C008
C008
    M5STACK(明栈)
    - ESP32-PICO-D4 收发器; 802.11 b/g/n(Wi-Fi,WiFi,WLAN),Bluetooth® Smart Ready 4.x Dual Mode 2.4GHz 评估板
C008 数据手册
ATOM Lite SKU:C008 Description Atom Lite is a very compact development board in the M5Stack development kit series with a size of only 24 * 24mm. It provides more GPIO for user customization which is very suitable for embedded smart home devices and in making smart toys. The main control adopts the ESP32-PICO chip which comes integrated with Wi-Fi and Bluetooth technologies and has a 4MB of integrated SPI flash memory. Atom Lite board provides an Infra-Red LED, a RGB LED, buttons, and a PH2.0 interface. In addition, it can connect to external sensors and actuators through 6 GPIOs. The on-board Type-C USB interface enables rapid program upload and execution. Product Features • • • • • • ESP32-based RGB LED Programmable button Built-in Infra-red Extendable Pins & Holes Program Platform: Arduino、UIFlow Include • 1x ATOM Lite Applications • • • Internet of things terminal controller IoT node Wearable peripherals Specification Resources Parameter ESP32 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi, dual mode Bluetooth Flash 4MB Power Input 5V @ 500mA Port TypeC x 1, GROVE(I2C+I/0+UART) x 1 PIN Port G19, G21,G22,G23,G25, G33 RGB LED WS2812B x 1 IR Infrared transmission Button Custom button x 1 2.4G Antenna Proant 440 Operating Temperature 32°F to 104°F ( 0°C to 40°C ) Size 24 x 24 x 10 mm Weight 12g Case Material Plastic ( PC ) EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Please install the corresponding driver according to the device type. M5Core host Please click here to view the CP210X driver installation tutorial, M5StickC/V/T/ATOM series can be used without driver) Windows Description: Through the color-changing breathing light program, test whether the RGB LED and buttons are working properly. Peripherals Pin Map RGB Led G27 Btn G39 IR G12 Links • Datasheet o o ESP32-PICO WS2812B-2020 Example 1. Arduino IDE • To get the code, please click here 2. UIFlow • Click here to view UIFlow example https://docs.m5stack.com/#/en/core/atom_lite/4-3-20
很抱歉,暂时无法提供与“C008”相匹配的价格&库存,您可以联系我们找货
C008
  • 1+70.526241+9.10435
库存:1141
C008
    • 1+68.75216
    库存:184
