot的官方网站。
KT-CP0108 价格&库存
很抱歉,暂时无法提供与“KT-CP0108”相匹配的价格&库存,您可以联系我们找货
