K110630002
K110630002
    GLAMOX
    LAMP ARTICULATING FLUOR 14W/22W
K110630002 数据手册
LC K110630002 Old item no.: LC2FEWT LC2FEWT LC LIGHT, 30" ARM WITH WEIGHTED BASE WHITE One of the most widely used task lights in the world. With a combined 22W circline fluorescent and 14W compact fluorescent lightsource, LC provides the perfect balance of high light output with good color rendition. Weighted base mount. Color: white. Lightsource Number of lamps Lamp power (W) Number of lamps 2 Lamp base Lamp power 2 (W) Lamp base 2 Electrical data 1 22 1 G10Q 14 Minimum frequency (Hz) 60 Maximum frequency (Hz) 60 Voltage from (V) 115 Maximum voltage (V) 120 Total consumption (W) 36 E26 Lightsource T9 Body Lightsource 2 T4 Body color Body material White Aluminum Dimensions Optic Net weight (kg) 0 Arm length (in.) 30 Material of reflector 51 Color of reflector Gross weight (lb.) Type of Ballast White Technical data Ballast Number of ballast Aluminum 2 IP classification 20 Multi watt HF Termination Mounting Cord length (ft) glamox.com/luxous Table/desk base 6 The Company reserves the right to change any product specifications without prior notification. 12/5/2017
K110630002 价格&库存
很抱歉,暂时无法提供与“K110630002”相匹配的价格&库存,您可以联系我们找货
