ATOM HUB PROTO
SKU:K039
Description
ATOM HUB PROTO is a DIY proto board module designed for use with the ATOM series. Users can build circuits or connect peripherals according
to their own needs to satisfy the functions and requirements of specific scenarios. Considering the various possibilities of user connection, ATOM
HUB PROTO provides a wealth of interfaces, including VH3.96 interface, DC-5V power interface, grove interface, and all kinds of openings are
reserved on the shell to facilitate user wiring。A variety of mounting holes are designed on the back of the fuselage, which not only support the
traditional hanging holes and screw fixing holes, but also support the fixation of slide rail clamps.Built in proto circuit board, main circuit space
layout 45x35x20mm.With atomhub, you can make your own hardware devices at will, such as connecting batteries by yourself, or integrating
micro air pump + air pressure sensor to make a blood pressure meter, or even building a positioning and tracking system with GPS + NB-IoT
module.
Product Features
Compatible with ATOM Matrix/ATOM Lite
Compact design
Industrial applications
Multiple interface output
Multiple mounting holes
Creative DIY
Includes
1x Proto board(include GROVE port)
1x 3.96*4P Plug & Plug Base
6x 3.96*3P Plug & Plug Base
1x ATOM HUB PROTO Face shell
1x DC 5V Power outlet
4x Dust Plug
1x DIN Rail
2x Plastic
4x Magnet double-side tape
4x Rubberpad
4x Magnet
4x M2*6mm Hexagon self tapping screw
1x M2*20mm Hexagon socket cup head machine screw
2x M4*10mm Hexagon countersunk screw
1x M2 Hex Key
1x M4 Hex Key
Applications
Atom expansion board
Industrial controller node
Peripheral connection
DIY hardware
Specification
Specification
Parameter
External port
1x VH-3.96 4P 6x VH-3.96 3P 1x DC5V Input 1x GROVE
Net weight
93g
Gross weight
105g
Product Size
72*40*30mm
Package Size
104 x 77 x 35mm
Case material
Plastic ( PC )
USAGE
Depending on your use case you can design the circuit or prototype, soldering the corresponding components,through the vh-3.96 interface to
connect external electrical equipment.You can also choose to purchase round waterproof connector connecting cable by yourself.
If you need to supply power through an external power supply, you can choose to supply power directly to ATOM through USB, or solder the DC
5V connector and connect the positive and negative poles to the corresponding pins of the ATOM. If the input voltage is higher than 5V, you need
to build your own voltage step-down circuit.If you need to use the GROVE port, connect the pad breakpoint corresponding to the pin number you
decide to use.
Related Link
PcbDoc
AtomHubProto
Example
Arduino
A remote control circuit is built in ATOM HUB PROTO by using the step-down circuit and relay. The control pin of the relay is GPIO21, which is
powered by an external power supply. It is connected to Apple's Homekit application through WiFi for remote control. Open the Homekit for
manual connection. The default password is 11111111. Use the Siri voice remote control or manual button for remote control.
Click here to download the Arduino example
Video
Demo
很抱歉,暂时无法提供与“K039”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+74.707691+9.66544
