K009-F
K009-F
    M5STACK(明栈)
    可穿戴设备 手表 套件 - 电池
K009-F 数据手册
Watch SKU:K009-F Description Watch is an M5Core watch set. In addition to being a powerful development hardware, the M5Core has a sophisticated look that gives it the possibility to wear smart. The kit is designed for the M5Core series,Compared with the old 3D printing base, the new model uses a mold, which has a qualitative improvement in appearance and quality. in addition to the cool strap. Also equipped with a 700mAh lithium battery, allowing users to have sufficient reliable endurance while using the device. Product Features • 700mAh lithium battery Weight and Size • • • • Item size: Base: 54.3mm x 54.3mm x 7mm Strap: 260mm x 22mm (total length after assembly) Item weight: Base: 25g Strap: 18g Product size: 127mm x 69mm x 23mm Product weight: 87g Package Includes • • • • • • 1x strap base 1x 700mAh battery 2x telescopic card pin 2x M3x15 screws 1x hex wrench 1x disassemble screwdriver Applications • smart watch Assembly step Assembling the strap: Insert the matching telescopic card into the strap fixing hole, and have two small holes on both sides of the base of the watch. Place one side of the telescopic card pin into the hole and the other side with the finger. Press and place it. Complete the installation of another strap in the same way. Install the battery: Plug the lead wire from the battery to the corresponding interface on the host circuit board. After the plug-in is completed, adjust the position of the battery to facilitate the installation of the watch base. Installation base: According to the position of the BUS bus on the main unit, the watch base is vertically inserted into the main unit and locked with the matching screws to complete the assembly. https://docs.m5stack.com/#/en/accessory/watch/4-3-20
K009-F 价格&库存
很抱歉,暂时无法提供与“K009-F”相匹配的价格&库存,您可以联系我们找货
