SST-10-IRD-B90H-S810
    LUMINUS(朗明纳斯)
    红外(IR) 发射器 815nm 3V 1.5A 770mW/sr @ 1A(标准) 90° 1414(3535 公制)
SST-10-IRD-B90H-S810 数据手册
SST-10-IRD-810nm Product Datasheet SST-10-IRD-810nm Dual Junction Surface Mount Series Low Thermal Resistance Infrared LED Table of Contents Technology Overview. . . . . . 2 Product Binning. . . . . . . . . . . . 3 Features • High Power Infrared LED with typical 810nm centroid wavelength • High thermal conductivity substrate • 90 and 130-degree viewing angle Ordering Information . . . . . . 3 • Operation at up to 1.5A CW and 5A pulse Optical and Electrical Characteristics. . . . . . . . . . . . . 4 • Corrosion Robustness Class: 3B Mechanical Dimensions. . . . 8 • Low Thermal Resistance Tape and Reel. . . . . . . . . . . . . 10 • Built-in ESD protection • Suitable for all SMT Assembly Methods • RoHS and REACh compliant Reel Information. . . . . . . . . . 12 Shipping information . . . . . 13 Applications Soldering. . . . . . . . . . . . . . . . . 14 • Surveillance Systems / CCTV Precautions. . . . . . . . . . . . . . . 15 Revision History. . . . . . . . . . . 16 • Iris and Face Recognition • License Plate Scanning • Automotive Sensing • Machine Vision • Night Vision 1 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Technology Overview Luminus SST-10-IRD-810nm LEDs benefit from innovations in device technology, chip packaging and thermal management. This suite of technologies give engineers and system designers the freedom to develop solutions both high in power and efficiency. Reliability REACh & RoHS Compliance Luminus SST-10-IRD-810nm LEDs have passed a rigorous suite of environmental and mechanical stress tests, including HTOL, temperature cycling, humidity and corrosion resistance. They are fully qualified for use in a wide range of high performance and high efficacy applications. The Luminus SST-10-IRD-810nm LED is compliant to the Restriction of Hazardous Substances Directive or RoHS. The restricted materials including lead, mercury cadmium hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ether (PBDE) are not used. Understanding Luminus SST-10-IRD-810nm LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus products. Testing Temperature Luminus SST-10-IRD-810nm LEDs are tested and binned at 25°C junction temperature. Temperature curves are provided to allow users to scale the data for actual operating temperature conditions. 2 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Product Ordering and Shipping Part Number Nomenclature All SST-10-IRD-810nm products are packaged and labeled with part numbers as outlined in below. When shipped, each reel will contain only a single flux wavelength and Vf bin. The part number designation is as follows: SST Product Family SST - Ceramic Surface Mount package w/ encapsulation 10 IRD Chip Area Color 10 : 1.0 mm2 B### F###-V# Package Configuration IRD : Dual Junction Infrared Bin Kit B90H : 90 deg Beam Angle B130H : 130 deg Beam Angle High Performance Ceramic 3.45mm x 3.45mm See Pages 8-9 for Detailed Drawings See below for flux, wavelength and forward voltage binning information Flux Bins1 Radiometric Power at 350mA, tp=20ms Bin Code Minimum Flux (mW) Maximum Flux (mW) S 475 505 T 505 535 U 535 565 V 565 595 W 595 625 Wavelength Bins1 Bin Code Minimum Peak Wavelength (nm) Maximum Peak Wavelength (nm) 810 800 830 Bin Code Minimum Forward Voltage (V) Maximum Forward Voltage (V) V9 2.8 3.0 Va 3.0 3.2 Vb 3.2 3.4 Forward Voltage Bins1 Peak Wavelength 810 Minimum Flux Bin (mW) Lens Angle Ordering Part Number 475 90 SST-10-IRD-B90H-S810 475 130 SST-10-IRD-B130H-S810 3 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Optical and Electrical Characteristics Optical and Electrical Characteristics1,5 Parameter Symbol Forward Current Output Power Typical Output Power at 1.0A, t-=20ms (typ.) Radiant Intensity at 1.0A, t-=20ms (typ.) Minimum Forward Voltage1 Package Type B90H B130H Unit If 350 mA PO 535 mW PO1.0A 1470 mW fe 770 410 mW/sr Vf min 2.8 V Vf 3.0 V Maximum Forward Voltage1 Vf max 3.4 V Viewing Angle 2 Ø1/2 Forward Voltage Typical 90 130 deg Peak Wavelength Typical λP 815 nm Centroid Wavelength Typical λc 810 nm FWHM Typical Δλ1/2 30 nm Temperature Coefficient of Foward Voltage TCVf -3.0 mV/ °C Temperature Coefficient of Radiometric Power TCPO -0.2 %/ °C Temperature Coefficient of Wavelength TCl 0.3 nm/ °C Thermal Resistance (Electrical) Rth 2.4 °C/W Note 1: Binning based on operation at a current of 350mA, 20ms single pulse and a constant junction temperature of Tj = 25ºC. Parts are binned and shipped in 0.2V Vf increments. 4 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Optical and Electrical Characteristics Absolute Maximum Ratings2 Parameter Symbol Rating Unit I 1.5 (CW) / 5 (Pulse) A Power Dissipation PD 6 W Reverse Voltage VR 5 V TSTG -40 to 100 °C Junction Temperature TJ 115°C °C ESD Sensitivity (HBM) - JEDEC JS-001-2014 Class 3B VHBM ≥8000 V ESD Sensitivity (CDM) - JEDEC JS-002-2018 Class C3 VCDM ≥1000 V Forward Current 3,4 Storage Temperature 3,4 Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Luminus SST-10-IRD-810nm LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Product lifetime data is specified at typical forward drive currents. Sustained operation at absolute maximum currents will result in a reduction of device lifetime compared to typical forward drive currents. Actual device lifetimes will also depend on junction temperature. Note 4: Maximum operating case temperature combined with maximum drive current defines the total maximum operating condition for the device. To prevent damage, please operate devices within specified conditions. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 5 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Optical and Electrical Characteristics Relative Output Flux vs. Forward Current Relative Output Flux vs. Temperature 1100% 106% 1000% 104% Relative Radiometric Power Relative Radiometric Power 900% 800% 700% 600% 500% 400% 300% 200% 100% 0% 102% 100% 98% 96% 94% 92% 90% 88% 86% 84% 82% 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 80% 5.00 If (A) 20 30 40 1.80 0.09 1.60 0.06 70 80 90 100 110 Δ Forward Voltage (Vf) 0.00 -0.03 1.00 -0.06 0.80 -0.09 -0.12 0.60 -0.15 0.40 -0.18 0.20 -0.21 0.00 -0.24 -0.20 -0.27 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 -0.30 0 10 20 30 40 If (A) 50 60 70 80 90 100 110 Tj (°C) Relative Peak Wavelength vs. Forward Current Relative Peak Wavelength vs. Temperature 20.0 22.5 17.5 20.0 17.5 15.0 15.0 Δ Peak Wavelength (λp) Δ Peak Wavelength (λp) 60 0.03 1.20 12.5 12.5 10.0 10.0 7.5 5.0 2.5 7.5 5.0 2.5 0.0 -2.5 0.0 -2.5 50 Relative Forward Voltage vs. Temperature 1.40 Δ Forward Voltage (Vf) 10 Tj (°C) Relative Forward Voltage vs. Forward Current -0.40 0 -5.0 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 If (A) 6 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved 4.00 4.50 5.00 -7.5 0 10 20 30 40 50 60 70 80 90 100 110 Tj (°C) Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Optical and Electrical Characteristics Typical Polar Radiation Plot - B90H 20° Typical Polar Radiation Plot - B130H 0° 10° 20° 1.0 30° 40° 40° 0.8 0.8 50° 0.6 60° 0.8 0.6 0.4 0.2 0.4 70° 0.2 80° 0.6 60° 0.4 70° 1.0 0° 1.0 30° 50° 90° 10° 0.2 80° 0 60° 40° 20° 90° 80° Typical Spectrum 1.0 0.8 0.6 0.4 0.2 0 20° 40° 60° 80° Permissible Pulse Handling Capability 6 120% Relative Intensity 100% 5 80% 60% 4 40% 0% If(A) 20% 700 720 740 760 780 800 820 840 860 880 3 D=0.005 900 D=0.01 Wavelength (nm) D=0.02 2 D=0.05 D=0.1 D=0.2 1 D=0.5 D=1 0 0.00001 0.0001 0.001 0.01 0.1 1 10 100 tp(s) 7 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Mechanical Dimensions - B90H Package 2.23 .088 A 1.38 .054 1.38 .054 E CENTER OF DIE EMITTING AREA .15[.006] M A B 2.15 .085 1.18 .046 .70±.13 .028±.005 BACK OF SUBSTRATE TO TOP OF DIE EMITTING AREA B CENTER OF ZENER DIODE .30[.012] M A B R.2 .008 2.7 .106 .38 .015 ANODE .20 3.45+.00 +.008 .136 - .000 1.0 .039 THERMAL PAD (NEUTRAL) 1.7 .067 2.7 .106 CATHODE E 1.0 .041 DIE EMITTING AREA 1.0 .041 DIE EMITTING AREA .20 3.45+.00 +.008 .136 - .000 2.33 2.09 .092 .082 SECTION E-E .63 .025 2.7 .106 R.2 .008 1.0 .039 1.7 .067 2.7 .106 RECOMMENDED SOLDER PAD LAYOUT 8 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Mechanical Dimensions - B130H Package 2.23 .088 A 1.38 .054 1.38 .054 E CENTER OF DIE EMITTING AREA .15[.006] M A B CENTER OF ZENER DIODE .30[.012] M A B .70±.13 .028±.005 BACK OF SUBSTRATE TO TOP OF DIE EMITTING AREA B R.2 .006 2.60 .102 1.18 .046 2.7 .106 .38 .015 ANODE .20 3.45+.00 +.008 .136 - .000 1.0 .039 THERMAL PAD (NEUTRAL) 1.7 .067 2.7 .106 CATHODE E 1.0 .041 DIE EMITTING AREA 1.0 .041 DIE EMITTING AREA .20 3.45+.00 +.008 .136 - .000 .60±.13 .023±.005 1.90±.13 .075±.005 SECTION E-E 2.7 .106 R.2 .008 1.0 .039 1.7 .067 2.7 .106 RECOMMENDED SOLDER PAD LAYOUT 9 PDS-003127 Rev 01 ©2021 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct • Sunnyvale, CA 94086 SST-10-IRD-810nm Product Datasheet Tape and Reel - B90H Package  “  “  “  “          “  “ $ &$7+2'(6,'( %  “  “ %  “  “  “  “ “ “  “  “ $12'(6,'(  “  “       6(&7,21$$ 127(6 ƒ 6(&7,21%% “ $  “  “ ƒ   ),1$/7$3($1'5((/3$&.$*,1*08670((77+( 5(48,5(0(1762)-('(&67'/(9(/$       /($9(PP>LQ@2)7$3((037
SST-10-IRD-B90H-S810 价格&库存
很抱歉,暂时无法提供与“SST-10-IRD-B90H-S810”相匹配的价格&库存,您可以联系我们找货
