CXM-4-30-90-36-TC41-F5-2
    LUMINUS(朗明纳斯)
    LED 照明 COB、引擎、模块 板上芯片(COB) CXM-4 白色,暖色 方形
CXM-4-30-90-36-TC41-F5-2 数据手册
Hospitality Series Product Datasheet Preliminary Generation 4 Hospitality Series White LED COB Arrays Features: • Hospitality Lighting, warm glow with pure whitening Contents • CCT 2700K, 3000K, 3500K, 4000K Part Number Nomenclature.2 • AccuWhite High Color Rendering, 90CRI and 95CRI CCT, CRI & R9 Specification. . 2 • 2 SDCM color binning standard Chromaticity Bin Structure . 3 • Excellent optical emission uniformity and color over angle consistency Ordering Part Numbers. . . . . 4 Operating Characteristics . . 7 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . 10 • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading • Environmentally friendly: RoHS and REACH compliant • UL recognized, file # E465703 Typical Spectrum . . . . . . . . . 15 Radiation Pattern . . . . . . . . . 15 Mechanical Dimension. . . . 16 RoHS REACH Shipping Container . . . . . . . 18 Label Information. . . . . . . . . 18 Technology Review . . . . . . . 19 Applications Test Specifications . . . . . . . . 19 • Hotel Lighting • Shop Lighting • Spotlights/Track Lights • Hospitality Lighting • Downlights • Architectural and Specialty Handling Notes. . . . . . . . . . . 19 1 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Part Number Nomenclature All Luminus COB products are packaged and labeled with part numbers as outlined in the table on page 4. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 3 NN XX VV QQPP FG W Product Family LES1 CCT2 Min. CRI3 Typical Voltage Package Configurator4 Flux Bin Chromaticity Bin Chip on Board, Multi-die 4mm LES diameter See Note 2 below CRI See Table Below Volts (V) TC41 Lumens See page 3 for bins Notes: 1. Light Emitting Surface (LES) Diameter. 4 = 4.5mm 6 = 6.3mm 9 = 9.8mm 14 = 14.5mm 22 = 22mm 2. Correlated Color Temperature (CCT), NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 3. Minimum Color Rendering Index (CRI). 4. TC is a standard substrate; 4 means Generation 4 COB products, 1 means a product with chromaticity slightly below the BBL. 5. L uminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number CCT, CRI and R9 Values Correlated Color Temperatures XX Value CRI *R9 2700K, 3000K 90 >90 >50 2700K, 3000K 95 >95 >85 Note: R9 values have a tolerance of +/- 5% 2 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Color Space ANSI C78.377-2008 2-step Ellipse 0.4600 0.4400 2700K 3000K 0.4200 3500K Black Body 4000K CIE y 0.4000 0.3800 0.3600 0.3400 0.3200 0.3500 0.3700 0.3900 0.4100 0.4300 0.4500 0.4700 0.4900 CIE x The following tables describe the chromaticity bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 2-step Bin CIEx CIEy θ (°) a b 2700K 0.4596 0.4043 53.7 0.0054 0.0028 3000K 0.4370 0.3965 53.2 0.0056 0.0027 3500K 0.4062 0.3862 54 0.0062 0.0027 4000K 0.3781 0.3698 53.7 0.0063 0.0027 Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements 3 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Ordering Part Numbers The following tables describe products with typical flux and minimum flux measured at typ current and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) (25ºC) Color Rendering Index (min.) 375 450 90 CXM-4-27-90-36-TC41-F5-2 355 330 385 95 CXM-4-27-95-36-TC41-F5-2 425 395 470 90 CXM-4-30-90-36-TC41-F5-2 370 345 405 95 435 405 475 90 370 345 405 95 CXM-4-35-95-36-TC41-F5-2 450 415 495 90 CXM-4-40-90-36-TC41-F5-2 410 375 450 95 CXM-4-40-95-36-TC41-F5-2 410 375 450 90 CXM-4-27-90-18-TC41-F5-2 355 330 385 95 CXM-4-27-95-18-TC41-F5-2 425 395 470 90 CXM-4-30-90-18-TC41-F5-2 370 345 405 95 435 405 475 90 370 345 405 95 CXM-4-35-95-18-TC41-F5-2 450 415 495 90 CXM-4-40-90-18-TC41-F5-2 410 375 450 95 CXM-4-40-95-18-TC41-F5-2 Typ. (85ºC) Min. (85ºC) 410 Calculated Typ. Typ. current (mA) 120 240 Ordering Part Number 2-step MacAdam Ellipse CXM-4-30-95-36-TC41-F5-2 CXM-4-35-90-36-TC41-F5-2 CXM-4-30-95-18-TC41-F5-2 CXM-4-35-90-18-TC41-F5-2 Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 4 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Ordering Part Numbers The following tables describe products with typical flux and minimum flux measured at typ current and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) (25ºC) Color Rendering Index (min.) 565 656 90 CXM-6-27-90-36-TC41-F5-2 535 495 585 95 CXM-6-27-95-36-TC41-F5-2 645 600 685 90 CXM-6-30-90-36-TC41-F5-2 570 535 630 95 675 625 720 90 600 555 660 95 CXM-6-35-95-36-TC41-F5-2 685 635 730 90 CXM-6-40-90-36-TC41-F5-2 620 575 665 95 CXM-6-40-95-36-TC41-F5-2 610 565 656 90 CXM-6-27-90-18-TC41-F5-2 535 495 585 95 CXM-6-27-95-18-TC41-F5-2 645 600 685 90 CXM-6-30-90-18-TC41-F5-2 570 535 630 95 675 625 720 90 600 555 660 95 CXM-6-35-95-18-TC41-F5-2 685 635 730 90 CXM-6-40-90-18-TC41-F5-2 620 575 665 95 CXM-6-40-95-18-TC41-F5-2 Typ. (85ºC) Min. (85ºC) 610 Calculated Typ. Typ. current (mA) 150 300 Ordering Part Number 2-step MacAdam Ellipse CXM-6-30-95-36-TC41-F5-2 CXM-6-35-90-36-TC41-F5-2 CXM-6-30-95-18-TC41-F5-2 CXM-6-35-90-18-TC41-F5-2 Hospitality Series Product Datasheet Preliminary Output Flux (lm) (25ºC) Color Rendering Index (min.) 1,355 1,605 90 CXM-9-27-90-36-TC41-F5-2 1,260 1,175 1,385 95 CXM-9-27-95-36-TC41-F5-2 1,520 1,415 1,675 90 CXM-9-30-90-36-TC41-F5-2 1,315 1,220 1,445 95 1,515 1,410 1,670 90 1,385 1,290 1,525 95 CXM-9-35-95-36-TC41-F5-2 1,600 1,485 1,760 90 CXM-9-40-90-36-TC41-F5-2 1,450 1,345 1,595 95 CXM-9-40-95-36-TC41-F5-2 2,975 2,765 3,270 90 CXM-14-27-90-36-TC41-F5-2 2,570 2,390 2,825 95 CXM-14-27-95-36-TC41-F5-2 3,105 2,885 3,415 90 CXM-14-30-90-36-TC41-F5-2 2,670 2,485 2,940 95 3,165 2,945 3,480 90 2,820 2,625 3,105 95 CXM-14-35-95-36-TC41-F5-2 3,260 3,030 3,560 90 CXM-14-40-90-36-TC41-F5-2 2,950 2,745 3,250 95 CXM-14-40-95-36-TC41-F5-2 4,615 4,290 5,075 90 CLM-22-27-90-36-TC41-F5-2 3,990 3,710 4,390 95 CLM-22-27-95-36-TC41-F5-2 4,820 4,480 5,300 90 CLM-22-30-90-36-TC41-F5-2 4,150 3,860 4,570 95 4,915 4,575 5,405 90 4,385 4,080 4,825 95 CLM-22-35-95-36-TC41-F5-2 5,065 4,710 5,565 90 CLM-22-40-90-36-TC41-F5-2 4,585 4,270 5,050 95 CLM-22-40-95-36-TC41-F5-2 Typ. (85ºC) Min. (85ºC) 1,460 Calculated Typ. 6 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Typ. current (mA) 360 720 1050 Ordering Part Number 2-step MacAdam Ellipse CXM-9-30-95-36-TC41-F5-2 CXM-9-35-90-36-TC41-F5-2 CXM-14-30-95-36-TC41-F5-2 CXM-14-35-90-36-TC41-F5-2 CLM-22-30-95-36-TC41-F5-2 CLM-22-35-90-36-TC41-F5-2 Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-4 Operating Characteristics1 Parameter - 36V Symbol Minimum Typical Maximum Unit 120 400 mA Forward Current2 If Forward Voltage Vf 31.0 33.8 37.0 V Parameter - 18V Symbol Minimum Typical Maximum Unit Forward Current2 If 240 800 mA Forward Voltage3 Vf 15.5 16.9 18.5 V Symbol Minimum Typical Maximum Unit 4.0 15.7 W 105 ºC 3 Parameter Power Operating Case Temperature Tc Light Emitting Surface Diameter LES 4.5 mm Thermal Resistance (junction-to-case) Qjc 1.43 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-6 Operating Characteristics1 Parameter - 36V Symbol Forward Current2 If Forward Voltage3 Vf Parameter - 18V Symbol Minimum Typical Maximum Unit 150 400 mA 31.0 33.3 37.0 V Minimum Typical Maximum Unit 300 800 mA 2 Forward Current If Forward Voltage3 Vf 15.5 16.7 18.5 V Symbol Minimum Typical Maximum Unit 5.0 15.7 W 105 ºC Parameter Power Operating Case Temperature Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resistance (junction-to-case) Qjc 1.0 ºC/W Junction Temperature Tj Viewing Angle 150 120 ºC Degree Notes: 1. Ratings are based on operation at a constant junction temperature of Tj = 85ºC. 2. To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions 3. Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. 4. Device operation not recommended at drive currents less than 10% of the typical value 5. Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 6. All product operating specifications are subject to change without advance notice. 7 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-9 Operating Characteristics1 Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum Typical Maximum Unit 360 1,100 mA 33.5 37.0 V 12.1 41.9 W 105 ºC 31.0 Power Operating Case Temperature Tc Light Emitting Surface Diameter4 LES 9.8 mm Thermal Resistance (junction-to-case) Qjc 0.32 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-14 Operating Characteristics1 Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 31.0 Power Operating Case Temperature Typical Maximum Unit 720 2,000 mA 33.5 37.0 V 24.1 75.6 W 105 ºC Tc Light Emitting Surface Diameter LES 14.5 mm Thermal Resistance (junction-to-case) Qjc 0.23 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Notes: 1. Ratings are based on operation at a constant junction temperature of Tj = 85ºC. 2. To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions 3. Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. 4. Device operation not recommended at drive currents less than 10% of the typical value 5. Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 6. All product operating specifications are subject to change without advance notice. 8 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CLM-22 Operating Characteristics1 Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31.0 Power Operating Case Temperature Typical Maximum Unit 1,050 2,500 mA 33.5 37.0 V 35.2 92.5 W 105 ºC Tc Light Emitting Surface Diameter LES 22.0 mm Thermal Resistance (junction-to-case) Qjc 0.16 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Notes: 1. Ratings are based on operation at a constant junction temperature of Tj = 85ºC. 2. To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions 3. Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. 4. Device operation not recommended at drive currents less than 10% of the typical value 5. Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 6. All product operating specifications are subject to change without advance notice. 9 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-4 Optical & Electrical Characteristics - 36V Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 300% 400 350 250% Forward Curremt (mA) Relative Luminous Flux 300 200% 150% 100% 250 200 150 100 50% 0% 50 0 50 100 150 200 250 300 350 0 400 31 32 33 34 Forward Curremt (mA) 35 36 37 38 39 Forward Voltage (V) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 35 Forward Voltage (V) Relative Luminous Flux 34.5 110% 100% 34 33.5 33 90% 32.5 80% 32 0 20 40 60 80 100 120 20 30 40 50 60 70 80 90 100 110 120 Junction Temperature (℃) Junction Temperature (℃) CXM-4 Optical & Electrical Characteristics - 18V Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 300% 800 700 Forward Curremt (mA) Relative Luminous Flux 250% 200% 150% 100% 50% 0% 600 500 400 300 200 100 200 300 400 500 600 700 Forward Curremt (mA) 10 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved 800 100 15.5 16 16.5 17 17.5 18 18.5 19 19.5 Forward Voltage (V) Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-4 Optical & Electrical Characteristics - 18V Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 17.5 110% Forward Voltage (V) Relative Luminous Flux 120% 100% 17 16.5 90% 80% 16 0 20 40 60 80 100 20 120 30 40 50 60 70 80 90 100 110 120 Junction Temperature (℃) Junction Temperature (℃) CXM-6 Optical & Electrical Characteristics - 36V Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 450 300% 400 Forward Current (mA) Relative Luminous Flux 250% 200% 150% 100% 50% 0% 350 300 250 200 150 100 50 150 250 350 50 450 31 32 33 34 Relative Output Flux vs. Junction Temperature 36 37 38 Change in Voltage vs. Junction Temperature 120% 35 110% Forward Voltage (V) Relative Luminous Flux 35 Forward Voltage (V) Forward Current (mA) 100% 34 33 90% 80% 0 20 40 60 80 100 Junction Temperature (℃) 11 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved 120 32 0 20 40 60 80 100 120 Junction Temperature (℃) Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-6 Optical & Electrical Characteristics - 18V Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 900 300% 800 Forward Current (mA) Relative Luminous Flux 250% 200% 150% 100% 50% 0% 700 600 500 400 300 200 100 100 200 300 400 500 600 700 800 900 15.5 16 16.5 17 18 18.5 19 Change in Voltage vs. Junction Temperature 120% 18 110% 17.5 Forward Voltage (V) Relative Luminous Flux Relative Output Flux vs. Junction Temperature 100% 90% 80% 17.5 Forward Voltage (V) Forward Current (mA) 17 16.5 0 20 40 60 80 100 16 120 0 20 40 Junction Temperature (℃) 60 80 100 120 Junction Temperature (℃) CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1100 300% 1000 900 Forward Current (mA) Relative Luminous Flux 250% 200% 150% 100% 800 700 600 500 400 300 50% 200 0% 100 100 200 300 400 500 600 700 800 900 1000 Forward Current (mA) 12 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved 1100 31 32 33 34 35 36 37 38 Forward Voltage (V) Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 35 110% Forward Voltage (V) Relative Luminous Flux 120% 100% 34 33 90% 32 80% 0 20 40 60 80 100 120 0 20 40 60 80 100 120 Junction Temperature (℃) Junction Temperature (℃) CXM-14 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 310% 2000 260% 1700 Forward Curremt (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 210% 160% 110% 1100 800 500 60% 10% 1400 200 200 500 800 1100 1400 1700 2000 31 32 33 34 36 37 38 Change in Voltage vs. Junction Temperature 120% 35 110% 34.5 Forward Voltage (V) Relative Luminous Flux Relative Output Flux vs. Junction Temperature 100% 34 33.5 90% 80% 35 Forward Voltage (V) Forward Curremt (mA) 33 0 20 40 60 80 100 Junction Temperature (℃) 13 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved 120 0 20 40 60 80 100 120 Junction Temperature (℃) Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CLM-22 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 310% 3500 260% 3000 Forward Curremt (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 210% 160% 110% 2000 1500 1000 60% 10% 2500 500 500 1000 1500 2000 2500 3000 31 3500 32 33 34 Relative Output Flux vs. Junction Temperature 36 37 38 Change in Voltage vs. Junction Temperature 120% 35 110% Forward Voltage (V) Relative Luminous Flux 35 Forward Voltage (V) Forward Curremt (mA) 100% 34 33 90% 80% 0 20 40 60 80 100 32 120 0 20 Junction Temperature (℃) 80 100 120 Change in CIE_x/y vs. Forward Current (3000K, 90CRI) 0.01 0.002 ΔCIE_x ΔCIE_x ΔCIE_y ΔCIE_y 0.005 0.001 ΔCIE_x/y ΔCIE_x/y 60 Junction Temperature (℃) Change in CIE_x/y vs. Junction Temp. (3000K, 90CRI) 0 -0.005 -0.01 40 0 -0.001 0 20 40 60 80 100 Junction Temperature (℃) 14 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved 120 -0.002 500 1000 1500 2000 2500 3000 3500 Forward Current (mA) Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Typical Spectrum 30-90 27-90 380 430 480 530 580 630 680 730 780 Radiation Pattern Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 40 60 80 Anglular Displacement (Degrees) 15 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Mechanical Dimensions CXM-4-TC Series 0.87±0.15 .034±.006 13.50±0.25 .531±.010 2X 0.85 .033 2X 0.85 .033 1.37 .054 5.50 .217 RING O.D. 4.5 LES 13.50±0.25 .531±.010 2X 2.02 .079 1.00 .039 TcPOINT 2X 2.02 .079 0.50±0.10 .020±.004 RING HEIGHT 2X 0.20±0.10 .008±.004 CXM-6-TC Series 2x 0.30 .012 5.90 .232 0.87±0.15 .034±.006 5.90 .232 0.85 .033 2xR 2.00 .079 2.30 .091 2.30 .091 6.30 .248 LES 7.80 .307 RING O.D. TcPOINT 13.50±0.25 .531±.010 1.37 .054 6.75 .266 0.85 .033 0.39 .015 2X 5.90 .232 3.28 .129 0.50±0.10 .020±.004 R0.50 .020 TRP 13.50±0.25 .531±.010 CXM-9-TC Series 0.87±0.15 .034±.006 13.50±0.25 .531±.010 2X 0.85 .033 2X 0.85 .033 2X R 2.00 .079 1.37 .054 11.10 .437 RING O.D. 9.8 LES 13.50±0.25 .531±.010 2X 2.02 .079 1.00 .039 TcPOINT 2X 2.02 .079 2X 0.20±0.10 .008±.004 0.50±0.10 .020±.004 RING HEIGHT Note: Unless otherwise specified, tolerance is ± 0.3mm 16 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Mechanical Dimensions CXM-14-TC Series 19.00±0.25 .748±.010 2X 1.60 .063 0.87±0.15 .034±.006 2X 3.20 .126 1.37 .054 2X R 2.00 .079 14.5 LES 19.00±0.25 .748±.010 15.80 .622 RING O.D. 1.00 .039 TcPoint 2X 0.20±0.10 .008±.004 2X 0.80 .031 2X 0.80 .031 0.50±0.10 .020±.004 RING HEIGHT CLM-22 Series 28.00±0.25 1.102±.010 2X 1.60 .063 0.87±0.15 .034±.006 2X 3.20 .126 1.37 .054 2X 3.20 .126 22.0 LES 28.00±0.25 1.102±.010 23.50 .925 RING O.D. 1.20 .047 TcPOINT 2X 1.40 .055 2X 1.40 .055 0.50±0.10 .020±.004 RING HEIGHT Note: Unless otherwise specified, tolerance is ± 0.3mm 17 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary CXM-4, CXM-6, CXM-9-AC Shipping Container Package model -- for illumination Note: 80 pcs per tray and 5 trays are stacked together to be sealed in an anti-static bag. Note: The anti-static bag is boxed for easier storage, 400 pcs per box. CXM-14 Shipping Container Package model -- for illumination Note: 45 pcs per tray and 5 trays are stacked together to be sealed in an anti-static bag. Note: The anti-static bag is boxed for easier storage, 225 pcs per box. CLM-22 Shipping Container Package model -- for illumination Note: 20 pcs per tray and 5 trays are stacked together to be sealed in an anti-static bag. Note: The anti-static bag is boxed for easier storage, 100 pcs per box. Label Information Notes: ① ① Manufacture part number, flux bin and chromaticity bin ② Customer part number ② ③ Rev.01 indicates a fully released product ④ Box ID ③ ④ ⑤ ⑥ ⑤ Production ID ⑥ Total number of units in a box Label model -- for illumination only 18 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series Product Datasheet Preliminary Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 300lm to over 25,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 50,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. Chromaticity Bin Range Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2 SCDM bin distribution. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. 19 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series ProductDatasheet Datasheet (Part #) Product Preliminary Handling Notes Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. Storage Condition Please follow the conditions below. Before opened Temperature 5~30 ºC, relative humidity less than 60%. Note: before opened LED should be used within a year After opened Temperature 5~30ºC, relative humidity less than 60%. Please apply soldering within one week. After opened LED should be kept in an aluminum moisture proof bag with a moisture absorbent material Avoid corrosive gas Avoid exposing to air with corrosive gas. If exposed, electrode surface would be damaged, which may affect soldering. Furthermore, if the device is stored in an environment which contain elements that could volatize resin material, then the volatized resin particles may stick to electrodes, which may result in connection failures. Static Electricity Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all time when working with Luminus COBs. Storage Luminus products are delivered in ESD shielded bags and should be stored in these bags until used Transporting When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used Assembly Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system 20 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA Hospitality Series ProductDatasheet Datasheet (Part #) Product Preliminary Chemical Compatibility The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a result, certain chemical compounds (H2SO4, H2S, SO2, NH3, H3PO4 etc.) are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to the table below for a list of the compounds not recommended for use with the Luminus COB products. Common Chemicals Know to Adversely Affect Luminus Devices Acetates Ethers Potassium hydroxide Acetic acid Cl, F or Br containing compounds Siloxanes, fatty acids Acrylates Liquid hydrocarbons Sodium Hydroxide Aldehydes Hydrochloric Acid Sulfur compounds Aldehydes Ketones Sulfuric Acid Amines Nitric Acid Toluene Benzene Phosphoric acid Xylenes Dienes Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.the compounds not recommended for use with the Luminus COB products. 21 PDS-003091 Rev A © 2020 Lumin © 2020 Luminuus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA
CXM-4-30-90-36-TC41-F5-2 价格&库存
很抱歉,暂时无法提供与“CXM-4-30-90-36-TC41-F5-2”相匹配的价格&库存,您可以联系我们找货
  • 1+20.450961+2.64717
  • 10+14.6652310+1.89826
  • 400+9.82579400+1.27185
  • 800+9.29710800+1.20342
  • 1200+9.026061200+1.16833
  • 2000+8.719862000+1.12870
  • 5200+8.239135200+1.06647
  • 10000+7.9685610000+1.03145
库存:1893
