KT-HB0013
KT-HB0013
    LULZBOT
    LULZBOT TAZ MODULAR PRINT BED HE
KT-HB0013 数据手册
  Suited for Intermediate Users LulzBot TAZ Modular Print Bed Heater The LulzBot TAZ Modular Print Bed System ensures your LulzBot TAZ is going strong for years to come with improved ease-ofmaintenance, increased versatility, and better heat uniformity across the bed surface. The system is an easy and smart upgrade to a LulzBot TAZ 3D Printer (compatible with 24-volt versions only, TAZ 36). The LulzBot TAZ Modular Print Bed Heater is the lower half of the TAZ Modular Print Bed System and features a silicone heat pad laminated to a stainless steel heat spreader. The heat spreader ensures uniform heat distribution across the surface of the bed. PRODUCT ALERT (2)  Upgrading your LulzBot TAZ? Get the other half of the LulzBot TAZ Modular Print Bed System here. TAZ 3 - 5 Users Users with LulzBot TAZ 3D Printers generations 3 - 5 will need to 3D print adjusted bed corners, and use a soldering iron to transfer or install M30.5 x3.8 mm heatset inserts into the new corners. Works with: LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ 4, LulzBot TAZ 3 Features Stainless steel heat spreader for maximizing uniform heat distribution across the print surface. Compatible with all 24-volt LulzBot TAZ 3D Printers (TAZ 3 through TAZ 6). Parts & Specifications Parts Included (1) LulzBot TAZ Modular Print Bed Heater (1) Wire tie Additional Parts Required TAZ 3 - 5 Users (1) TAZ 5 Bed Corners for Modular Print Bed System (not included - print yourself)                    https://www.lulzbot.com/store/parts/lulzbot‐taz‐modular‐print‐bed‐heater 4‐11‐18
KT-HB0013 价格&库存
很抱歉,暂时无法提供与“KT-HB0013”相匹配的价格&库存,您可以联系我们找货
KT-HB0013
  • 1+1099.324651+142.02418
