K110620001
K110620001
    GLAMOX
    LAMP ARTICULATING FLUOR 14W/22W
K110620001 数据手册
LC K110620001 Old item no.: LC1ABK LC1ABK LC LIGHT, 45" ARM WITH EDGE CLAMP BLACK One of the most widely used task lights in the world. With a combined 22W circline fluorescent and 14W compact fluorescent lightsource, LC provides the perfect balance of high light output with good color rendition. Edge clamp mount. Color: black. This is a sample image. The actual item may be different in color or otherwise from the image displayed. Lightsource Number of lamps Lamp power (W) Number of lamps 2 Lamp base Lamp power 2 (W) Lamp base 2 Electrical data 1 22 1 G10Q 14 Minimum frequency (Hz) 60 Maximum frequency (Hz) 60 Voltage from (V) 115 Maximum voltage (V) 120 Total consumption (W) 36 E26 Lightsource T9 Ballast Lightsource 2 T4 Number of ballast Type of Ballast 2 Multi watt HF Dimensions Net weight (kg) 0 Optic Gross weight (lb.) 8 Material of reflector Arm length (in.) 45 Body material Aluminum White Technical data Body Body color Color of reflector Black IP classification 20 Aluminum Termination Cord length (ft) Mounting glamox.com/luxous 6 Edge clamp The Company reserves the right to change any product specifications without prior notification. 11/11/2016
K110620001 价格&库存
很抱歉,暂时无法提供与“K110620001”相匹配的价格&库存,您可以联系我们找货
