K007
K007
    M5STACK(明栈)
    - ESP32 收发器; 802.11 b/g/n(Wi-Fi,WiFi,WLAN),Bluetooth® Smart Ready 4.x Dual Mode 2.4GHz 评估板
K007 数据手册
IRE U:K007 utorial&Quick-Start ose the development platform you want to use, view the corresponding tutorial&quick-Start. Flow Arduino Description tack FIRE Kit, as one of the M5Stack developing kit series, is an upgrade from the Gray kits. Providing 9-Axis IMU sensor(6-Axis posture acceleratio surement + 3-Axis magnetic measurement), it equips with more hardware resources : 16M Flash + 8M PSRAM , enhanced Base (M5GO Base and M5 Base), larger battery, etc. For those developers who ask for hardware performance, Fire will be a good choice. a IMU posture sensor, there are a lot of situations which you can apply this kit to: detecting acceleration, angulation, and trajectory. You can make ve products like sports data collector, 3D remote gesture controller and more base on the above functions. is M5 Core device. Its modular, stackable, scalable, and portable device is powered with an ESP-32 core, which makes it open source, low cost, fulltion, and easy for developers to handle new product development on all stages include circuit design, PCB design, software, mold design and uction. tack Fire comes with three separable parts. The top part ,just like Basic and Gray Kit, has all kinds of processors, chips ,sockets, 2.4G antenna, ESP32, er management IC , a LCD screen and some other interface components. The middle part is called M5GO base which provides a lithium battery, M-B et , LED bar and three more GROVE Ports. The bottom part is a charge table, which can be connected to the M5GO base via POGO pins. portive development platforms and programming languages: Arduino, Blockly language with UIFlow, Micropython. Regardless of what level ramming skill you have, M5Stack would guide you in every step of the way to realize your idea as well as to the final productlization. u ever played with ESP8266, you would realize that ESP32 is a perfect upgrade out of ESP8266. In comparison, ESP32 has more GPIOs, more analog ts and two analog outputs, multiple extra peripherals( like a spare UART ). Official developing platform ESP-IDF has transplanted with FreeRTOS. Wit -core and real time OS you can get more organized code and much high speed processor. Notice: The GPIO 16 / 17 in Fire is connected to the PSRAM by default, so when you connect or stack other function modules, you need to avoid conflicts with these two pins to prevent the device from working improperly and causing instability. Power on/off: Power on: click the red power button on the left Power off: Quickly double-click the red power button on the left Note: By default, when USB is powered, it cannot be shut down** roduct Features ESP32-based Speaker, 3 Buttons, LCD(320*240) TF card slot (16G Maximum size) Battery Socket & Lipo Battery Extendable Pins & Holes M-Bus Socket & Pins Development Platform UIFlow, MicroPython, Arduino nclude x FIRE x M5GO CHG Base 2x LEGO block 5x LEGO connector x M3 HEX KEY x Type-C USB(100cm) x User Manual Applications nternet of things terminal controller Stem education product DIY creation pecification Resources Parameter ESP32 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi, dual mode Bluetooth Flash Memory 16MB PSRAM 8MB Power Input 5V @ 500mA Port TypeC x 1, GROVE(I2C+I/0+UART) x 1 IPS Screen 2 inch, 320x240 Colorful TFT LCD, ILI9342C, max brightness 853nit Speaker 1W-0928 Resources Button Parameter Custom button x 3 MEMS BMM150 + MPU6886 Battery 500 mAh @ 3.7V Antenna 2.4G 3D Antenna Operating Temperature 0°C to 60°C Net weight 62.3g Gross weight 162g Product Size 54mm x 54mm x 30.5mm Package Size 105mm x 65mm x 40mm Case Material Plastic ( PC ) GO Bottom to view details parameters asyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. wnload Windows Version Easyloader Description: Load UIFlow firmware, built-in demo program supports testing of accelerometer, LED BAR, microphone, buttons and some peripheral sensors. The firmware can be used for UIFlow graphical programming. eripherals Pin Map & TF card :320x240 TF card Maximum size 16GB ESP32 Chip GPIO23 GPIO19 GPIO18 GPIO14 GPIO27 GPIO33 GPIO32 ILI9342C MOSI/MISO / CLK CS DC RST BL TF Card MOSI MISO CLK on & Speaker ESP32 Chip GPIO39 GPIO38 GPIO37 GPIO25 ESP32 Chip GPIO39 GPIO38 GPIO37 GPIO25 Button Pin BUTTON A BUTTON B BUTTON C / Speaker Speaker Pin VE Port A & IP5306 ve use the customized I2C version of IP5306, on power management. C address is 0x75. Click here to check its datasheet ESP32 Chip GPIO22 GPIO21 5V GND GROVE A SCL SDA 5V GND IP5306 SCL SDA 5V GND 06 charging/discharging,Voltage parameter charging discharging 0.00 ~ 3.40V -> 0% 4.20 ~ 4.07V -> 100% 3.40 ~ 3.61V -> 25% 4.07 ~ 3.81V -> 75% 3.61 ~ 3.88V -> 50% 3.81 ~ 3.55V -> 50% 3.88 ~ 4.12V -> 75% 3.55 ~ 3.33V -> 25% 4.12 ~ / -> 100% 3.33 ~ 0.00V -> 0% xis MotionTracking Sensor MPU6886 6886 I2C address 0x68 ESP32 Chip GPIO22 GPIO21 5V GND MPU6886 SCL SDA 5V GND ESP32 Chip GPIO22 GPIO21 5V GND BMM150 SCL SDA 5V GND ESP32 Chip GPIO36 GPIO26 5V GND GROVE B GPIO36 GPIO26 5V GND xis Geomagnetic Sensor BMM150 M150 I2C address 0x10 M5GO Base Port VE Port B VE Port C ESP32 Chip GPIO16 GPIO17 5V GND GROVE C RXD TXD 5V GND Bar & Micphone & Speaker ESP32 Chip GPIO15 GPIO34 GPIO25 Hardwares SIG Pin MIC Pin Speaker Pin M5PORT EXPLAIN PORT PIN Note: PORT-A(Red) G21/22 I2C PORT-B(Black) G26/36 DAC/ADC PORT-C(Blue) G16/17 UART SP32 ADC/DAC ADC1 ADC2 DAC1 DAC2 8 channels 10 channels 2 channels 2 channels G32-39 G0/2/4/12-15/25-27 G25 G26 M-BUS n using the RGB LED of gpio15, it is recommended to initialize,pinMode(15, OUTPUT_OPEN_DRAIN); For more information about Pin assignment an Remapping, Please refer to ESP32 Datasheet chematic Schematic Related Link Datasheet ESP32 MPU6886 BMM150 SH200Q IP5306 API Arduino API earn M5Stack Christmas Snow Globe Modern times make modern solutions possible. Therefore, the step to a digital snow globe is not that far. Q-Bot We aim to build a robot that is effective in sanitizing surfaces without putting cleaners in harm's way. Office M5Stack Assistant An IoT office assistant with "free, busy and lunch" indicators, Pomodoro timers and quick meetings with IFTTT and your calendar integration. Audio Spectrum Display with M5Stack An audio spectrum visualiser using the M5Stack internal mic or FC-04 sound sensor with the M5Stack core. Translated from a guide by macsbug M5Stack COM.LoRaWAN Using UIFlow M5Stack recently released an updated LoRaWAN module. This tutorial teaches you how to connect it to The Things Network using UIFlow. RTC Modules with M5Stack Out of the M5Stack family only the M5StickC has an inbuilt RTC. Here's how to add one to your other M5Stac devices xample duino Clickhereto get Arduino code Video tack instroduce Version Change elease Date 2018.6 Product Change Note: Initial public release / MPU9250 changed to SH200Q+BMM150, TN before use . pls upgrade your M5Stack lib to the latest version (after 0.2.8 screen changed to IPS screen to solve screen reverse color problem. SH200Q changed to MPU6886 / 2019.7 2019.8 Battery capacity changed from 600mAh to 2019.11 / 500mAh 2020.4 PSRAM Size changed from 4MB to 8MB /
很抱歉,暂时无法提供与“K007”相匹配的价格&库存,您可以联系我们找货
