0985 656 500/0.5M
0985 656 500/0.5M
    BELDEN
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 1.64'(500.0mm) 双屏蔽
0985 656 500/0.5M 数据手册
Be Certain with Belden EtherMATE™ Industrial Ethernet Double-Ended Cord Sets High-Flex/High Noise, Stranded/Shielded, 24 AWG, PVC Jacket Type 0985 656 103 0985 656 104 0985 656 500 M12 to RJ45 M12 (receptacle) to RJ45 RJ45 to RJ45 Industrial Ethernet double-ended cord set, high-flex, male, M12 to RJ45 straight, 4-pair, 24 AWG, PVC cable, stranded/shielded with teal jacket and orange inserts. Industrial Ethernet, double-ended cord set, high-flex, M12 female receptacle to RJ45 male, 4-pair, 24 AWG, PVC cable, stranded/shielded, with teal jacket. Configuration Product Description 0985 656 504 RJ45 to RJ45 (crossover) Industrial Ethernet double-ended cord set, high-flex, male, RJ45 to RJ45 straight, 4-pair, 24 AWG, PVC cable, stranded/shielded with teal jacket. Category Rating Industrial Ethernet double-ended cord set, high-flex, male, RJ45 to RJ45 straight, 4-pair, 24 AWG, PVC cable, stranded/shielded crossover with teal jacket. CAT5e Technical Illustration Wiring diagram M12 6 4 1 7 5 8 2 3 Nut Color White/Orange Orange White/Blue Blue White/Green Green White/Brown Brown Shield RJ45 1 2 5 4 3 6 7 8 Shell M12 6 4 1 7 5 8 2 3 Nut Color White/Orange Orange White/Blue Blue White/Green Green White/Brown Brown Shield RJ45 1 2 5 4 3 6 7 8 Shell RJ45 1 2 5 4 3 6 7 8 Shell Color White/Orange Orange White/Blue Blue White/Green Green White/Brown Brown Shield RJ45 1 2 5 4 3 6 7 8 Shell RJ-45S 1 2 5 4 3 6 7 8 Shield Color White/Orange Orange White/Blue Blue White/Green Green White/Brown Brown Shield RJ-45S 3 6 5 4 1 2 7 8 Shield Face views Part number 0985 656 103/...M 0985 656 104/...M 0985 656 500/...M 0985 656 504/...M 0.3 M / 0.5 M / 1 M / 2 M / 3 M / 4 M / 5 M / 10 M / 15 M / 20 M 0.5 M / 1 M / 2 M / 5 M / 10 M / 15 M / 20 M 0.3 M / 0.5 M / 1 M / 2 M / 3 M / 4 M / 5 M / 10 M / 15 M / 20 M / 25 M/ 30 M / 35 M / 40 M / 45 M / 50 M / 55 M / 60 M / 65 M / 70 M / 75 M / 80 M / 85 M / 90 M 0.6 M / 1 M / 2 M / 5 M / 10 M / 15 M / 30 M Standard cable lengths www.lumberg-automationusa.com 800-235-3361 or 1-800-BELDEN1 53 EtherMATE™ Industrial Ethernet Double-Ended Cord Sets High-Flex/High Noise, Stranded/Shielded, 24 AWG, PVC Jacket Type 0985 656 103 0985 656 104 Degree of protection Operating temperature range 0985 656 500 IP67 / IP20 0985 656 504 IP20 -20°C(-4°F) to +75°C(+167°F) Mechanical M12 Molded body Coupling nut Contacts Insert PUR, black Brass, nickel plated Brass, gold over nickel plated PUR orange M12 Receptacle Housing Insert Contacts Brass, nickel plated PUR, black Brass, gold plated RJ45 Housing Insert Contacts Pre-tinned copper alloy Clear polycarbonate 50 μ” gold in contact area over nickel plating Cable specifications Cable jacket Color Overall diameter Conductor Number of pairs Insulation Foil shield Braided shield EMI protection Agency approval Cable type Safety Voltage Rating (for cable) PVC, (sun and oil resistant) Teal 7.77mm, nominal 24 AWG, 7 strands tinned copper 4 Polyethylene Aluminum/polypropylene tape, 100% coverage Tinned copper, 65% coverage 50 dB @ 0.772 MHz - 1000 MHz ETL rated CMR CAT5, high flex / high noise (0985 656 500/504 CAT5e) Characteristics NOTE: Vibration & Oil Resistant applies to M12 side only. Recommended panel cut out The application of these products in harsh environments should always be checked before use. Specifications subject to alteration. 54 800-235-3361 or 1-800-BELDEN1 www.lumberg-automationusa.com
0985 656 500/0.5M 价格&库存
很抱歉,暂时无法提供与“0985 656 500/0.5M”相匹配的价格&库存,您可以联系我们找货
