K010
K010
    M5STACK(明栈)
    - 收发器 评估板
K010 数据手册
M5Core2 SKU:K010 Description M5Core2 is the second generation core device in the M5Stack development kit series, which further enhances the functions of the original generation of cores. The MCU is an ESP32 model D0WDQ6-V3 and has dual core Xtensa® 32-bit 240Mhz LX6 processors that can be controlled separately. WiFi and Bluetooth are supported as standard and it includes an on board 16MB Flash and 8MB PSRAM, USB TYPE-C interface for charging, downloading of programs and serial communication, a 2.0-inch integrated capacitive touch screen, and a built-in vibration motor. M5Core2 also features a built-in RTC module which can provide accurate timing. The power supply is managed by an AXP192 power management chip, which can effectively control the power consumption of the base and a built-in green LED power indicator helps to notify the user of battery level. The battery capacity has been upgraded to 390mAh, which can power the core for much longer than the previous model. The M5Core2 retains the SD card slot and speakers. However, in order to ensure higher quality sound output, the I2S digital audio interface power amplifier chip is used to effectively prevent signal distortion. There are independent power and reset buttons on the left side and bottom of the base. The 3 icons on the front of the screen are capacitive buttons which are programmable. There is a small expansion board on the back of the base with a 6-axis IMU sensor and microphone. Development platforms and programming languages supported by M5Stack Core2 are as follows: Arduino, UIFlow and MicroPython No matter what level of your development and programming skills, M5Stack will help you turn your ideas into reality. Power on/off: • Power on: press the power button • Power off: press the power button for 6s Restart: press the reset button at the bottom Product Features • ESP32-based, built-in Bluetooth,WiFi • 16M Flash,8M PSRAM • Built-in speaker, power indicator, vibration motor, RTC, I2S amplifier, capacitive touch screen, power button, reset button • TF card slot (16G Maximum size) • Built-in lithium battery, equipped with power management chip • Independent small board built-in 6-axis IMU, PDM microphone • M-Bus Socket & Pins • Programming Platform: UIFlow, MicroPython, Arduino Include • 1x M5Stack Core2 • 1x Type-C USB(20cm) Applications • Internet of things terminal controller • Stem education product • DIY prototyping • Smart home interface Specification EasyLoader PinMap LCD & TF card LCD :320x240 TF card Maximum size 16GB CAP.TOUCH Mic & NS4168 AXP Power Indicator Light RTC IMU(3-axis gyroscope & 3-axis accelerometer) USB to serial chip Internal I2C connection M5Core2 M-BUS Schematic diagram M5Core2 PORT Description ESP32 ADC/DAC For more information about Pin assignment and Pin Remapping, Please refer to ESP32 Datasheet Related Link • Datasheet • ESP32 • FT6336U • NS4168 • MPU6886 • ILI9342C • SPM1423 • BM8563 • SY7088 • AXP192 Schematic • Schematic Example Arduino IDE • Clickhereto get Arduino code Video
很抱歉,暂时无法提供与“K010”相匹配的价格&库存,您可以联系我们找货
K010
  • 1+414.055191+53.53993
库存:290
