SBM-40-RGBW-SC41-QD100
    LUMINUS(朗明纳斯)
    SMD-8P,5.8x4.7mm
    发光二极管/LED 红色,翠绿色,蓝色,白色 SMD-8P,5.8x4.7mm 623nm,525nm,454nm
SBM-40-RGBW-SC41-QD100 数据手册
SBM-40-SC Product Datasheet SBM-40-SC Features: Table of Contents • High optical output at 2 A: up to 253 Red lumens up to 404 Green lumens up to 2265 Blue mWatts up to 543 White lumens • High thermal conductivity package Technology Overview. . . . . . 2 • Four chips with emitting area of 1 mm2 each Binning Structure. . . . . . . . 3-4 • Environmentally friendly: RoHS compliant Ordering Part Number . . . . . 5 Product Shipping & Labeling Information. . . . . . . . . . . . . . . . 6 • Variable drive currents: 0.1 A to 2.0 A • Available in RGBW combination Optical & Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 7-12 Thermal Resistance . . . . . . . 13 Mechanical Dimensions . . . 14 Applications: Solder Profile . . . . . . . . . . . . . 15 • Entertainment /Stage Lighting • Medical Lighting • Architectural Ligthing • Fiber-coupled Illumination • Spot Lighting • Machine Vision Packaging Specification. . . 16 Revision History. . . . . . . . . . . 17 • Pool and Fountain Lighting 1 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC SBM-160 Product Datasheet Technology Overview Luminus LEDs benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.6º C/W (electrical), Luminus SBM-40-SC LEDs have industry-leading thermal resistance. This allows the LED to be driven at higher current while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Reliability Designed from the ground up, Luminus LEDs are one of the most reliable light sources in the world today. Luminus LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. Understanding Luminus LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points Luminus surface mount LEDs are typically tested with a 20 ms input pulse and a junction temperature of 25 ºC. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from 0.1 A to 2.0 A, and duty cycle from 90 lm and Red DWL range of 621nm-626 nm; Green flux > 210 lm and Green DWL range of 522 nm to 527 nm; Blue power > 1000 mW and Blue DWL range of 451 nm to 456 nm; White flux >210 lm. 5 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Product Shipping & Labeling Information All SBM-40-SC products are packaged and labeled with their respective bin as outlined in the tables on pages 3 & 4. When shipped, each reel will only contain one bin. The part number designation is as follows: SBM 40 RGBW SC41 QD Product Family Chip Area Color Package Configuration Bin Kit Identifier Surface Mount (window) 4.0 mm R: Red G: Green B: Blue W: White Internal Code QDXXX 2 6 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Optical & Electrical Characteristics 1,2 Parameter Symbol Red Green Blue White Unit Drive Condition3 I 1.0 1.0 1.0 1.0 A Emitting Area - 1.0 1.0 1.0 1.0 mm2 Emitting Area Dimensions - 1.0 x 1.0 1.0 x 1.0 1.0 x 1.0 1.0 x 1.0 mm x mm λd min 621 522 451 - nm λd typ 623 525 454 - nm λd max 626 527 456 - nm Δλ1/2 17 32 21 N/A nm x 0.31 - y 0.32 - 3.0 V Dominant Wavelength FWHM (typ.) Chromaticity Coordinates4 (typ.) VF min 2.3 3.0 3.0 VF typ Forward Voltage V VF max 3.6 3.9 3.9 3.9 V Minimum Current 5 - 0.1 0.1 0.1 0.1 A Maximum Current - 2.0 2.0 2.0 2.0 A Maximum Operating Junction Temperature 5,6 Tj operating,max 100 140 130 130 ºC Absolute Maximum Junction Temperature 5,6 Tj absolute max 115 150 150 150 ºC - -40/+100 -40/+100 -40/+100 -40/+100 ºC 5 Storage Temperature Range Note 1: All ratings are based on test conditions of If = 1000 mA, Tc=25 ºC, 20 millisecond pulse. Tcase is defined on Thermal Resistance section, page 12. Note 2: Unless otherwise noted, values listed are typical. Devices are production tested and specified at 1 A/mm2 for red, green, blue and white. Values provided at 2 A based on characterization and measurements at 2A/mm2. Note 3: SBM-40-SC RGBW devices can be driven at currents ranging from 0.1 A to 2 A depending on color and at duty cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to meet application lifetime requirements. Note 4: In CIE 1931 chromaticity diagram coordinates, normalized to x+y+z=1. Note 5: SBM-40-SC RGBW devices are designed for continuous operation to a maximum current as specified above. Product lifetime data is specified at recommended forward drive currents. Sustained operation at or beyond maximum currents will result in a reduction of device lifetime compared to recommended forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the lifetime derating curves for further information. Note 6: Maximum Operating Junction Temperature and Absolute Maximum Junction Temperature assume that with all four (RGBW) LEDs operating simultaneously at 2 A. 7 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Optical & Electrical Characteristics7 Relative Luminous Flux - Red Relative Luminous Flux - Green Relative Luminous Flux vs. If Luminous Flux vs. If φv/φv(1A) Single Pulse 20ms Relative Tj = 25° Relative Luminous Flux vs. If Relative Luminous Flux vs. If φv/φv(1A) Single Pulse 20ms Tj = 25° φv/φv(1A) Single Pulse 20ms Tj = 25°C φv/φv(1A) Single Pulse 20ms Tj = 25℃ 220% 200% 200% 180% 180% 160% Relative Luminous Flux Relative Luminous Flux 160% 140% 120% 100% 80% 60% 140% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 0.5 1 If (A) 1.5 0% 2 0 0.5 1 If (A) Relative Luminous Flux - Blue Relative Luminous Flux - White Relative Luminous Flux vs. If Luminous Flux vs. If φv/φv(1A) Single Pulse 20ms Relative Tj = 25° Relative Luminous Flux vs. If Luminous Flux vs. If φv/φv(1A) Single Pulse 20ms Relative Tj = 25° 1.5 2 220% 220% 200% 200% 180% 180% 160% 160% Relative Luminous Flux Relative Luminous Flux 2 φv/φv(1A) Single Pulse 20ms Tj = 25°C φv/φv(1A) Single Pulse 20ms Tj = 25℃ 140% 120% 100% 80% 140% 120% 100% 80% 60% 60% 40% 40% 20% 20% 0% 1.5 0 Note 7: 0.5 1 If (A) 1.5 2 0% 0 0.5 1 If (A) Flux and power values are measured using a current pulse of typical 20 ms. Luminus maintains a test measurement accuracy for LED flux and power of ±6%. 8 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Optical & Electrical Characteristics Voltage as function of Forward Current - Red Voltage as function of Forward Current - Green Vf vs. If Vf(If ) Single Pulse 20ms Tj = 25° Vf vs. If Vf(If ) Single Pulse 20ms Tj = 25° Vf vs. If Vf(If) Single Pulse 20ms Tj = 25°C Vf vs. If Vf(If) Single Pulse 20ms Tj = 25°C 4.20 4.00 3.80 3.60 Voltage (Vf) Voltage (Vf) 3.40 3.00 3.20 2.60 2.80 2.20 1.80 0 0.5 1 If (A) 1.5 2.40 2 0 0.5 1 If (A) 1.5 Voltage as function of Forward Current - Blue Voltage as function of Forward Current - White Vf vs. If Vf(If ) Single Pulse 20ms Tj = 25° Vf vs. If Vf(If ) Single Pulse 20ms Tj = 25° Vf vs. If Vf(If) Single Pulse 20ms Tj = 25°C Vf vs. If Vf(If) Single Pulse 20ms Tj = 25°C 4.00 4.40 3.60 3.60 Voltage (Vf) Voltage (Vf) 4.00 3.20 3.20 2.80 2.80 2.40 2 0 0.5 1 If (A) 9 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved 1.5 2 2.40 0 0.5 1 If (A) 1.5 Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 2 SBM-40-SC Product Datasheet Optical & Electrical Characteristics Wavelength change as function of Current - Red Wavelength change as function of Current - Green Δ Dominant Wavelength (λd) Δ Dominant Wavelength (λd) Red Tj=25° Δ Dominant Wavelength (λd) Δ Dominant Wavelength (λd) Green Tj=25° Green Tj=25℃ Red Tj=25℃ 12.0 1.0 10.0 Δ Dominant Wavelength (λd) Δ Dominant Wavelength (λd) 0.6 0.2 -0.2 -0.6 8.0 6.0 4.0 2.0 0.0 -2.0 -1.0 0 0.5 1 If (A) 1.5 -4.0 2 0 0.5 1 If (A) 1.5 Wavelength change as function of Current - Blue CIEx, y change as function of Current - White Δ Dominant Wavelength (λd) Δ Dominant Wavelength (λd) Blue Tj=25° Chromaticity Shift vs. If Shift vs. If Tj = 25°C ΔCIEx,y = CIEx,y(If ) - CIEx,y (1A), Chromaticity Single Pulse 20ms Blue Tj=25℃ ΔCIEx,y = CIEx,y(If) - CIEx,y (1A), Single Pulse 20ms Tj = 25°C 0.040 1.0 Δ CIEx 0.030 0.7 Δ Dominant Wavelength (λd) 2 Δ CIEy 0.020 Δ CIEx, Δ CIEy 0.4 0.1 0.010 0.000 -0.010 -0.020 -0.2 -0.030 -0.5 0 0.5 1 If (A) 10 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved 1.5 2 -0.040 0 0.5 1 If (A) 1.5 Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 2 SBM-40-SC Product Datasheet Optical & Electrical Characteristics SBM-40-SC -RGBW Spectrum8 120% Green Blue Relative Intensity 100% Red White 80% 60% 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) SBM-40-SC -RGBW Angular Distribution 30° 20° 10° 40° 0° 1.0 0.8 50° 0.6 60° 0.4 70° 0.2 80° 90° Note 8: 1.0 0.8 0.6 0.4 0.2 0 20° 40° 60° 80° Typical spectrum from Red, Green, Blue and White LEDs at reference current of 1 A, CW. Please contact Luminus to obtain data in Excel format. 11 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet SBM-40-SC Thermal Resistance Thermal resistance junction to case, R th(j-c)_real = 1.0 oC/W (typ.),(All chips operated simultaneously) Thermal resistance junction to case, Rth(j-c)_electrical = 0.8 oC/W (typ.) (All chips operated simultaneously) Case Temperature (Tc ) = Temperature at bottom of ceramic substrate. 12 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Mechanical Dimensions – SBM-40-SC Emitter 4.68 .15 EMITTING EARE 2.17 0.38 GREEN 5.75 .15 EMITTING AREA 2.26 D WHITE RED BLUE 0.77 "A" 0.87 0.87 0.77 "B" P8 P7 P6 P5 "C" P4 P3 P2 P1 DETAILD 0.77 SCALE 20 : 1 0.87 0.87 PAD P1 ASSIGNMENT CATHODE, RED P2 ANODE, RED P3 CATHODE, BLUE P4 ANODE, BLUE P5 CATHODE, GREEN P6 ANODE, GREEN P7 CATHODE, WHITE P8 ANODE, WHITE 0.77 4.48 DIMENSION NAME "A" BOTTOM OF SUBSTRATE TO TOP OF WINDOW "B" BOTTOM OF SUBSTRATE TO TOP OF SOLDERMASK 0.52 .05 "C" TOP OF DIE EMITTING AREA TO TOP OF WINDOW 0.48 .06 DESCRIPTION NOMINAL DIMENSION TOLERANCE .09 1.21 For prototyping purposes, please see Bergquist thermal clad boards, part #803807 (square board) or part # 803808 (star board). Available from Digi-Key or Mouser. 13 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Solder Profile SAC 305 Reflow Profile Window For Low Density Boards 250 Temperature (ºC) 225 200 175 150 125 100 75 50 25 0 0 30 60 Solder Profile Stage 90 120 150 180 Time (sec) 210 240 270 300 Lead-Free Solder Lead-based Solder 2 ºC/sec max 2 ºC/sec max Preheat Min Temp (Ti,min) 100 ºC 120 ºC Preheat Max Temp (Ti,max) 175 ºC 130 ºC 90 seconds 120 seconds 185 ºC 160 ºC 30-60 seconds 30 seconds Liquidus Peak Temp (Tp) 240 ºC max 220ºC max Cooldown ≤ 4 ºC/sec ≤ 6 ºC/sec 4 min 3.5 - 4 min Rate of Rise Preheat Time (Ti,min to Ti,max) Liquidus Min Temp (TL) Liquidus to Liquidus Time (TL to TL2) Profile Length (Ambient to Peak) Note 9: Temperatures are taken and monitored at the component copper layer. Note 10: Optimum profile may differ due to oven type, circuit board or assembly layout. Note 11: Recommended lead free, no-clean solder: AIM NC254-SAC305. Note 12: Refer to soldering and handling application note (APN-001473) for additional solder profiles and details. 14 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Packaging Specification Packing Unit = 500 pcs per reel 12.4 .488 UNREELING DIRECTION 178 7 21.3 .839 3X 2.00 .079 13 .512 16.0 .630 C 120° DETAIL C UNREELING DIRECTION TOP VIEW SBM-40 DETAIL D SCALE 4 : 1 Note 13: For detailed drawing, please refer to drawing number: TO-1156. 15 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SBM-40-SC Product Datasheet Revision History Revision Rev 01 Date 05/27/2018 Description Preliminary Datasheet release The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may have in such information. This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and other countries. 16 PDS-002984 Rev 01 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086
SBM-40-RGBW-SC41-QD100 价格&库存
很抱歉,暂时无法提供与“SBM-40-RGBW-SC41-QD100”相匹配的价格&库存,您可以联系我们找货
    • 1+111.49920
    • 200+44.49600
    • 500+43.00560
    • 1000+42.27120
    • 500+55.88048500+7.26429
    • 1000+53.984881000+7.01786
    • 1500+53.015421500+6.89184
    库存:446
