K110660002
K110660002
    GLAMOX
    LAMP ARTICULATING FLUOR 23W
K110660002 数据手册
LS K110660002 Old item no.: LS1AWT LS1AWT LS LIGHT, 45" ARM WITH EDGE CLAMP WHITE Luxo's most versatile and best-selling Industrial task light. As part of Luxo's Classic Task Light Series, the LS couples classic styling with superior arm technology and is well-suited for a variety of applications. A 23W compact fluorescent lightsource and internal reflector provide greater light output with minimal heat. Edge clamp mount. Color: white. This is a sample image. The actual item may be different in color or otherwise from the image displayed. Lightsource Number of lamps Lamp base Electrical data 1 E26 Minimum frequency (Hz) 60 Maximum frequency (Hz) 60 Lamp power (W) 23 Voltage from (V) 115 Lightsource T3 Maximum voltage (V) 120 Dimensions Body Net weight (kg) 0 Body color Gross weight (lb.) 6 Body material Arm length (in.) White Aluminum 45 Termination Optic Material of reflector Color of reflector Cord length (ft) Aluminum Mounting 6 Edge clamp White Ballast Technical data IP classification glamox.com/luxous Type of Ballast High frequency 20 The Company reserves the right to change any product specifications without prior notification. 11/11/2016
K110660002 价格&库存
很抱歉,暂时无法提供与“K110660002”相匹配的价格&库存,您可以联系我们找货
