K110670002
K110670002
    GLAMOX
    LAMP ARTICULATING FLUOR 23W
K110670002 数据手册
LS K110670002 Old item no.: LS1EWT LS1EWT LS LIGHT, 45" ARM WITH WEIGHTED BASE WHITE Luxo's most versatile and best-selling Industrial task light. As part of Luxo's Classic Task Light Series, the LS couples classic styling with superior arm technology and is well-suited for a variety of applications. A 23W compact fluorescent lightsource and internal reflector provide greater light output with minimal heat. Weighted base mount. Color: white. This is a sample image. The actual item may be different in color or otherwise from the image displayed. Lightsource Number of lamps Lamp base Electrical data 1 E26 Minimum frequency (Hz) 60 Maximum frequency (Hz) 60 Lamp power (W) 23 Voltage from (V) 115 Lightsource T3 Maximum voltage (V) 120 Dimensions Net weight (kg) Optic 0 Material of reflector Gross weight (lb.) 27 Color of reflector Arm length (in.) 45 Material of diffuser Body Body color Body material glamox.com/luxous White Polycarbonate Termination White Aluminum Technical data IP classification Aluminum Mounting Cord length (ft) Table/desk base 6 Ballast 20 Type of Ballast The Company reserves the right to change any product specifications without prior notification. High frequency 11/11/2016
K110670002 价格&库存
很抱歉,暂时无法提供与“K110670002”相匹配的价格&库存,您可以联系我们找货
