MP-3030-110H-40-90
MP-3030-110H-40-90
    LUMINUS(朗明纳斯)
    SMD3030_2P
    发光二极管/LED 白色,天然 SMD3030_2P
MP-3030-110H-40-90 数据手册
MP-3030-110H Mid Power Product Datasheet High-Performance 3030 Mid Power LED (65mA, 3V) **PRELIMINARY** Table of Contents Technology Overview. . . . . . 2 Features: • High efficacy • CRI Options: Minimum 80, 90, 95 Product Selection Table . . . . 3 • Low thermal resistance Operating Characteristics . . 4 • Compatible with automatic placement equipment Chromaticity Diagram. . . . . . 5 • Compatible with infrared reflow solder process • RoHs and REACH compliant Color Ranks. . . . . . . . . . . . . . . . 5 Chromaticity Coordinate Group . . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Characteristics Graphs. . . . . .7 Solder Profile . . . . . . . . . . . . . . 8 Ordering Nomenclature. . . . 9 Package dimension . . . . . . . 10 Soldering Pad Pattern. . . . . 10 Dimension and Polarity. . . . 11 Packagage Dimensions. . . . 12 Applications • Replacement lamps • Down lights • Panel lighting • Architectural lighting Box Packaging. . . . . . . . . . . . 13 1 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Technology Overview Luminus mid power LEDs are lighting class solutions designed for high performance general lighting applications. These state-of-the-art LEDs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability REACH & RoHS Compliance Luminus mid power LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, it is fully qualified for use in a wide range of high performance and high efficacy lighting applications. The Luminus MP-3030 Mid Power LED is compliant to the Restriction of Hazardous Substances Directive or RoHS. Understanding Luminus Mid Power LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus products. Testing Temperature Luminus Mid Power products are measured at a case temperature of 25ºC and placed into intensity, chromaticity and voltage bins as described herein. 2 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Product Selection Table Test condition = 65 mA, Tc=25 ºC Nominal CCT Minimum CRI Ordering Part Number Minimum Flux @ 65mA (Lumens) Typical Flux @65mA (Lumens) 80 MP-3030-110H-22-80 22 25 90 MP-3030-110H-22-90 20 22 80 MP-3030-110H-27-80 28 32 90 MP-3030-110H-27-90 24 27 95 MP-3030-110H-27-95 20 24 80 MP-3030-110H-30-80 28 34 90 MP-3030-110H-30-90 24 28 95 MP-3030-110H-30-95 22 25 80 MP-3030-110H-35-80 30 34 90 MP-3030-110H-35-90 26 29 95 MP-3030-110H-35-95 22 25 80 MP-3030-110H-40-80 30 35 90 MP-3030-110H-40-90 26 29 95 MP-3030-110H-40-95 24 25 80 MP-3030-110H-50-80 30 35 90 MP-3030-110H-50-90 26 29 80 MP-3030-110H-57-80 30 35 90 MP-3030-110H-57-90 26 29 80 MP-3030-110H-65-80 30 35 90 MP-3030-110H-65-90 26 29 2200K 2700K 3000K 3500K 4000K 5000K 5700K 6500K *Tolerance of measurements of the luminous flux is ±7% * Tolerance of measurements of the CRI is ±2 *IFP condition with Pulse: Width ≤100μs Duty cycle ≤1/10 3 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet MP-3030 Mid Power Operating Characteristics Optical and Electrical Characteristics(Tc=250C) Parameter Symbol Forward Voltage Vf Reverse Current Ir View Angle 2θ Thermal Resistance Rthj-sp Electrostatic Discharge ESD Minimum Typical Maximum Unit Condition 2.6 2.8 3.0 V If=65mA 10 uA Vr=5V 120 º If=65mA 11 ºC/W If=65mA 1/2 1000 V Note 1: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 2: Maximum operating case temperature combined with maximum drive current defines the total maximum operating condition for the device. To prevent damage, please follow derating curves for all operating conditions. Note 3: Mid power LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Product lifetime data is specified at typical forward drive currents. Sustained operation at absolute maximum currents will result in a reduction of device lifetime compared to typical forward drive currents. Actual device lifetimes will also depend on case temperature. Refer to the current vs. case temperature derating curves for further information. Note 4: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Absolute Maximum Ratings (Tc=250C) Parameter Symbol Rating Unit Forward Current If 200 mA Pulse Forward Current Ifp 300 mA Power Dissipation Pd 600 mW Reverse Voltage Vr 5 V Operating Temperature Topr -40~+85 °C Storage Temperature Tstg -40~+85 °C Junction Temperature Tj 125 °C Soldering Temperature Tsld 230 °C or 260 °C for 10 sec *IFP condition with Pulse: Width ≤100μs Duty cycle ≤1/10 4 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Color Bins target chromaticity @ Tc=25 °C Color Code Center Radius x y a b Angle(deg) ϕ 22m5 0.5018 0.41520 0.013500 0.00700 59.90 27m5 0.4620 0.41450 0.013500 0.00700 53.42 30m5 0.4383 0.40810 0.013900 0.00680 53.22 35m5 0.4073 0.39170 0.01545 0.00690 53.13 40m5 0.3875 0.38680 0.015650 0.00670 53.43 50m5 0.3507 0.3635 0.013700 0.00590 59.37 57m7 0.3348 0.3491 0.015645 0.00770 58.35 65m7 0.3187 0.3363 0.015610 0.006650 58.34 Ellipse Definition *Note: Tolerance of measurements of the chromaticity Coordinate is ±0.005 Chromaticity coordinates as per ANSI standard. 5 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Chromaticity Coordinate Group Chromaticity Coordinates at Tc= 25° C Chromaticity Coordinates at Tc= 85° C 6 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Typical optical/Electrical Characteristics Graphs Vf-------If TO BE UPDATED Tc-----Relative Luminous Flux 7 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved If---- Relative Luminous flux TO BE UPDATED Color Specturm MP-3030Mid Power Product Datasheet PRELIMINARY Typical Optical/Electrical Characteristic Ambient Temperature-Allowable Forward Current Allowable Forward Current(mA) Typical Polar Radiation Pattern Ambient Temperature (0C) Tc--Forward Voltage 8 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved Ta Cs CiE x, y Shift MP-3030-110H Mid Power Product Datasheet Product Ordering and Shipping Part Number Nomenclature All mid power products are packaged and labeled with part numbers as outlined in below. When shipped, each reel will contain only a single flux and voltage bin. The part number designation is as follows: MP-3030 Mid Power LEDs Mid Power Package Type Package Configurator Nominal CCT Minimum CRI MP MP-3030 110H ## ## Example : The part number MP-3030-110H-30-80 refers to a MP-3030 mid power emitter with nominal color temperature of 3,000k and minimum CRI of 80. Please refer to page 5 for a description of available CCT and CRI combinations. Note 1: CCT Codes: Note 2: 27 = 2700 k 30= 3000 k CRI Codes: 80 40 = 4000 k 90 50 = 5000 k 95 57= 5700 k 65 = 6500 k Each mid power product shipped will be labeled with its specific flux and voltage bins. Not all bins listed are available in all CCTs and CRIs. Test Condition = 65mA Tc=25 ºC Luminus Flux Bins Bin Code Minimum Flux (Lumens) Maximum Flux (Lumens) D3 20 22 D4 22 24 D5 24 26 D6 26 28 D7 28 30 D8 30 32 D9 32 34 E1 34 36 Forward Voltage Bins (Tc=25°C) Bin Code Minimum Voltage (Volts) Maximum Voltage ( Volts) Z1 2.6 2.7 A1 2.7 2.8 B1 2.8 2.9 * Tolerance of measurements f the Forward Voltage is ±0.08V 9 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Package Dimension (mm) Recommended Soldering Pad Pattern Note: tolerance : .X: ±0.10mm .XX: ±0.05mm 10 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Package Dimensions Of Tape(mm) User feed direction Start End Not less than 400mm Leader Capacity per reel (5000 PCs LEDs) 11 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved Not less than 160mm End MP-3030-110H Mid Power Product Datasheet Package Dimensions of Reel (mm) User feed direction Upper Band Carrier tape 013 mm 0165.1mm(6.5 inch) Package Dimensions of Reel (mm) Label: contains the type, Lot #, Quality, Product parameters Desiccant (bag) Humidity Card (bag) Label: contains the type, Lot #, Quality, Product parameters 12 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved Vacuum sealed antistatic bag MP-3030-110H Mid Power Product Datasheet Box Packaging Label: contains the type, Lot #, Quality, Product parameters *Capacity 5 reels per box Label: contains the type, Lot #, Quality, Product parameters *Capacity 10 reels per box 13 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved MP-3030-110H Mid Power Product Datasheet Precaution for Use Storage: 1. This device is rated at MSL 3 per JEDEC J-STD-020 standard. 2. Recommended storage condition: At 5 °C- 30 °C and relative humidity 60% RH in its original package 3. After this bag is opened, devices that will be applied to infrared reflow, vapor - phase reflow, or equivalent soldering process must be: a) Completed within 168 hours b) Stored at less than 60%RH c) If not completely used within 168 hours, seal the remaining in the moisture barrier bag 4. Devices require baking before mounting, if 3 a) is not met. 5. If baking is required, devices must be baked under below conditions: 24 hours at 60C+/-5C Static Electricity: 1. The products are sensitive to static electricity, and care should be taken when handling them. 2. Static electricity or surge voltage will damage the LEDs. It is recommended to wear a anti-electrostatic wristband or an anti-electrostatic gloves when handling the LEDs. 3. All devices, equipment and machinery must be properly grounded. It is recommended that measures be taken against surge voltage to the equipment that mounts the LEDs. 14 PDS-002980 Rev 01-preliminary © 2018 Luminus Devices, Inc. - All Rights Reserved
MP-3030-110H-40-90 价格&库存
很抱歉,暂时无法提供与“MP-3030-110H-40-90”相匹配的价格&库存,您可以联系我们找货
MP-3030-110H-40-90
  • 5000+0.580605000+0.07535
  • 10000+0.5432610000+0.07051
  • 15000+0.5240715000+0.06802
  • 25000+0.5023925000+0.06520
  • 35000+0.4894935000+0.06353
  • 50000+0.4768850000+0.06189
库存:14975
MP-3030-110H-40-90
  • 1+1.757901+0.22815
  • 10+1.1985710+0.15556
  • 100+0.83612100+0.10852
  • 500+0.66730500+0.08661
  • 1000+0.611351000+0.07935
  • 2000+0.563602000+0.07315
库存:14975
MP-3030-110H-40-90
