CFR1/2WK
CFR1/2WK
    LUMIMAX
    炭膜 电阻器套件 10 ~ 1M 欧姆 ±5% 1/2W 通孔 160 件(32 个值 - 每个值 5 件)
CFR1/2WK 数据手册
Lumimax Optoelectronic Technology CF Series Carbon Film Fixed Resistors CFR1WK: Carbon Film 1W Resistor Sample Kit * 32 resistor values, 0~10M ohm CFR1/4WK: Carbon Film 1/4W Resistor Sample Kit * 32 resistor values, 0~10M ohm CFR1/2WK: Carbon Film 1/2W Resistor Sample Kit * 32 resistor values, 10~1M ohm CFR1/8WK: Carbon Film 1/8W Resistor Sample Kit * 32 resistor values, 10~10M ohm Note: * for Resistor values inside each sample kit, please refer to the last page of spec. sheet for details. Product Features • • • • • • Excellent long-term stability Wide Resistance range 0.1Ω ~ 10MΩ Power ratings from 1/8W to 3Ws Products with lead-free terminations meet EU RoHS and China RoHS requirements All general purpose and Power applications AECQ-200 Qualified Pb-Free and RoHS Compliant Power rating and Dimensions Style CF-1/8W CF-1/4W CF-1/2W CF-1W CF-2W L 3.3 + 0.4 ~-0.2 6.3 ± 0.5 9.0 ± 0.5 11.5 ± 1.0 15.5 ± 1.0 Dimensions (mm) D 1.8 ± 0.3 2.3 ± 0.3 3.2 ± 0.5 4.5 ± 0.5 5.0 ± 0.5 H 29 ± 2.0 28 ± 2.0 26 ± 2.0 35 ± 2.0 32 ± 2.0 d 0.45 ± 0.03 0.55 ± 0.03 0.65 ± 0.03 0.78 ± 0.03 0.78 ± 0.03 44611 S. Grimmer Blvd., Fremont, CA 94538 tel: 510-241-9686 www.lumimaxusa.com ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. Electronical Characteristics Power rating at 70°C Body Size (D x L mm) (D x L inch) Operating temp. range Max. working voltage Max. overload voltage Dielectric withstanding voltage Value range ± 5% 1/8W 1.8 x 3.3 0.071 x 0.13 150V 300V 300V 1/4W 1/2W 2.3 x 6.3 3.2 x 9.0 0.091 x 0.248 0.126 x 0.354 -55°C + 155°C 250V 350V 500V 700V 500V 700V 1W 4.5 x 11.5 0.177 x 0.453 2W 5.0 x 15.5 0.197 x 0.61 450V 1000V 1000V 500V 1000V 1000V E6 series 0.1Ω ~ 0.68Ω ; E24 series 1Ω ~ 22MΩ Derating Curve Temperature Coefficient (T.C.R.) CF series 1W, 2W 1/8W, 1/4W, 1/2W Under 1Ω ± 1500 ± 1500 Max. Value of Temp. Coefficient ppm/°C 1Ω to 100KΩ 100KΩ to 1MΩ 1MΩ to 10MΩ ± 350 -500~0 -1500 ~ 0 -500 ~350 -700~0 -1500 ~ 0 Test and Requirements Performance test Short time overload Temperature Coefficient (TCR) Dielectric withstanding voltage Test Method JIS-C-5202 5.5 2.5 times RCWV for 5 seconds Resistance value at room temperature and room temperature +100°C JIS-C5202 5.7 In V-Block for 60 seconds Appraise ±(0.75%+0.05Ω) page By type 44611 S. Grimmer Blvd., Fremont, CA 94538 tel: 510-241-9686 www.lumimaxusa.com ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. Pulse overload JIS-C5202 5.8 ± (1% +0.05Ω) 4 times RCWV for 10000 cycles (1 sec. on, 25 secs. Off) Insulation resistance JIS-C5202 5.6 In V-Block >10000MΩ Load life JIS-C5202 7.10 ± (3%+0.05Ω) 70°C at RCWV for 1000 hours (1.5 hrs on, 0.5 hrs. off) Load life in humidity JIS-C5202 7.9 Less than 100KΩ± 40°C± 2°C 90~95% RH at RCWV for 1000 hours 3%. 100KΩ or (1.5 hrs on, 0.5 hrs. off) more ± 5%. Soler ability JIS-C5202 6.5 95% min. coverage 260°C± 5°C for 2±0.5 seconds Resistance to solvent JIS-C5202 6.9 No deterioration Specimens shall be immersed in a bath of of coatings and alcohol completely for 3 mins. Using ultrasonic markings. test equipment. Terminal strength Direct load for 10 sec. in the direction off the Tensile: ≥ 2.5kg terminal leads. Note: RCWV: Rated Continuous Working Voltage = √Power rating x Resistance value Resistor body color Normal size 1/8W to 2W: Khaki color Part Number CF 1W 2K J T Type Power rating Resistance Tolerance Packaging CF – Carbon film 1/8W 1/4W 1/2W 1W 2W 1R = 1Ω 10R = 10Ω 2K = 2KΩ 3K3 = 3.3KΩ 10M = 10MΩ J = ± 5% G = ± 2% TB = Taping in box TR = Taping in reel BU = Bulk T = Cut Taped 44611 S. Grimmer Blvd., Fremont, CA 94538 tel: 510-241-9686 www.lumimaxusa.com ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. Tape on box packing 1/2W, 1W and 2W Resistor 1/4W and 1/8W Resistor Quantity per box: 1000pcs Quantity per box: 5000pcs Carbon Film Resistor sample kit values CFR1WK Carbon film 1W Resistor kit, 0~10M ohm, tol: 5% 32 values, 5pc/value. Total 160pcs 32 Resistance values (ohm) are: ① 0 ② 1 ③ 10 ④ 100 ⑤ 1K ⑥ 10K ⑦ 100K ⑧ 15 ⑨ 150 ⑩ 1K5 ⑪ 15K ⑫ 22 ⑬ 220 ⑭ 2K2 ⑮ 22K ⑯ 220K ⑰ 33 ⑱ 330 ⑲ 3K3 ⑳ 33K ㉑ 3R9 ㉒ 39 ㉓ 390 ㉔ 39K ㉕ 47 ㉖ 470 ㉗ 4K7 ㉘ 47K ㉙ 51 ㉚ 510 ㉛ 5K1 ㉜ 10M 44611 S. Grimmer Blvd., Fremont, CA 94538 tel: 510-241-9686 www.lumimaxusa.com ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CFR1/4WK Carbon film 1/4W Resistor kit, 0~10M ohm, tol: 5% 32 values, 5pc/value. Total 160pcs 32 Resistance values (ohm) are: ① 0 ② 1 ③ 10 ④ 100 ⑤ 1K ⑥ 10K ⑦ 100K ⑧ 15 ⑨ 150 ⑩ 1K5 ⑪ 15K ⑫ 22 ⑬ 220 ⑭ 2K2 ⑮ 22K ⑯ 220K ⑰ 33 ⑱ 330 ⑲ 3K3 ⑳ 33K ㉑ 3R9 ㉒ 39 ㉓ 390 ㉔ 39K ㉕ 47 ㉖ 470 ㉗ 4K7 ㉘ 47K ㉙ 51 ㉚ 510 ㉛ 5K1 ㉜ 10M CFR1/8WK Carbon film 1/8W Resistor kit, 10~10M ohm, tol: 5% 32 values, 5pc/value. Total 160pcs 32 Resistance values (ohm) are: ① 10 ② 15 ③ 22 ④ 30 ⑤ 39 ⑥ 47 ⑦ 51 ⑧ 100 ⑨ 220 ⑩ 300 ⑪ 470 ⑫ 510 ⑬ 1K ⑭ 2K ⑮ 2K2 ⑯ 3K ⑰ 3K3 ⑱ 4K7 ⑲ 5K1 ⑳ 10K ㉑ 15K ㉒ 22K ㉓ 33K ㉔ 47K ㉕ 51K ㉖ 68K ㉗ 100K ㉘ 220K ㉙ 470K ㉚ 510K ㉛ 1M ㉜ 10M CFR1/2WK Carbon film 1/2W Resistor kit, 10~1M ohm, tol: 5% 32 values, 5pc/value. Total 160pcs 32 Resistance values (ohm) are: ① 10 ② 15 ③ 22 ④ 47 ⑤ 68 ⑥ 100 ⑦ 120 ⑧ 150 ⑨ 220 ⑩ 330 ⑪ 470 ⑫ 510 ⑬ 680 ⑭ 1K ⑮ 2K ⑯ 2K2 ⑰ 3K3 ⑱ 4K7 ⑲ 5K1 ⑳ 6K8 ㉑ 10K ㉒ 15K ㉓ 22K ㉔ 47K ㉕ 51K ㉖ 68K ㉗ 100K ㉘ 220K ㉙ 470K ㉚ 510K ㉛ 680K ㉜ 1M 44611 S. Grimmer Blvd., Fremont, CA 94538 tel: 510-241-9686 www.lumimaxusa.com ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE.
CFR1/2WK 价格&库存
很抱歉,暂时无法提供与“CFR1/2WK”相匹配的价格&库存,您可以联系我们找货
