A011
A011
    M5STACK(明栈)
    STANDING BASE FOR CORE W/ DHT12
A011 数据手册
    BTC Standing Base for M5 Core with DHT12 SKU: A011 BTC is a M5 base that allows you sit your M5 core instead of laying them down or hang on the wall. BTC is not just a sit for holding the M5 core but also comes with serveral features like temperature and humiluty detection(by DHT12), and power seat. Note:  This Base can be used as a seat for BASIC or GRAY, USBC thru BTC can only supply power to the M5core not actually charging the Lipo battery. Because the battery can only be charged thru IP5306 which is not inside BTC, the USBC power pin had connected to output 5v(VCC_5V) of IP5306 on M5core.  The DHT12 inside BTC share the same IO with GROVE PORTA. Extend ENV unit on GROVE PORTA gonna cause I@C adress conflict. Product Features  DHT12 inside Kit includes    Type-C USB Cable M3 x 16 Screw Key Example Arduino IDE To get the code BTC.ino, please click here. #include   #include "DHT12.h"  #include  //The DHT12 uses I2C comunication.    void setup() {      M5.begin();      Wire.begin();      M5.Lcd.setBrightness(10);      Serial.println(F("ENV Unit(DHT12 and BMP280) test..."));  }    void loop() {      float tmp = dht12.readTemperature();      float hum = dht12.readHumidity();      Serial.printf("Temperatura: %2.2f*C  Humedad: %0.2f%%\r\n", tmp, hum);        M5.Lcd.setCursor(0, 0);      M5.Lcd.setTextColor(WHITE, BLACK);      M5.Lcd.setTextSize(3);      M5.Lcd.printf("Temp: %2.1f  \r\nHumi: %2.0f%%  \r\n", tmp, hum);        delay(100);  }  DHT12 ESP32 Chip GPIO22 GND GPIO21 3V3 DHT12 SCL GND SDA 3V3     https://m5stack.com/collections/m5‐base/products/btc‐standing‐base/12‐99‐19
很抱歉,暂时无法提供与“A011”相匹配的价格&库存,您可以联系我们找货
A011
