RST 5L-RKT 5L-949/10 M
    BELDEN
    缆线组件 32.8'(10.00m)
RST 5L-RKT 5L-949/10 M 数据手册
Datasheet The information/details in this datasheet merely contain general descriptions or performance factors which, when applied in an actual situation, do not always correspond with the described form, and may be amended by way of the further development of products. The desired performance factors shall only be binding if these are expressly agreed on conclusion of the contract. Datasheet-No. 934-853-999 EN Revison: 07 Type: Created: 2016-10-05 pkuhn RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended Page: 1 of 7 Datasheet Product description - M12-Power cordset, double ended - knurled screw with self-locking threaded joint - Optional 360° shielding connected to knurled screw RST(S) …. - RKT(S) / RKWT(S) /… M, see standard products male - female 5 (4+PE):, K - Coding 5 (4+FE):, L - Coding 4 (3+PE):, S - Coding 4:, T - Coding IEC 61076-2-111 K-, L-, S- or T-coded 1,5 mm² K: blue L: grey S: black T: dark-grey Type Type of contacts Number of contacts Standard Construction type Conductor size Color contact bearer Further information see datasheets: RKT(S)-… , M12 female connector straight datasheet number: 934-849-999 RKWT(S)-… , M12 female connector angled datasheet number: 934-850-999 RST(S)-… , M12 male connector straight datasheet number: 934-851-999 RSWT(S)-… , M12 male connector angled datasheet number: 934-852-999 Technical data Clearance / Creepage distance Rated voltage Operating voltage DIN EN 60664-1 (2008/01); VDE 0110-1 see table, page 1 600 V ac/dc, K- / S-Coding 50 V ac / 60 V dc, L- / T-Kodierung Rated current * Rated impulse voltage Pollution degree Contact resistance Insulation resistance Mating cycles 16 A; 1,5 mm² see table, page 1 3 acc. to DIN EN 60664-1 (VDE 0110-1) ≤ 10 mΩ > 10^9 Ohm max. 100 * Notice derating Datasheet-No. 934-853-999 EN Revison: 07 Type: Created: 2016-10-05 pkuhn RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended Page: 2 of 7 Datasheet Materials Contact Contact plating Contact bearer over molding Coupling screw O-ring Surface coupling screw Shielding sleeve CuNi Cu/Au PBT GF TPE, blue or black CuZn FKM Cu/Ni CuZn, plating: Ni Environmental conditions Protection class (IEC 60529) * Temperature range (connector) IP65, IP67 -40 °C to +125 °C, notice derating * only if mounted and locked in combination with Hirschmann / Lumberg connector. Flammability class over molding Contact bearer UL 94 HB UL 94 V-2 Approvals VDE UL DIN EN 61984: in preparation UL 2238, E315587 Additional technical data Fastening torque (coupling nut) Fastening torque (coupling screw) M 12x1: (50-60) Ncm, hand-light M 12x1: (50-60) Ncm, hand-light Cutline Do not connect / disconnect under load. Caution hot! Under power the surface of the connector can reach a temperature of more then 56 °C (144 °F). The specified electrical and mechanical characteristics require a properly locked connector. When the connetor is unlocked and in risk of pollution the connector has to be covered with a protective cap ≥ IP54. "L" = standard length of control line Datasheet-No. 934-853-999 EN Revison: 07 Type: Created: 2016-10-05 pkuhn RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended Page: 3 of 7 Datasheet Datasheet-No. 934-853-999 EN Revison: 07 Type: Created: 2016-10-05 pkuhn RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended Page: 4 of 7 Datasheet Standard products Artikel-No. 934-853-001 934-853-002 934-853-003 934-853-004 934-853-005 934-853-006 934-853-007 934-853-008 934-853-009 934-853-010 934-853-011 934-853-012 934-853-013 934-853-014 934-853-015 934-853-016 934-853-017 934-853-018 934-853-025 934-853-026 934-853-027 934-853-028 934-853-029 934-853-030 934-853-037 934-853-038 934-853-039 934-853-040 934-853-041 934-853-042 934-853-043 934-853-044 934-853-045 934-853-046 934-853-047 934-853-048 934-853-049 934-853-050 934-853-051 934-853-052 934-853-053 934-853-054 934-853-081 934-853-082 934-853-083 934-853-084 934-853-085 934-853-086 934-853-087 934-853-088 934-853-089 934-853-090 934-853-091 934-853-092 934-853-093 934-853-094 934-853-095 934-853-096 934-853-097 934-853-098 Type Rated voltage Rated impulse voltage Cable size RST 4S-RKT 4S-703/2 M RST 4S-RKT 4S-703/5 M RST 4S-RKT 4S-703/10 M RST 4S-RKT 4S-733/2 M RST 4S-RKT 4S-733/5 M RST 4S-RKT 4S-733/10 M RST 4S-RKWT 4S-703/2 RST 4S-RKWT 4S-703/5 RST 4S-RKWT 4S-703/10 RST 4S-RKWT 4S-733/2 RST 4S-RKWT 4S-733/5 RST 4S-RKWT 4S-733/10 RST 4T-RKT 4T-723/0,3 M RST 4T-RKT 4T-723/0,6 M RST 4T-RKT 4T-723/1 M RST 4T-RKT 4T-723/2 M RST 4T-RKT 4T-723/5 M RST 4T-RKT 4T-723/10 M RST 4T-RKWT 4T-723/0,3 RST 4T-RKWT 4T-723/0,6 RST 4T-RKWT 4T-723/1 RST 4T-RKWT 4T-723/2 RST 4T-RKWT 4T-723/5 RST 4T-RKWT 4T-723/10 RST 5K-RKT 5K-911/2 M RST 5K-RKT 5K-911/5 M RST 5K-RKT 5K-911/10 M RST 5K-RKT 5K-735/2 M RST 5K-RKT 5K-735/5 M RST 5K-RKT 5K-735/10 M RST 5K-RKT 5K-736/2 M RST 5K-RKT 5K-736/5 M RST 5K-RKT 5K-736/10 M RST 5K-RKWT 5K-911/2 RST 5K-RKWT 5K-911/5 RST 5K-RKWT 5K-911/10 RST 5K-RKWT 5K-735/2 RST 5K-RKWT 5K-735/5 RST 5K-RKWT 5K-735/10 RST 5K-RKWT 5K-736/2 RST 5K-RKWT 5K-736/5 RST 5K-RKWT 5K-736/10 RSTS 4S-RKTS 4S-700/2 RSTS 4S-RKTS 4S-700/5 RSTS 4S-RKTS 4S-700/1 RSTS 4S-RKTS 4S-915/2 RSTS 4S-RKTS 4S-915/5 RSTS 4S-RKTS 4S-915/1 RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-915/ RSTS 4S-RKWTS 4S-915/ RSTS 4S-RKWTS 4S-915/ RSTS 4T-RKTS 4T-722/0, RSTS 4T-RKTS 4T-722/0, RSTS 4T-RKTS 4T-722/1 RSTS 4T-RKTS 4T-722/2 RSTS 4T-RKTS 4T-722/5 RSTS 4T-RKTS 4T-722/10 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² Datasheet-No. 934-853-999 EN Revison: 07 Type: Created: 2016-10-05 pkuhn RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended Page: 5 of 7 Datasheet 934-853-105 934-853-106 934-853-107 934-853-108 934-853-109 934-853-110 934-853-117 934-853-118 934-853-119 934-853-120 934-853-121 934-853-122 934-853-123 934-853-124 934-853-125 934-853-126 934-853-127 934-853-128 934-853-159 934-853-160 934-853-161 934-853-162 934-853-163 934-853-164 934-853-165 934-853-166 934-853-167 934-853-168 934-853-170 934-853-171 934-853-172 934-853-173 934-853-174 934-853-175 934-853-301 934-853-302 934-853-303 934-853-304 934-853-305 934-853-306 934-853-307 934-853-308 934-853-309 934-853-310 934-853-311 934-853-312 934-853-313 934-853-314 934-853-315 934-853-316 934-853-317 934-853-318 934-853-325 934-853-326 934-853-327 934-853-328 934-853-329 934-853-330 934-853-337 934-853-338 934-853-339 934-853-340 934-853-341 RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 5K-RKTS 5K-910/2 RSTS 5K-RKTS 5K-910/5 RSTS 5K-RKTS 5K-910/1 RSTS 5K-RKTS 5K-916/2 RSTS 5K-RKTS 5K-916/5 RSTS 5K-RKTS 5K-916/1 RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-916/ RSTS 5K-RKWTS 5K-916/ RSTS 5K-RKWTS 5K-916/ RSTS 5K-RKTS 5K-910/0, RSTS 5K-RKTS 5K-910/3, RSTS 5K-RKTS 5K-910/7, RSTS 5K-RKTS 5K-910/1 RST 5L-RKT 5L-949/0,3 M RST 5L-RKT 5L-949/0,6 M RST 5L-RKT 5L-949/1 M RST 5L-RKT 5L-949/2 M RST 5L-RKT 5L-949/5 M RST 5L-RKT 5L-949/10 M RST 5L-RKWT 5L-949/0,3 RST 5L-RKWT 5L-949/0,6 RST 5L-RKWT 5L-949/1 RST 5L-RKWT 5L-949/2 RST 5L-RKWT 5L-949/5 RST 5L-RKWT 5L-949/10 RST 4S-RKT 4S-703/2 M RST 4S-RKT 4S-703/5 M RST 4S-RKT 4S-703/10 M RST 4S-RKT 4S-733/2 M RST 4S-RKT 4S-733/5 M RST 4S-RKT 4S-733/10 M RST 4S-RKWT 4S-703/2 RST 4S-RKWT 4S-703/5 RST 4S-RKWT 4S-703/10 RST 4S-RKWT 4S-733/2 RST 4S-RKWT 4S-733/5 RST 4S-RKWT 4S-733/10 RST 4T-RKT 4T-723/0,3 M RST 4T-RKT 4T-723/0,6 M RST 4T-RKT 4T-723/1 M RST 4T-RKT 4T-723/2 M RST 4T-RKT 4T-723/5 M RST 4T-RKT 4T-723/10 M RST 4T-RKWT 4T-723/0,3 RST 4T-RKWT 4T-723/0,6 RST 4T-RKWT 4T-723/1 RST 4T-RKWT 4T-723/2 RST 4T-RKWT 4T-723/5 RST 4T-RKWT 4T-723/10 RST 5K-RKT 5K-911/2 M RST 5K-RKT 5K-911/5 M RST 5K-RKT 5K-911/10 M RST 5K-RKT 5K-735/2 M RST 5K-RKT 5K-735/5 M Datasheet-No. 934-853-999 EN Revison: 07 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V Type: Created: 2016-10-05 pkuhn 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6,0 kV 6,0 kV 6,0 kV 6,0 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² Page: 6 of 7 Datasheet 934-853-342 934-853-343 934-853-344 934-853-345 934-853-346 934-853-347 934-853-348 934-853-349 934-853-350 934-853-351 934-853-352 934-853-353 934-853-354 934-853-381 934-853-382 934-853-383 934-853-384 934-853-385 934-853-386 934-853-387 934-853-388 934-853-389 934-853-390 934-853-391 934-853-392 934-853-393 934-853-394 934-853-395 934-853-396 934-853-397 934-853-398 934-853-405 934-853-406 934-853-407 934-853-408 934-853-409 934-853-410 934-853-417 934-853-418 934-853-419 934-853-420 934-853-421 934-853-422 934-853-423 934-853-424 934-853-425 934-853-426 934-853-427 934-853-428 RST 5K-RKT 5K-735/10 M RST 5K-RKT 5K-736/2 M RST 5K-RKT 5K-736/5 M RST 5K-RKT 5K-736/10 M RST 5K-RKWT 5K-911/2 RST 5K-RKWT 5K-911/5 RST 5K-RKWT 5K-911/10 RST 5K-RKWT 5K-735/2 RST 5K-RKWT 5K-735/5 RST 5K-RKWT 5K-735/10 RST 5K-RKWT 5K-736/2 RST 5K-RKWT 5K-736/5 RST 5K-RKWT 5K-736/10 RSTS 4S-RKTS 4S-700/2 RSTS 4S-RKTS 4S-700/5 RSTS 4S-RKTS 4S-700/1 RSTS 4S-RKTS 4S-915/2 RSTS 4S-RKTS 4S-915/5 RSTS 4S-RKTS 4S-915/1 RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-700/ RSTS 4S-RKWTS 4S-915/ RSTS 4S-RKWTS 4S-915/ RSTS 4S-RKWTS 4S-915/ RSTS 4T-RKTS 4T-722/0, RSTS 4T-RKTS 4T-722/0, RSTS 4T-RKTS 4T-722/1 RSTS 4T-RKTS 4T-722/2 RSTS 4T-RKTS 4T-722/5 RSTS 4T-RKTS 4T-722/10 RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 4T-RKWTS 4T-722/ RSTS 5K-RKTS 5K-910/2 RSTS 5K-RKTS 5K-910/5 RSTS 5K-RKTS 5K-910/1 RSTS 5K-RKTS 5K-916/2 RSTS 5K-RKTS 5K-916/5 RSTS 5K-RKTS 5K-916/1 RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-910/ RSTS 5K-RKWTS 5K-916/ RSTS 5K-RKWTS 5K-916/ RSTS 5K-RKWTS 5K-916/ Datasheet-No. 934-853-999 EN Revison: 07 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V Type: Created: 2016-10-05 pkuhn 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV RS(W)T(S) … - RK(W)T(S) …-.../… M Cord set double ended 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² Page: 7 of 7
RST 5L-RKT 5L-949/10 M 价格&库存
很抱歉,暂时无法提供与“RST 5L-RKT 5L-949/10 M”相匹配的价格&库存,您可以联系我们找货
