A099
A099
    M5STACK(明栈)
    4PIN 转 Grove 互连适配器 M5Stack 平台评估扩展板
A099 数据手册
GROVE-TO-4P SKU:A099 Description GROVE-TO-4P is a GROVE expansion connector. This component leads out the PIN of the HY2.0-4P interface, which can help you expand some sensors that need to be connected via DuPont cables. Product Features GROVE-TO-4P Pin extension Contains 10x GROVE-TO-4P Specifications Resources Parameter PIN pin spacing 2.54mm Net weight 12.32g/1 pcs Gross weight 124g Product size 25.34*10.27*1mm/1 pcs Package size 80*120*2mm
很抱歉,暂时无法提供与“A099”相匹配的价格&库存,您可以联系我们找货
