K024-B
K024-B
    M5STACK(明栈)
    ESP32 物联网套件 M5Stack 单元 Arduino,Blocky(UIFlow),Micropython 初级入门套件
K024-B 数据手册
= CONTENTS Contents............................................................ 1 Introduction........................................................ 2 Description .......................................................... 2 M5Core ............................................................... 3 Hardware and Sensor .................................................. 4 Accessories .......................................................... 5 ARDUINO IDE......................................................... 6 Environment Setup............................................... 6 API................................................................ 17 LCD............................................................ 17 Button......................................................... 20 Speaker........................................................ 22 Module............................................................. 24 Relay.......................................................... 24 ............................................................... 25 Microphone..................................................... 27 Light Sensor................................................... 29 Joystick....................................................... 31 Step Motor..................................................... 34 DC-Motor....................................................... 39 Servo.......................................................... 42 Keyboard....................................................... 45 Encoder........................................................ 48 DHT12 Temperature and humidity detection....................... 51 BMP280 Air pressure detection.................................. 54 LED MATRIX..................................................... 57 RFID........................................................... 60 DAC............................................................ 63 ADC............................................................ 66 RS-232......................................................... 72 appendix........................................................... 73 Example Github ...................................................... 74 Arduino API ......................................................... 75 Document & Datasheet ................................................ 75 INTRODUCTION Description DemoBoard is a multi-functional IoT learning development board. It uses BASIC in the M5Stack controller series as the control core, built-in ESP32 main control chip, and is fully compatible with the M5Stack module stacking and hardware expansion system. Equipped with a wealth of peripheral modules, including environmental detection related sensors, rocker control, rotary encoder, matrix buttons, radio frequency identification, mechanical motion control (including three-motor drive methods), three-color LED light board, relay Control, integrate multiple groups of ADC and DAC conversion circuits, and support RS485 and RS232 bus communication. Each module has an independent power switch. Combining the M5 main control with its Internet of Things properties as the control core, the DemoBoard development board covering "sound, light, electricity, force" and other aspects will be your learning hardware, A great tool for programming. M5Core The front of the BASIC controller is a 2-inch color TFT LCD screen with a resolution of 320x240. Built-in IoT chip ESP32, integrated Bluetooth, and WiFi modules in one. ESP32 is equipped with a dual-core 32-bit MCU with a main frequency of up to 240 MHz and a computing capacity of up to 650 DMIPS. The chip has abundant pin resources and integrates a wealth of hardware peripherals, including capacitive touch sensors, Hall sensors, low-noise sensor amplifiers, SD card interfaces, Ethernet interfaces, high-speed SDIO/SPI, UART, I2S, and I2C, etc. Hardware and Sensor 1 - Use M5Core as the control core, compatible with Module stacking and Unit expansion system. 2 - Protoboard, M5-BUS bus expansion 3 - Environmental sensor series (temperature, humidity, pressure, light, microphone) 4 - 8 relay outputs 5 - Joystick input 6 - Rotary encoder 7 - 8x8 matrix RGB LED 8 - 10KG Serve 9 - RS-458,RS232 Communication function 10 - 4 channel DAC, 4 channel ADC 11 - 4x4 button matrix 12 - DC motor (with feedback) 13 - Four-phase five-wire stepping motor 14- Radio Frequency Identification Reader (RFID) Accessories The development board provides a series of supporting hardware, which can help users test the functions of each module on the board. 1x 12V power adapter (before using the development board, please connect the 12V power adapter to power the development board) 1x RS232 connection line (used as RS232 port connection) 1x RFID CARD (used to test radio frequency modules) 1x ID CARD (used to test radio frequency modules) 16x Bread wire (used for onboard jumpers to connect the interfaces of various hardware modules) ARDUINO IDE Environment Setup Software Install The development environment used in this tutorial is the Arduino IDE. This chapter will show you how to download related software, resource libraries, and some basic configurations Arduino IDE is open-source software, with cross-platform capabilities, it can run on Windows, Mac OS X, and Linux. (The software installation operation demonstrated in this tutorial is based on the Windows 10 operating system) First visit (https://www.arduino.cc/en/Main/Software), enter the download page and select the installation package corresponding to your operating system to download. Windows 10 users can click the "Windows Installer, for Windows XP and up" option, and the page will switch to the donation and download page. If you need to donate, you can click "CONTRIBUTE & DOWNLOAD", and only download the installation package file and click "JUST DOWNLOAD". After the download is complete, double-click to open the installation package. According to the installation prompt, choose to agree to the authorization agreement. For the configuration options and installation path of the installation, you can follow the default configuration if there is no special requirement. Click Next according to the prompts until the installation is complete. According to the default configuration, after the installation is complete, an Arduino shortcut icon will be created on the desktop. Double-click it to start the Arduino IDE. Basic Introduction At the top of the program are the tabs and the function menu bar, which provide a series of operation and configuration options, including compile, upload, new, open, save, and serial monitor functions. Located in the middle is the programming area for code editing. Below the programming area is the log output area. When enabled, it will show you the current working status of the Arduino IDE, such as compiling or uploading the program and output the log information during the compilation and upload process, which is convenient for program debugging and Troubleshooting. Install CP2104 driver The main controller used by DemoBoard is BASIC. Before use, we need to install the matching USB driver (CP2014), Visit the Arduino environment configuration tutorial page in the official documentation of M5Stack. (https://docs.m5stack.com/#/en/arduino/arduino_development) Select the "Install USB Driver" option in the catalog, jump to the bottom of the page, and select the CP210X driver compressed package of the corresponding operating system to download. Unzip the downloaded compressed package, open the corresponding installation program (64-bit operating system selection _x64, 32-bit operating system selection _x86) according to the number of operating systems, and click Next in turn according to the prompts until the installation is complete. After completing the installation, use the Type-C data cable to connect the M5Stack device to the personal computer. Select the "Device" option from the Windows settings page to view the information of the currently connected device. As shown in Figure 211, the current M5Stack device has been successfully connected, and the currently used port is COM10. It means that the USB CP210X driver has been installed successfully and the device is operating normally. ESP32 Board In addition to supporting Arduino's official development boards (such as Arduino Uno), Arduino IDE supports many controller chips on the market. When developing different devices, we need to specify the current development board information in the configuration options, This section will show you how to configure the ESP32 board management information used by M5Stack in the Arduino IDE. Click the "File" tab at the top of the Arduino IDE page and open the "Preferences" setting. Click the Add button on the right side of the "Add Board Management Address" column, enter the URL address below in the pop-up window, and click OK to save. https://dl.espressif.com/dl/package_esp32_index.json Also, in the "Preferences" setting page, you can set some display parameters, such as the editor text size, adding line number display, compiling/burning log prompts, and other auxiliary content. After saving the settings, select the "Tools" tab, point the mouse to the "Development Board" option, find the "Development Board Manager" in its sub-directory, and click Open. In the pop-up board management window, search for "esp32" and the content of the "esp32 by Espressif Systems" development board will appear. Click the version number option to switch to install different versions. For better support, it is recommended to download the latest version. After the installation is complete, close the board manager and go back to the -->"Tools"-->"Development Board" option. Below the directory, you will find "M5Stack-Core-ESP32" and other M5Stack, ESP32 related board resources Options. Select "M5Stack-Core-ESP32", connect the device to set the port and other parameters. The "Upload Speed" parameter can set the communication speed (bps) at which the Arduino IDE transmits executable files to the device when uploading programs. In the code debugging stage, it is often necessary to repeatedly burn the program. To speed up the development progress, you can choose a higher speed to reduce the burning time. M5Stack Library M5Stack officially provides an Arduino program library adapted to M5Stack devices. The program library encapsulates and integrates a series of M5Stack device hardware (such as sensors, LCD screens, etc.) function support and drivers. Through this library, users can develop M5Stack devices very conveniently and quickly. Select the "Tools" tab, open the "Manage Library" option, and click to open the Library Manager. Search for "M5Stack" in the library manager, and you will find a series of libraries related to M5Stack. Here we choose the library maintained by the official and with the "by m5stack" field. Select the latest version and install it. After completing the above steps, the development environment of M5Stack & Arduino IDE has been set up. Hello World At the top of the program are tabs and function menu bars, which provide a series of operation and configuration options, and in the middle is the programming area for code editing. Below the programming area is the log output area. When enabled, it will show you the current working status of the Arduino IDE, such as compiling or uploading the program and output the log information during the compilation and upload process, which is convenient for program debugging and Troubleshooting. In addition to providing a series of functions, the M5Stack program also provides many programming cases for users' reference. After completing the deployment of the development environment, we can try to run a simple case program to familiarize ourselves with the use of software and hardware. Click the "File" tab at the top of the Arduino IDE page-->"Example Program"-->"M5Stack"-->"Basics"-->"HelloWorld" to open the example program. Connect the M5Stack device to the computer through the Type-C data cable, select the corresponding port in the "Port" option in the "Tools" tab, and confirm that the development board and other configuration information are correct. Click the "Upload" button on the function menu bar, and the program will automatically start to compile. After the compilation is passed, the program will be uploaded automatically, and the log will output the percentage of the progress of the program upload at this time. At this time, please keep the computer and the M5Stack device connected until the program upload is completed. When the status bar prompts "Done uploading.", it means the program has been uploaded. Check the M5Stack device at this time, and you will find that the upper left corner of the LCD screen displays the words "Hello World". The screen is as expected by our program, and it is successfully displayed. API LCD Description When learning environment configuration, we ran the "HelloWorld" case program and successfully displayed text on the LCD. This color LCD screen can do much more than that. The M5Stack library provides a series of commonly used program APIs for LCD drivers. Next, we will learn how to use these APIs to freely print content and draw patterns on the LCD screen of the M5Stack device. This "320x240" pixel color LCD screen. In actual use, you can think of the screen as a plane coordinate system, with the horizontal axis is the x-axis and the vertical axis is the y-axis. Starting from the origin of coordinates (0,0) in the upper left corner to the diagonal (319.239) in the lower right corner, a rectangle formed by the diagonal is the display area of the screen. When the coordinates of the content leave this range, it will not be displayed normally. Text display In the program, we can not only modify the displayed text content but also set the display position of the content and the font size. By setting the text cursor, you can specify the position of a character in the text content. By setting the font-size value, the size of the font display can be adjusted. Set cursor position: void M5.lcd.setCursor(uint16_t x, uint16_t y); Description: Set the text cursor to the coordinates (x,y) parameter: uint16_t x:x-axis coordinate uint16_t y:y-axis coordinate return: none eg:M5.lcd.setCursor(40, 60); Set font size: void M5.lcd.setTextSize(uint8_t size); Description:Set font size parameter: uint8_t size:Font size (allowable input range 1~7) return: none eg:M5.lcd.setTextSize(3); Print Text: int M5.lcd.print(val); int M5.lcd.print(val,format); int M5.lcd.println(val); int M5.lcd.println(val,format); Description:Print the specified information on the LCD screen。 parameter: val:The output value can be integers, floating-point numbers, characters, and strings. format: Specify the output format, BIN (binary), OCT (octal), DEC (decimal), HEX (hexadecimal). When outputting floating-point numbers, you can specify the number of digits left after the decimal point. return: The number of bytes occupied by the content eg: M5.lcd.print(78);// Print result 78 M5.lcd.print(1.23456); Print result is 1.23 (by default, two decimal places are reserved) M5.lcd.print("M");// Print M M5.lcd.print("Hello M5Stack"); Print Hello M5Stack M5.lcd.print(78,HEX);// Print 4E M5.lcd.print(1.23456,4); //Print 1.2346 Example Control LCD to display text dynamically, and display "Hello World" and "Hello M5Stack" at intervals #include void setup(){ } M5.begin(); M5.Lcd.setTextSize(3); void loop() { M5.Lcd.setCursor(40, 60); M5.Lcd.print("Hello World"); delay(1000); M5.Lcd.clear(BLACK); M5.lcd.setCursor(40, 100); M5.Lcd.print("Hello M5Stack"); delay(1000); M5.Lcd.clear(BLACK); } Button Description Three programmable physical buttons are provided on the control panel. With the existing API, interactive operations such as short press and long press can be realized. Button click: uint8_t M5.BtnA.wasPressed(); Description: When the button is pressed, the function returns the value "1" once, and then set to "0". When the button is released, the function return value is always "0". parameter:none return:none eg: if (M5.BtnA.wasPressed()) { M5.Lcd.printf("Button A was pressed."); delay(1000); } Long press: uint8_t M5.BtnA.pressedFor(int32_t ms); Description: Specify the duration of pressing the button. Actually, when the pressing duration is greater than the set duration, it returns "1", otherwise it returns "0". parameter: int32_t ms: Set long press time return:none eg: if (M5.BtnA.pressedFor(2000)) { M5.Lcd.printf("Button A was pressed for more than 2 second s."); delay(1000); } Status update: void M5.update(); Description: Update the status of buttons A, B, C, Yang, and speakers. Note: When using a key program, you need to add "M5.update();" to the cycle of the program, so that the key value is constantly refreshed as the program runs, otherwise the program key is only valid once. parameter:none return:none eg: M5.update(); Speaker Description The speaker integrated on the controller emits various tones for audio playback or function prompts. Play the specified tone: void M5.Speaker.tone(uint16_t freq, uint32_t duration); Description:Play audio at a specified frequency and support setting the playing time. parameter: uint16_t freq: Set the frequency of playing sound uint32_t duration: return:none eg: M5.Speaker.tone(440, 1000); Note: The hearing range of ordinary people is 20Hz~20KHz. Sounds larger or smaller than this range may not be recognized by people. Excessive use of high frequency or long-term high-frequency playback is likely to cause damage to the speaker hardware. Therefore, please pay attention to the appropriate range when filling in the parameters. Example combines the key function to control the speaker to emit different sounds. #include void setup() { M5.begin(); M5.Lcd.setTextSize(3); M5.lcd.setCursor(40, 100); M5.Lcd.print("M5Stack Speaker test"); } void loop() { if(M5.BtnA.wasPressed()) { M5.Speaker.tone(262, 1000); } if(M5.BtnB.wasPressed()) { M5.Speaker.tone(294, 1000); } if(M5.BtnB.wasPressed()) { M5.Speaker.tone(330, 1000); } M5.update(); } Warnning: When using M5Core for programming and development, you need to pay attention to the pin occupancy of the built-in hardware and avoid using the same pin to drive different hardware, resulting in failure to work properly. The following pins represent their application in M5Core, ( For example, GPIO32 is the pin occupied by the LCD screen) more complete pin mapping information, please visit https://docs.m5stack.com/#/en/core/basic MODULE Relay Description Relay is a relay control module. When the coil inside the relay is energized, it will generate a magnetic force to absorb the switch action, and then realize the switch control. Such a small current control high current electrical circuit scheme can control DC/3A-30V or AC/3A -220V level line is on and off. Each relay provides three control circuit pins, which are the common terminal COM, the normally closed terminal NC, and the normally open terminal NO. By default, NC and COM are connected, and NO and COM are disconnected by default. When the relay coil is energized, The switch relationship between the two and the common terminal COM will be reversed. Hardware connection When using the Relay relay control module, you only need to connect the control pin of the controller to the relay coil and turn on the independent power switch of the module to power it. In this way, when the controller pin outputs a high level, the relay coil will be energized and generated The magnetic field force absorbs the action switch and makes the corresponding action. Example #include const int In_0 = 23; void setup() { // put your setup code here, to run once: pinMode(In_0,OUTPUT); } void loop() { // put your main code here, to run repeatedly: digitalWrite(In_0, LOW); delay(1000); digitalWrite(In_0, HIGH); } delay(1000); Microphone Description The Microphone module integrates the MAX4466 microphone preamplifier, which can effectively collect the analog and digital information input through the microphone. It also provides an adjustable resistor for the user to adjust the threshold value of identification. Hardware connection The Microphone module supports the reading of two signal values, digital and analog. It should be noted that not all GPIO interfaces of M5Core support AD conversion when making hardware connections. Therefore, the interface needs to be connected when using the analog reading function. Connect to pins that support ADC (such as 34/35/36), and use general GPIO for digital reading. Example #include const int Analog = 36; const int Digtal = 2; void setup() { // put your setup code here, to run once: M5.begin(); pinMode(Digtal, INPUT_PULLUP); dacWrite(25, 0); M5.Lcd.setCursor(100, 0, 4); M5.Lcd.print("MICROPHONE"); } uint16_t a_data; uint16_t d_data; void loop() { // put your main code here, to run repeatedly: a_data = analogRead(Analog); d_data = digitalRead(Digtal); Serial.printf("Analog:%0d Digtal:%0d\n", a_data, d_data); M5.Lcd.setCursor(30, 120, 4); M5.Lcd.printf("Analog:%0d Digtal:%0d\n", a_data, d_data); delay(200); } Light Sensor Description Light Sensor is a light sensor with an integrated photoresistor, LM393DR2G voltage comparator, which can effectively collect light input analog and digital information. It also provides adjustment resistance for users to adjust the threshold value of recognition. Hardware connection The Light module supports the reading of both digital and analog signal values. When making hardware connections, it should be noted that not all GPIO interfaces of M5Core support AD conversion, so when using the analog reading function, you need to connect the interface Connect to pins that support ADC (such as 34/35/36) and use general GPIO for digital reading. Example #include const int Analog = 36; const int Digtal = 2; void setup() { // put your setup code here, to run once: M5.begin(); pinMode(Digtal, INPUT_PULLUP); dacWrite(25, 0); M5.Lcd.setCursor(100, 0, 4); M5.Lcd.print("LUMINOSITY"); } uint16_t a_data; uint16_t d_data; void loop() { // put your main code here, to run repeatedly: a_data = analogRead(Analog); d_data = digitalRead(Digtal); Serial.printf("Analog:%0d Digtal:%0d\n", a_data, d_data); M5.Lcd.setCursor(30, 120, 4); M5.Lcd.printf("Analog:%0d Digtal:%0d\n", a_data, d_data); delay(200); } Joystick Description The joystick is a joystick input module. The module has built-in two sets of sliding rheostats and a key switch. When the joystick is operated, its internal resistance changes accordingly. Connect the X_ADC and Y_ADC interfaces of the module to the M5Core support On the ADC converted pin, read the digital information of the joystick offset through the program. When the BUTTON is pressed down on the joystick, its internal key switch will act accordingly to change the output signal to a low level. Hardware connection Connect the X_ADC and Y_ADC of the Joystick module to the pins that support the ADC function on the M5Core (in this example, PIN 35/36 will be used), and connect the BUTTON to PIN 2. Example #include /* note:Reading the adc value requires writing the pin 25 of th e adc to 0. dacWrite(25, 0); */ void setup() { // put your setup code here, to run once: M5.begin(); pinMode(2, INPUT_PULLUP); dacWrite(25, 0); } M5.Lcd.setCursor(100, 0, 4); M5.Lcd.print("JOYSTICK"); uint16_t x_data; uint16_t y_data; uint8_t button_data; void loop() { // put your main code here, to run repeatedly: x_data = analogRead(35); y_data = analogRead(36); button_data = digitalRead(2); Serial.printf("x:%0d y:%0d button:%d\n", x_data, y_data, but ton_data); M5.Lcd.setCursor(30, 120, 4); M5.Lcd.printf("x:%04d y:%04d button:%d\n", x_data, y_data, b utton_data); } delay(200); Step Motor Description Step Motor is a stepping motor module with integrated motor drive chip LV8548MC, using a five-wire four-phase connection. The A, B, C, D interfaces on the board can control the four magnetic pole coils in the stepping motor through the drive chip The power is turned on and off to control the rotation of the motor. Hardware connection Connect the control pins PIN 2, 5, 12, and 13 to the A, B, C, and D ports of the stepper motor module, and turn on the independent power supply Different coil energization sequence will affect the rotation speed of the stepper motor, the number of beats for a complete revolution, the step value, and the stability during operation. Example-1 Coil MotorA MotorB MotorC MotorD Step1 High Step2 Step4 High High High #include const int MOTOR_A_A = 2; const int MOTOR_A_B = 5; const int MOTOR_A_C = 12; const int MOTOR_A_D = 13; void setup() { M5.begin(); pinMode(MOTOR_A_A, pinMode(MOTOR_A_B, pinMode(MOTOR_A_C, pinMode(MOTOR_A_D, } Step3 OUTPUT); OUTPUT); OUTPUT); OUTPUT); void loop() { digitalWrite(MOTOR_A_A, digitalWrite(MOTOR_A_B, digitalWrite(MOTOR_A_C, digitalWrite(MOTOR_A_D, delay(2); digitalWrite(MOTOR_A_A, digitalWrite(MOTOR_A_B, digitalWrite(MOTOR_A_C, digitalWrite(MOTOR_A_D, delay(2); digitalWrite(MOTOR_A_A, digitalWrite(MOTOR_A_B, digitalWrite(MOTOR_A_C, digitalWrite(MOTOR_A_D, delay(2); digitalWrite(MOTOR_A_A, digitalWrite(MOTOR_A_B, digitalWrite(MOTOR_A_C, digitalWrite(MOTOR_A_D, delay(2); } HIGH); HIGH); LOW); LOW); LOW); HIGH); HIGH); LOW); LOW); LOW); HIGH); HIGH); HIGH); LOW); LOW); HIGH); Example-2 Coil MotorA MotorB MotorC MotorD Step1 High Step2 High High Step3 High High High #include const const const const int int int int MotorA MotorB MotorC MotorD = = = = 2; 5; 12; 13; const int pinMotor[4] = {MotorA,MotorB,MotorC,MotorD}; Step4 High High const int logic[4][4] = { {1,1,0,0}, {0,1,1,0}, {0,0,1,1}, {1,0,0,1} }; int count; void setup() { M5.begin(); pinMode(pinMotor[0], pinMode(pinMotor[1], pinMode(pinMotor[2], pinMode(pinMotor[3], } OUTPUT); OUTPUT); OUTPUT); OUTPUT); void loop() { for (int i = 0; i < 2048 ; i++) { driveMotor(); delay(2); } } void driveMotor() { count++; int step = count % 4; digitalWrite(pinMotor[0] digitalWrite(pinMotor[1] digitalWrite(pinMotor[2] digitalWrite(pinMotor[3] } , , , , logic[step][0]); logic[step][1]); logic[step][2]); logic[step][3]); Example-3 Coil MotorA MotorB MotorC MotorD Step1 High High Step2 Step3 Step4 Step5 Step6 Step7 High High High High High High High High High We can further subdivide the step, only need to modify the array of power-on logic, and the drive function. const int logic[8][4] = { {1,1,0,0}, {0,1,0,0}, {0,1,1,0}, {0,0,1,0}, {0,0,1,1}, {0,0,0,1}, {1,0,0,1}, {1,0,0,0} }; void driveMotor() { count++; int step = count % 8; digitalWrite(pinMotor[0] digitalWrite(pinMotor[1] digitalWrite(pinMotor[2] digitalWrite(pinMotor[3] } , , , , logic[step][0]); logic[step][1]); logic[step][2]); logic[step][3]); Step8 High DC-Motor Description DC-Motor is a DC motor module with feedback. The module has a builtin LV8548MC motor driver chip. It provides M+ and M- two interfaces for controlling forward and reverse rotation. When M+ is high and Mis low, The motor rotates forward. When M+ is low level and M- is high level, the motor is reversed. When M+ and M- are both low and low, the motor brakes. Hardware connection Connect the control pins PIN 21, 22 to the M+ and M- ports of the DC motor module respectively, and turn on the independent power supply. Example #include void setup() { M5.begin(true, false, true); M5.Lcd.clear(BLACK); M5.Lcd.setTextColor(YELLOW); M5.Lcd.setTextSize(2); M5.Lcd.setCursor(65, 10); M5.Lcd.println("DC motor example"); M5.Lcd.setCursor(30, 220); M5.Lcd.println("Forward"); M5.Lcd.setCursor(140, 220); M5.Lcd.println("stop"); M5.Lcd.setCursor(220, 220); M5.Lcd.println("Reverse"); pinMode(21, OUTPUT); } pinMode(22, OUTPUT); void loop() { M5.update(); } if (M5.BtnA.wasReleased()) { M5.Lcd.print('A'); digitalWrite(22, LOW); digitalWrite(21, HIGH); } else if (M5.BtnB.wasReleased()) { M5.Lcd.print('B'); digitalWrite(21, LOW); digitalWrite(22, LOW); } else if (M5.BtnC.wasReleased()) { M5.Lcd.print('C'); digitalWrite(21, LOW); digitalWrite(22, HIGH); } Servo Description The development board is equipped with a steering gear (0~180°) with a torque of up to 10KG. The default 5V power supply is used for control by a single-signal bus. The driving signal is 50Hz, which is controlled to rotate to different angles according to the PWM duty cycle. PWM waveform is medium and high The level time is (0.5us~2.5us) respectively to control the rotation of the steering gear (0~180°) Hardware connection Connect the control pin PIN 15 to the SIGNAL interface of the servo and turn on the independent power supply, Example #include #include "driver/ledc.h" const int servo_pin = 15; int freq = 50; int ledChannel = 0; int resolution = 8; void setup() { } M5.begin(); M5.Lcd.setCursor(120, 110, 4); M5.Lcd.println("SERVO"); ledcSetup(ledChannel, freq, resolution); ledcAttachPin(servo_pin, ledChannel); void loop() { ledcWrite(ledChannel, 6);//0° delay(1000); ledcWrite(ledChannel, 18);//90° delay(1000); ledcWrite(ledChannel, 30);//180° delay(1000); } Keyboard Description A 4 x 4 matrix key module is provided on the development board. The specific key pressed can be detected by program scanning, which can provide you with richer key-value input and diversified control functions. Hardware connection Connect the control pins to each pin of the row and column of the button matrix, so that the program can scan the action of the button. Example In this case, the library is used, you can search and install it in the library management of Arduino. #include #include /*** * note:You should first install the keyboard library. * https://github.com/Chris--A/Keypad ***/ const byte ROWS = 4; //four rows const byte COLS = 4; //three columns byte rowPins[ROWS] = {17,16,21,22}; byte colPins[COLS] = {5, 26, 13, 15}; char keys[ROWS][COLS] = { {'a','b','c','d'}, {'e','f','g','h'}, {'i','j','k','l'}, {'m','n','o','p'} }; Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROW S, COLS); void setup() { // put your setup code here, to run once: M5.begin(); } M5.Lcd.setCursor(100, 0, 4); M5.Lcd.println("KEYBOARD"); void loop() { //put your main code here, to run repeatedly: char key = keypad.getKey(); if(key){ Serial.println(key); M5.Lcd.fillRect(150, 150, 80, 50, BLACK); M5.Lcd.setCursor(150, 140, 4); M5.Lcd.printf("%c",'A'); } } Encoder Description When the knob is rotated, port A and port B will generate a correspondingly high level according to the selected rotation direction. When the knob is pressed, its internal key switch will act accordingly to change the output signal to a low level. Hardware connection Connect the control spindle to an ordinary GPIO, and re-insert the replacement change in the program to determine the action of the knob. Example #include const int phaseA = 2; const int phaseB = 13; const int Button = 15; #define GET_CODE() uint8_t(digitalRead(phaseA)
K024-B 价格&库存
很抱歉,暂时无法提供与“K024-B”相匹配的价格&库存,您可以联系我们找货
K024-B
库存:28
K024-B
    • 1+1122.47626
    库存:44
