K016-P
K016-P
    M5STACK(明栈)
    可穿戴设备 IOT 开发 套件 - 电池,电路板,电缆,USB
K016-P 数据手册
M5StickC PLUS SKU:K016-P Tutorial&Quick-Start Choose the development platform you want to use, view the corresponding tutorial&quick-Start. UIFlow Arduino M5StickC-Plus can use most programs of M5StickC. Due to hardware differences such as screens, please download the M5StickCPlus library before compiling the program and modify the header file reference in the program as M5StickCPlus.h . Description M5StickC PLUS is powered by ESP32-PICO-D4 with Bluetooth 4.0 and WiFi and is an upgrade of the original M5StickC with a bigger screen .It is a portable, easy-to-use, open source, IoT development board. This tiny device will enable you to realize your ideas, enrich your creativity, and speed up your IoT prototying. Developing with M5StickC PLUS takes away a lot of the pains from the development process. M5StickC Plus is one of the core devices in M5Stacks product series. The compact body is integrated with rich hardware resources, such as infrared, RTC, Microphone, LED, IMU, Buttons, PMU,etc. Improvements from the regular StickC are a buzzer, bigger screen (1.14-inch, 135 * 240 resolution LCD Screen) and more stable hardware design. This revision increases the display area by 18.7%, and the battery capacity from 95mAh to 120mAh. It also supports the HAT and Unit family of products. Power switch operation: Power on :Press power button for 2 seconds Power off :Press power button for 6 seconds Notice: Baud rate supported by M5StickC Plus: 1200 ~115200, 250K, 500K, 750K, 1500K G36/G25 share the same port, when one of the pins is used, the other pin should be set as a floating input For example, to use the G36 pin as the ADC input, Configuration the G25 pin as FLOATING The input range of VBUS_VIN and VBUS_USB is limited to 4.8-5.5V, and the internal battery will be charged through AXP192 power management when VBUS is powered. setup() { M5.begin(); pinMode(36, INPUT); gpio_pulldown_dis(GPIO_NUM_25); gpio_pullup_dis(GPIO_NUM_25); } Product Features ESP32-based support BLE 4.2 and WiFi Built-in 6-Axis IMU Red LED IR transmitter Microphone RTC Buttons, LCD(1.14 inch) Built-in Lipo Battery Extendable Socket Built-in Passive Buzzer Wearable & Wall mounted Development Platform UIFlow, MicroPython, Arduino Include 1x M5StickC Plus Applications Internet of things terminal controller Wearable devices Stem education product DIY creation USB Drive problems UnitV/M5StickV/M5StickC/ATOM may not work without driver in some systems. Users can manually install FTDI driver to fix this problem. Take the win10 environment as an example, download the driver file that matches the operating system, decompress it, and install it through the device manager. (Note: In some system environments, the driver needs to be installed twice for the driver to take effect. The unrecognized device name is usually M5Stack or USB Serial . Windows recommends using the driver file to install directly in the device manager (custom Update), the executable file installation method may not work properly). Specification Resources Parameter ESP32 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi, dual mode Bluetooth Flash Memory 4MB Power Input 5V @ 500mA Port TypeC x 1, GROVE(I2C+I/0+UART) x 1 LCD screen 1.14 inch, 135*240 Colorful TFT LCD, ST7789v2 Button Custom button x 2 LED RED LED MEMS MPU6886 Buzzer built-in buzzer IR Infrared transmission MIC SPM1423 RTC BM8563 PMU AXP192 Battery 120 mAh @ 3.7V Antenna 2.4G 3D Antenna PIN port G0, G25/G36, G26, G32, G33 Operating Temperature 0°C to 60°C Net weight 15g Gross weight 21g Product Size 48.2*25.5*13.7mm Package Size 65*25*15mm Case Material Plastic ( PC ) EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Please install the corresponding driver according to the device type. M5Core host Please click here to view the CP210X driver installation tutorial, M5StickC/M5StickV/M5StickT/ATOM series can be used without driver) Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: Accelerometer, microphone, LED, IR, RTC, Bluetooth and other hardware tests. Press A or B to switch test items. Schematic PDF Download PinMap Power structure block diagram RED LED & IR Transmitter & BUTTON A & BUTTON B ESP32 GPIO10 RED LED LED Pin GPIO9 IR Transmitter GPIO37 GPIO39 GPIO2 Transmitter Pin BUTTON A Button Pin BUTTON B Button Pin Buzzer Buzzer Pin TFT LCD Driver IC:ST7789v2 Resolution:135 * 240 ESP32 GPIO15 GPIO13 GPIO23 GPIO18 GPIO5 TFT LCD TFT_MOSI TFT_CLK TFT_DC TFT_RST TFT_CS GROVE PORT ESP32 GPIO33 GPIO32 5V GND GROVE port SCL SDA 5V GND MIC (SPM1423) ESP32 GPIO0 GPIO34 MICPHONE CLK DATA 6-Axis posture sensor (MPU6886) & power management IC (AXP192) ESP32 GPIO22 GPIO21 6-Axis IMU sensor SCL SDA Power management IC SCL SDA AXP192 Microphone RTC TFT backlight TFT IC ESP32/3.3V MPU6886 5V GROVE LDOio0 LDO1 LDO2 LDO3 DC-DC1 IPSOUT Related Link datasheet ESP32-PICO ST7789v2 BM8563 MPU6886 AXP192 SPM1423 API Arduino API Arduino Library M5StickC_PLUS Library Example Arduino M5StickC Plus facory test code
K016-P 价格&库存
很抱歉,暂时无法提供与“K016-P”相匹配的价格&库存,您可以联系我们找货
K016-P
  • 1+177.897301+23.01380
库存:114
